Aero 1550 and XCSoar
Old January 23rd 10, 04:45 PM posted to rec.aviation.soaring
Andy[_1_]
Default Aero 1550 and XCSoar
Is there a version of XCSoar that is compatible with the Compaq Aero
1550 (MIPS R4111, CE 3.0). Is so, is it available for download?
I have downloaded Installxcsoar-ppc2002.exe. It installs ok but
returns the error "not a valid Windows CE application" when atempting
to run it.
Don't want to waste any more time on this if it isn't supported
anymore.
thanks
Andy
Old January 23rd 10, 08:02 PM posted to rec.aviation.soaring
Brian[_1_]
For anyone still using the 1550 I am set up to compile the exe file
for it.
Let me know if you want me to email you a newer exe file for the 1550.
Brian
Old January 23rd 10, 09:50 PM posted to rec.aviation.soaring
Andy[_1_]
for it.
Brian
Thanks Wayne and Brian for the help.
Andy
Old January 24th 10, 02:06 AM posted to rec.aviation.soaring
John Seaborn[_2_]
Andy,
So how does XC run on the 1550? How did it install?
John Seaborn
for it.
Brian
Andy
Old January 24th 10, 03:04 PM posted to rec.aviation.soaring
Andy[_1_]
On Jan 23, 7:06*pm, John Seaborn wrote:
Andy,
I received Aero 1550 compatible files for XCSoar and XCSoar
simulator. I just copied them to my 1550 using the explorer function
of ActiveSync and they run fine. You can use the same TP file as GNII
but need Open Air format airspace. You'll also need a suitable polar
file. I have not attempted to install any terrain files and have no
expectaion it would work on this processor.
So far I'm just getting familiar with it in simulator mode and can't
comment on how well it will work in flight on this device. I can pass
the files on to you if you send me an email.
I was not able to find compatible files on the XCSoar site and have
been told that support for the 1550 is discontinued. But see Brian's
offer above. I found the XCSoar documentation relating to 1550
support to be conflicting and confusing but maybe that's just me.
Andy
Old January 24th 10, 03:43 PM posted to rec.aviation.soaring
Brian[_1_]
What works even better than the Simulator mode is to use the Flight
Version and the Replay feature. Put an IGC file from one of your
previous flights on the PDA and replay it. This may work on the
Simulator as well, but I don't think I have tried it.
Brian
looking for Compaq Aero 1550 [email protected] Soaring 3 June 5th 08 05:19 PM
WANTED: Compaq Aero 1550 WaltWX Soaring 12 March 20th 08 04:10 PM
FS: Aero 1550 GH Soaring 1 September 24th 04 02:59 AM
FS Aero 1550 Ed Hollestelle Soaring 0 July 12th 04 08:10 PM
mSeeYou (ver1.01) on Aero 1550 Jean-Paul BERRY Soaring 0 February 20th 04 02:59 PM
