View Single Post
Old March 9th 05, 11:10 AM
John Miller
John A. Weeks III wrote:
OK, its time to wind this discussion down.
Way past time. Someone (was it you?) should be spanked for floating the
idea in the first place. But let me point out the likely reason for the
resistance you're encountering, because I believe you're not trolling,
merely misguided.
The homeless/carrier thing is simply the wrong solution to the wrong
problem. Like many well-intentioned people, you're attacking the
symptom rather than the cause. The focus should be on eliminating
homelessness, not warehousing the homeless.
But even if warehousing were the goal, putting them on an aircraft is,
if I may say so, a spectacularly bad way to do it. If you would only
reflect on it it a bit, you'd no doubt come to the same conclusion.
John Miller
