We are getting close to getting our first winch operation going and need to
develop some Ops and Procedures. I hate starting with a "blank page" Anybody have some Ops and Procedures to send my way to get started? Regards, Frank My return address is slightly modified to reduce SPAM. |
There are a lot of articles about this issue, but here are the main rules:
- take special care about the first 50m!!! - don't climb too steep, keep the speed high enough to react cable break/winch failure. - always be prepared for cable break/winch failure, decide what to do on different altitudes BEFORE take-off!! - always release cable in case of emergency, several pilots landed with cable - winch driver also should cut the cable without hesitation in case of emergency - discuss common signaling method between winch driver and pilots (at our site: too slow use ailerons, too fast use rudder) - clear airspace before launch - check weather situation (lightning!) Have fun ![]() /Janos Frank Smith wrote: We are getting close to getting our first winch operation going and need to develop some Ops and Procedures. I hate starting with a "blank page" Anybody have some Ops and Procedures to send my way to get started? Regards, Frank My return address is slightly modified to reduce SPAM. |
![]() Janos' recommendations are good, with one exception: - discuss common signaling method between winch driver and pilots (at our site: too slow use ailerons, too fast use rudder) At my home field (and throughout Denmark), we use: Too slow: Lower nose somewhat, signal with rudder. Too fast: Signal with ailerons. When too slow (and maybe with too high AOA for the speed), aileron deflections that might get one wing above critical AOA is the last thing we want, right? Anyway, be 100% sure what signals to use! -As we see, they can differ from site to site. What do the rest of you winchers use for signalling out there? Happy Soaring, Lars Peder Mosquito W6, Denmark. "Janos Bauer" wrote in message ... There are a lot of articles about this issue, but here are the main rules: - take special care about the first 50m!!! - don't climb too steep, keep the speed high enough to react cable break/winch failure. - always be prepared for cable break/winch failure, decide what to do on different altitudes BEFORE take-off!! - always release cable in case of emergency, several pilots landed with cable - winch driver also should cut the cable without hesitation in case of emergency - discuss common signaling method between winch driver and pilots (at our site: too slow use ailerons, too fast use rudder) - clear airspace before launch - check weather situation (lightning!) Have fun ![]() /Janos Frank Smith wrote: We are getting close to getting our first winch operation going and need to develop some Ops and Procedures. I hate starting with a "blank page" Anybody have some Ops and Procedures to send my way to get started? Regards, Frank My return address is slightly modified to reduce SPAM. |
Of course we also lower the nose (generally it's enough for most of
the winch drivers ![]() facing to the sailplane and moving of wings is much more visible than the fuselage twisting. If the speed is too high probably you fly with steep angle and in this position the winch driver will see the glider belly only. Ailerons movement will make small effect but rudders will shake the whole fuselage. Regards, /Janos Lars Peder Hansen wrote: Janos' recommendations are good, with one exception: - discuss common signaling method between winch driver and pilots (at our site: too slow use ailerons, too fast use rudder) At my home field (and throughout Denmark), we use: Too slow: Lower nose somewhat, signal with rudder. Too fast: Signal with ailerons. When too slow (and maybe with too high AOA for the speed), aileron deflections that might get one wing above critical AOA is the last thing we want, right? |
What do the rest of you winchers use for signalling out there? Radio. Stefan |
It could be difficult on our noisy Hercules H4
![]() /Janos Stefan wrote: Lars Peder Hansen wrote: What do the rest of you winchers use for signalling out there? Radio. Stefan |
Janos Bauer wrote:
It could be difficult on our noisy Hercules H4 ![]() Well, there is a tool exactly for this. It's called headset. Stefan |
This may be a off the wall suggestion but with the learning curve
required and the potential for a serious accident if a pilot doesn't react correctly or quickly enough Why not do a deal to import the teaching experience you need . Why reinvent the wheel. Worldwide there are a large number highly qualified people who could transplant their knowledge. I know of several retired people (they have the time) at my club who are both A cat instructers,winchdriver rated and have vast experience from all round the world ,one in particular has competed at a number of world championships. There are bound to be others with similar qualities , all you need is a deal that makes it attractive, I would say probably airfares and a place to stay with food , maybe a block of time in a local single seater so they can go xcountry in a new area. If you advertised you might be pleasantly surprised. "Frank Smith" wrote in message news ![]() We are getting close to getting our first winch operation going and need to develop some Ops and Procedures. I hate starting with a "blank page" Anybody have some Ops and Procedures to send my way to get started? Regards, Frank My return address is slightly modified to reduce SPAM. |
What do the rest of you winchers use for signalling out there? Too fast -- Signal with rudder - needs to be positive enough that the winch driver can tell the difference between a signal & a badly flown launch Too Slow - Abandon the launch while you still have time/space to land ahead. Any signal that's positive enough for the winch driver to see (Aileron or Rudder) with marginal speed and the extra weight/load of the cable is simply asking for something nasty to happen :-) |
You need to carefully think about this. Time was in
the UK when the signal for too fast was yawing the glider (it still is) and the signal for too slow was lower the nose and 'signal with ailerons'. The latter procedure was 'banned' some years ago, with good reason and replaced by lower the nose, if the airspeed does not increase, RELEASE and treat as a launch failure. A glider on the launch is carrying a large amount of cable which increases the wing loading, the wing is almost certainly already at a high angle of attack and if motive power is lost this has to increase. (as airspeed reduces angle of attack increases to maintain flight). Knowing what happens if the angle of attack of a wing is increased by moving the airleron down on one wing, when that wing is already at a high angle of attack, do you really want to do that. One wing stalled=possibility of spinning with the cable still attached, not something that you will want to do. This scenario is induced by moving the ailerons in this situation. That is why the practice was discontinued in the UK. Use of the rudder (yawing) at a high angle of attack is probably even worse, makes me cringe to think about it. I agree with the gentleman who advised getting an experienced winch launch instructor to see you through the first few days/weeks. It may cost a few shekels but what value do you put on a life At 10:48 12 February 2004, Janos Bauer wrote: Of course we also lower the nose (generally it's enough for most of the winch drivers ![]() The winch driver facing to the sailplane and moving of wings is much more visible than the fuselage twisting. If the speed is too high probably you fly with steep angle and in this position the winch driver will see the glider belly only. Ailerons movement will make small effect but rudders will shake the whole fuselage. Regards, /Janos Lars Peder Hansen wrote: Janos' recommendations are good, with one exception: - discuss common signaling method between winch driver and pilots (at our site: too slow use ailerons, too fast use rudder) At my home field (and throughout Denmark), we use: Too slow: Lower nose somewhat, signal with rudder. Too fast: Signal with ailerons. When too slow (and maybe with too high AOA for the speed), aileron deflections that might get one wing above critical AOA is the last thing we want, right? |
Showstoppers (long, but interesting questions raised) | Anonymous Spamless | Military Aviation | 0 | April 21st 04 05:09 AM |
"I Want To FLY!"-(Youth) My store to raise funds for flying lessons | Curtl33 | General Aviation | 7 | January 9th 04 11:35 PM |
USAFE commander: 86th Airlift Wing will divide for combat, support operations | Otis Willie | Military Aviation | 0 | November 27th 03 11:31 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
using winch instead of aerotow | goneill | Soaring | 5 | August 27th 03 02:46 PM |
