No longer relevant to boat building so I've crossposted and set follow- ups. Thanks, r.b.b. guys! On Mar 19, 8:55*pm, cavelamb wrote: Fred the Red Shirt wrote: On Mar 19, 3:53 pm, cavelamb wrote: Fred the Red Shirt wrote: I'm looking at materials and techniques that would be useful for a homebuilt glider. ... I thought you have a set of Texas Parasol plans, Fred. Light and cheap techniques there. Yes *I do and have found no better (where 'better' is defined in terms of strong, light, fast, and not too expensive) way to make a fuselage. I think with composites I can make a lighter wing, considering that a glider wing will be longer, thinner and have a shorter chord than the TP wing. -- FF The traditional primaries were quite heavy. Think aluminum angle primary glider type fuselage and take the wing and tail from the Texas Parasol. The whole mess wouldn't weight 100 pounds. Cool! It needs to be under 150 to qualify as a FAR 103 UL glider. How much does one TP wing weigh? How much does the whole plane weigh, sans engine? A 12' SkyPup wing with a 52" chord and weighs about 26 pounds, but that has no drag spar or ailerons. The whole Pup weighs 205 lbs. -- FF |
No longer relevant to boat building so I've crossposted and set follow- ups. Thanks, r.b.b. guys! On Mar 19, 8:55 pm, cavelamb wrote: Fred the Red Shirt wrote: Cool! It needs to be under 150 to qualify as a FAR 103 UL glider. How much does one TP wing weigh? Last ones I built were about 35 pounds each, with ailerons. They could be 5 to 8 pounds lighter if it were important. Leave out the false ribs (and the foam false spar that supports them). How much does the whole plane weigh, sans engine? Bare airframe was about 40 pounds on the gear. But there is still a lot to add to that for a completed airplane. But if you were after a primary glider style airframe? I'd guess 50 pounds complete with single wheel. LOTS of wire... But wire is pretty light. -- FF -- Richard Lamb http://www.home.earthlink.net/~cavelamb/ |
Fred,
You might also want to take a look at Paper Dragon. Similar wing, but single tube tailboom. All zipped up for you. http://groups.yahoo.com/group/texasp...aper%20Dragon/ Richard |
On Mar 20, 1:46*pm, cavelamb wrote:
Fred, You might also want to take a look at Paper Dragon. Similar wing, but single tube tailboom. All zipped up for you. http://groups.yahoo.com/group/texasp...aper%20Dragon/ Thanks. That's a lot like one of Mike Sandlin's airchairs, only with an engine. Have you sen Marske's flying wings: http://www.continuo.com/marske/ He describes his method for using carbon fiber rods he http://www.continuo.com/marske/ARTIC...ods/carbon.htm and he http://www.marskeaircraft.com/carbonrod.html Meanwhile, on the subject of wire bracing, how is proper tension obtained on the wires? Are they terminated with a threaded fastener like a bicycle spoke? -- FF |
On Mar 20, 1:46 pm, cavelamb wrote: Fred, You might also want to take a look at Paper Dragon. Similar wing, but single tube tailboom. All zipped up for you. http://groups.yahoo.com/group/texasp...aper%20Dragon/ Thanks. That's a lot like one of Mike Sandlin's airchairs, only with an engine. Have you sen Marske's flying wings: http://www.continuo.com/marske/ He describes his method for using carbon fiber rods he http://www.continuo.com/marske/ARTIC...ods/carbon.htm and he http://www.marskeaircraft.com/carbonrod.html Meanwhile, on the subject of wire bracing, how is proper tension obtained on the wires? Are they terminated with a threaded fastener like a bicycle spoke? -- FF I like turnbuckles. But you can also just twist the wire. Twist with the lay to tighten, against to loosen. -- Richard Lamb http://www.home.earthlink.net/~cavelamb/ |
| 2-33 Questions | P. Corbett | Soaring | 0 | February 25th 07 06:46 PM |
| More IFR with VFR GPS questions | Chris Quaintance | Instrument Flight Rules | 58 | November 30th 05 09:39 PM |
| heater control for curing oven | [email protected] | Home Built | 27 | October 1st 05 08:03 PM |
| Mig-29 questions & general aviation questions 2003 | Steven | Military Aviation | 1 | October 20th 03 07:06 AM |
| Seven Questions For Michael Moore from a Blogger (was Questions for Mr. Bush, from Michael Moore) | Jim Yanik | Military Aviation | 2 | October 9th 03 10:36 PM |
