I just noticed that a few of the welds on the top aluminum framework
of my Komet trailer have broken. Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4 |
On Oct 19, 11:40*am, Bruno wrote:
I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4 A friend has the same problem with his Komet. We were talking to a welding guy and he mentioned that it could be Stitch Welded, dunno what that means, but worth a try. Brad |
On Oct 19, 12:15*pm, Brad wrote:
On Oct 19, 11:40*am, Bruno wrote: I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4 A friend has the same problem with his Komet. We were talking to a welding guy and he mentioned that it could be Stitch Welded, dunno what that means, but worth a try. Brad That's a technique of doing a lot of short welds, spread way apart, letting those cool, then doing another series of short welds between the first batch, and repeating until the weld is continuous. Keeps you from cooking the fiberglass. |
I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4 Now I'm going to have to look at my trailer more closely. I know all the structure of the bottom half is steel, and I had assumed the top was too! (My trailer is late 70's vintage). Where are your welds cracked? If there is access, it can be re-welded. Otherwise, gussets, epoxy, and rivets. IMO, just putting epoxy (or any type of glue/ cement/bonding agent) in the places the welds have cracked won't take care of the problem. |
if you're afraid of welding heat and don't want to remove the top (I would
dare to say they is a pretty big job, why not look at adding a few aluminum sheet gussets where the cracks are...typically mechanical fasteners can be as strong or stronger than the welded aluminum joints if properly done. Even (good) high strength Pop-Rivets could be use easily to attached the gussets. tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Bruno" wrote in message ... I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4 |
I agree with Tim, alu welds are much weaker.
Gussets and bolts are much stronger. The most likely reason the weld broke, vibration. Udo On Oct 19, 3:48*pm, "Tim Mara" wrote: if you're afraid of welding heat and don't want to remove the top (I would dare to say they is a pretty big job, why not look at adding a few aluminum sheet gussets where the cracks are...typically mechanical fasteners can be as strong or stronger than the welded aluminum joints if properly done. Even (good) high strength Pop-Rivets could be use easily to attached the gussets. tim Please visit the Wings & Wheels website atwww.wingsandwheels.com "Bruno" wrote in message ... I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4- Hide quoted text - - Show quoted text - |
On Oct 19, 5:23*pm, Udo wrote:
I agree with Tim, alu welds are much weaker. Gussets and bolts are much stronger. The most likely reason the weld broke, vibration. Udo On Oct 19, 3:48*pm, "Tim Mara" wrote: if you're afraid of welding heat and don't want to remove the top (I would dare to say they is a pretty big job, why not look at adding a few aluminum sheet gussets where the cracks are...typically mechanical fasteners can be as strong or stronger than the welded aluminum joints if properly done. Even (good) high strength Pop-Rivets could be use easily to attached the gussets. tim Please visit the Wings & Wheels website atwww.wingsandwheels.com "Bruno" wrote in message ... I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - Agree with Udo ..060 aluminum gussets, Cherry Max rivets. Good for life UH |
On Oct 19, 3:49*pm, wrote:
On Oct 19, 5:23*pm, Udo wrote: I agree with Tim, alu welds are much weaker. Gussets and bolts are much stronger. The most likely reason the weld broke, vibration. Udo On Oct 19, 3:48*pm, "Tim Mara" wrote: if you're afraid of welding heat and don't want to remove the top (I would dare to say they is a pretty big job, why not look at adding a few aluminum sheet gussets where the cracks are...typically mechanical fasteners can be as strong or stronger than the welded aluminum joints if properly done. Even (good) high strength Pop-Rivets could be use easily to attached the gussets. tim Please visit the Wings & Wheels website atwww.wingsandwheels.com "Bruno" wrote in message .... I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - Agree with Udo .060 aluminum gussets, Cherry Max rivets. Good for life UH Thanks all for the replies. I was hoping that someone would say JB- Weld would work great but I think I am going to have to bite the bullet and try my hand at doing a few rivets and aluminum gussets. I am glad I saw the broken welds when I did last night. They are on both sides of the bar that holds my stabilizer to the roof. I only had a few screws attached to the ceiling holding that half of the stabilizer holder up into the roof. Yikes! I would recommend everyone the next time they are in their trailer to look at the welds up in the corners of their trailer roof for breaks. Thanks, Bruno - B4 |
On Oct 19, 7:32*pm, Bruno wrote:
On Oct 19, 3:49*pm, wrote: On Oct 19, 5:23*pm, Udo wrote: I agree with Tim, alu welds are much weaker. Gussets and bolts are much stronger. The most likely reason the weld broke, vibration. Udo On Oct 19, 3:48*pm, "Tim Mara" wrote: if you're afraid of welding heat and don't want to remove the top (I would dare to say they is a pretty big job, why not look at adding a few aluminum sheet gussets where the cracks are...typically mechanical fasteners can be as strong or stronger than the welded aluminum joints if properly done. Even (good) high strength Pop-Rivets could be use easily to attached the gussets. tim Please visit the Wings & Wheels website atwww.wingsandwheels.com "Bruno" wrote in message ... I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. *Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. *Does anyone have any suggestions for a good bonding agent to use on the broken welds? Thanks, Bruno - B4- Hide quoted text - - Show quoted text -- Hide quoted text - - Show quoted text - Agree with Udo .060 aluminum gussets, Cherry Max rivets. Good for life UH Thanks all for the replies. *I was hoping that someone would say JB- Weld would work great but I think I am going to have to bite the bullet and try my hand at doing a few rivets and aluminum gussets. *I am glad I saw the broken welds when I did last night. *They are on both sides of the bar that holds my stabilizer to the roof. *I only had a few screws attached to the ceiling holding that half of the stabilizer holder up into the roof. *Yikes! *I would recommend everyone the next time they are in their trailer to look at the welds up in the corners of their trailer roof for breaks. Thanks, Bruno - B4 Note that UH says Cherry-Max - these are not cheapo pop-rivets ! |
Bruno wrote:
I just noticed that a few of the welds on the top aluminum framework of my Komet trailer have broken. Maybe I am just lazy but I am concerned about getting the welds redone with the fiberglass top right next to it. Does anyone have any suggestions for a good bonding agent to use on the broken welds? Considering what a trailer is meant to bear and how long it will hopefuly remain in use, I would bite the bullet, remove the top and have the welding job done by a pro without compromises. |
Gas Welding Aid 1 - welding clamp 1.JPG (0/1) | Stealth Pilot[_2_] | Aviation Photos | 1 | March 26th 09 07:20 AM |
gas welding aid 2 - welding clamp 2.JPG (1/1) | Stealth Pilot[_2_] | Aviation Photos | 0 | March 26th 09 03:58 AM |
gas welding aid 2 - welding clamp 2.JPG (0/1) | Stealth Pilot[_2_] | Aviation Photos | 0 | March 26th 09 03:57 AM |
aluminum rib, aluminum spar, holes drilled but screws broken off | jls | Home Built | 13 | January 3rd 07 08:06 AM |
Aluminum welding | Ernest Christley | Home Built | 5 | April 24th 06 11:47 AM |
