vfr on top
Old February 15th 10, 07:51 AM posted to rec.aviation.ifr
Myname
Default vfr on top
What are the advantages of vfr-on-top in the real world? I understand the
ifr to vfr-on-top then cancel, but what about other uses?
Old February 15th 10, 11:11 AM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Default vfr on top
the ifr to vfr-on-top then cancel, but what about other uses?
Well, what are the advantages of IFR to VFR-on-top then cancel?
Old February 15th 10, 06:03 PM posted to rec.aviation.ifr
Default vfr on top
On Feb 15, 4:11*am, "Steven P. McNicoll"
Well, what are the advantages of *IFR to VFR-on-top then cancel?
To legally punch a cloud deck.
I have done this several times on a 50NM trip where it was VFR at my
destination.
It's easier to cancel in the air with KJAN once I am 1000 foot above
the cloud deck then to have to call FSS to cancel my IFR.
I would only be with Memphis center a mere 3 to 5 minutes before
initiating a descent below radar coverage so I can't cancel with them
on the ground.
Old February 20th 10, 05:43 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default vfr on top
destination.
on the ground.
That's not "IFR to VFR-on-top then cancel", that's IFR to punch
through a cloud deck then cancel upon reaching VFR conditions. You're
not VFR-on-top until you've been cleared to maintain VFR-on-top and
you can't be cleared to maintain VFR-on-top until you've reported
reaching VFR-on-top.
Old February 21st 10, 02:17 PM posted to rec.aviation.ifr
Default vfr on top
On Feb 20, 10:43*am, "Steven P. McNicoll"
Your terminology flat out wrong...... Based on the question you
asked, my scenario answered your question. You said VFR ON TOP.
You can't be VFR on top WITHOUT an IFR clearance. VFR on TOP is IFR.
Once you cancel IFR, you no longer are VFR on top. So what you say
above is absolutely an impossible scenario.
There is specific terminology for VFR traffic that you are not picking
up on and that is VFR OVER the top.
That is build in for VFR. VFR rules require contact with the ground
OR maintain 1000 feet above the cloud deck and fly VFR OVER the top
with your departure and destination being VFR for the flight to be
legal.
And even then you don't report to ATC that you are VFR over the top,
it's just simple flight following.
In my answer to you, , I file IFR, fly through the cloud, get VFR on
top and cancel IFR. Once I cancel IFR, I have the option of electing
flight following and maintaining VFR OVER the top. In this case, you
could drop me for workload consideration.
You can't drop me if I am VFR ON TOP as I am IFR until I cancel.
Old February 21st 10, 03:03 PM posted to rec.aviation.ifr
Steven P. McNicoll
Default vfr on top
Your terminology flat out wrong...... *Based on the question you
asked, my scenario answered your question. *You said VFR ON TOP.
"IFR to VFR-on-top then cancel" is not my terminology, it's the OP's,
Myname. Your response did not answer the question I directed to him.
You can't be VFR on top WITHOUT an *IFR clearance. *VFR on TOP is IFR..
Correct.
Once you cancel IFR, you no longer are VFR on top. * So what you say
And that's why I asked the question.
We're not talking about that.
That is build in for VFR. *VFR rules require contact with the ground
legal.
Flight following is not a requirement of VFR over-the-top operations.
top and cancel IFR. *Once I cancel IFR, I have the option of electing
flight following and maintaining VFR OVER the top. *In this case, you
But why request VFR-on-top if all you want to do is punch a cloud deck
and cancel upon reaching VFR conditions? Why ask for something you
don't intend to use?
Correct.
Old February 15th 10, 11:21 AM posted to rec.aviation.ifr
Mxsmanic
Default vfr on top
Myname writes:
The main advantage is that it allows a pilot to choose his altitude at his
discretion, within broad limits, rather than request approval for every change
of altitude from ATC.
Old February 20th 10, 07:46 AM posted to rec.aviation.ifr
A Guy Called Tyketto
Default vfr on top
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Mxsmanic wrote:
Myname writes:
You can already do that with VFR w/flight following.
BL.
Brad Littlejohn | Email:
Unix Systems Administrator, |
Web + NewsMaster, BOFH.. Smeghead! |
http://www.wizard.com/~tyketto
PGP: 1024D/E319F0BF 6980 AAD6 7329 E9E6 D569 F620 C819 199A E319 F0BF
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.10 (GNU/Linux)
iD8DBQFLf4VLyBkZmuMZ8L8RAvhqAJwPt2twDJ17gZuIASVZMz r2jz3nDACfbybn
41Yw8FCdcXUnRaeVLoSN0ts=
=pFbw
-----END PGP SIGNATURE-----
