Winter Water Ballast
Old November 24th 09, 05:20 AM posted to rec.aviation.soaring
Scott Alexander[_2_]
Default Winter Water Ballast
Anyone have any bright ideas on how to keep the water from freezing?
Salt?
Antifreeze?
Anything?
Old November 24th 09, 09:00 AM posted to rec.aviation.soaring
sisu1a
On Nov 23, 9:20*pm, Scott Alexander
Salt?
Antifreeze?
Anything?
Yes antifreeze, but the type of antifreeze that is made for
winterizing RV drinking water tanks. (not toxic when dumped)
-Paul
Old November 24th 09, 10:31 AM posted to rec.aviation.soaring
Tim Taylor
On Nov 23, 10:20*pm, Scott Alexander
Salt?
Antifreeze?
Anything?
The two best solutions are Methanol and Propylene glycol. Salt
absolutely not! Cost wise it will depend on how much of a freezing
point depression you need.
Freezing Point
Propylene Glycol Solution
(% by mass) F
0 32
10 26
20 18
30 7
Methanol Concentration
(% by mass) F
0 32
10 20
20 0
30 -15
Methanol will cost about $3 to $4 per gallon, Propylene Glycol can be
purchased as RV antifreeze in either -50 or -100 solutions. These are
25% and 50% solutions so you will need to to dilute accordingly.
Price for the -50 runs about $4 a gallon.
Lets do a back of the envelope calculation of what you need for a day
where you want to protect down to about 15 F.
Propylene Glycol you will need a 22% solution by mass or about 27% by
volume so you for a 40 gallon total load in your glider you will need
about 35 gallons of off the self -50 antifreeze. Cost of about $140
per flight.
Methanol you will need about 13% by mass or 16.5% by volume. So you
will need about 6.6 gallons of menthanol at a cost of about $25 USD
per flight.
Old November 24th 09, 05:26 PM posted to rec.aviation.soaring
T8
On Nov 24, 12:20*am, Scott Alexander
Salt?
Antifreeze?
Anything?
You mentioned Dan & Dave Cole in another thread in the context of
getting good, conservative advice. Ask them. I predict you'll get
some more good, conservative advice :-).
Temptation to fly with ballast in extremely cold weather is sometimes
an indicator of an excessive BCS ratio.
-Evan Ludeman / T8
Old November 24th 09, 08:38 PM posted to rec.aviation.soaring
Papa3
getting good, conservative advice. *Ask them. *I predict you'll get
-Evan Ludeman / T8
Ditto on that. We at Blairstown fly ridge all year round, and over
the years folks have fiddled with this stuff. There are just too many
things to go wrong. I have a great photo somewhere of Dave Michaud
(UM) with like 8 lbs of ice (okay, probably not 8) hanging off his
tail boom. Some combination of leaking dump valve in the wing and
getting the mixing ratio of anti-freeze wrong.
Frankly, the days are too short for record flights, so the only
reason to carry ballast is to smooth out the ride a bit or go a little
faster. I submit that it's just not worth it.
P3
Old November 25th 09, 04:15 PM posted to rec.aviation.soaring
Ronald Tabery
-Evan Ludeman / T8
Ditto on that. *We at Blairstown fly ridge all year round, and over
the years folks have fiddled with this stuff. *There are just too many
things to go wrong. * I have a great photo somewhere of Dave Michaud
tail boom. * Some combination of leaking dump valve in the wing and
*Frankly, the days are too short for record flights, so the only
faster. * I submit that it's just not worth it.
P3
The concern over ballast freezing in the wing is not the issue.
Forget about all antifreeze additives, particularly alcohols and
salt. As pointed out, leaking valves is the issue. Water cools
slowly to zero and then it has to jump 80 calories per gram to freeze
(heat of fusion). Starting with relatively warm water gives you many
hours of sloshing; I have contest experience in New Zealand with
flights of many hours in the wave (-20 degrees) without ballast
freezing. The wing's foam cores serve as insulation and freezing is
not a problem in all but the most extreme circumstances of time and
temperature. Warm water can extend the hours significantly. Carry
water all year if you like, just make sure you have water tight
valves. Freezing the valves shut is more of a concern than dangling
ice for wing-mounted dumps; fuselage dumps are another matter due to
possible CG shift from accumulation on the tail boom. Overall, it is
not a big concern.
ron tabery
Old November 25th 09, 04:45 PM posted to rec.aviation.soaring
If there is a concern of water freezing when dumping it out over the
rudder, flaps or ailerons, then consider this.
The CRJ-200 has a limitation during certain icing parameters to move
the ailerons (wiggle them) every 5,000 feet during climbout. There's
been a few CRJ's that had the ailerons freeze up due to ice.
Seems like if we were to dump ballast, then during the dumping move
the control surfaces back and forth that are going to get wet until
the water is all dumped out.
Old November 25th 09, 04:50 PM posted to rec.aviation.soaring
vontresc
On Nov 25, 10:45*am, Scott Alexander
the ailerons (wiggle them) every 5,000 feet during climbout. *There's
Hmmm this whole discussion got me to thinking. What if you changed the
ballast tanks to handle something like extremely fine silica sand.
This would be denser, and if kept sufficiently dry would flow quite
well. IIRC balloonists have been using and dumping sand bags for
years, why not in a sailplane?
Pete
Old November 25th 09, 04:59 PM posted to rec.aviation.soaring
Papa3
On Nov 25, 11:45*am, Scott Alexander
It's not so much about the control surfaces (though the rudder in the
example I gave actually was fairly limited in travel as a rsult of the
icing). It's the assymetric dumping and other stuff. For example:
On the LS8, the wing dumps orifices are about 1" give or take. The
tail dump is maybe 0.25". Which one is more likely to ice-up if you
get something wrong? Now, depending on the empty CG, dumping all
the wing ballast and not being able to dump the tail may (or may not)
be a big deal. In other ships with fiddly valves (pretty much any
Schleicher OEM system), what if one wing dumps and the other doesn't?
Big dieal? Sometimes yes, sometimes no. Obviously, these same risks
exist in warm weather, but they are clearly greater in cold weather.
So again, what are the real percentages in carrying water ballast in
our neck of the woods in winter? Most of the big records are done in
April/May or September/October when the days are long enough to get
started early and fly late.
Not to mention the fact that it's just damned uncomfortable messing
with water when it's cold outside :-)
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
water ballast leak Robert Harvey Soaring 0 May 26th 05 10:33 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
astir cs-77 water ballast pete83 Soaring 4 May 27th 04 05:21 AM
