For a low wing aircraft with dual wing tanks, what is the point of
having a fuel selector valve. It seems to be a source of some fuel exhaustion caused accidents. Wouldn't it just be easier to feed off both simultaniously? |
![]() "Jay" wrote in message om... For a low wing aircraft with dual wing tanks, what is the point of having a fuel selector valve. It seems to be a source of some fuel exhaustion caused accidents. Wouldn't it just be easier to feed off both simultaniously? Because there's a fuel pump involved. If one tank goes dry, the pump sucks air. Easy experiment. Grab two straws. Stick one in a glass of water and let the other one stay outside the glass and try to drink from them. There are a few low wing planes with "BOTH" positions on the selector, but they drain to a common tank and the pump draws singly from there. |
![]() "Ron Natalie" wrote: For a low wing aircraft with dual wing tanks, what is the point of having a fuel selector valve. It seems to be a source of some fuel exhaustion caused accidents. Wouldn't it just be easier to feed off both simultaniously? Because there's a fuel pump involved. If one tank goes dry, the pump sucks air. Easy experiment. Grab two straws. Stick one in a glass of water and let the other one stay outside the glass and try to drink from them. There are a few low wing planes with "BOTH" positions on the selector, but they drain to a common tank and the pump draws singly from there. ++++++++++++++++++++++++++++++++++ Not true of the Ercoupe I once owned. Header tank was common to both wing tanks. Fuel was pumped from BOTH wing tanks to that common tank and then gravity fed to the engine. When the common tank was full, the excess was gravity fed to the left tank. Some other Coupes returned fuel to the right tank. Both tanks were connected together, so fuel would balance out... eventually. Barnyard BOb -- |
I'll second that!!!
I flew a Beech Skipper (yea, I know but I was young.) that used a ON-Off selector instead of selecting a wing tank. Right side tank always went low first (1/4 tank) before the left tank would show 3/4's of a tank left. Mechanic was top notch, but with all his efforts (short of installing a non-certified part) it only got marginally better. Even flying with the left wing high did not improve things. Bart -- Bart D. Hull Tempe, Arizona Check http://www.inficad.com/~bdhull/engine.html for my Subaru Engine Conversion Check http://www.inficad.com/~bdhull/fuselage.html for Tango II I'm building. RobertR237 wrote: In article , (Jay) writes: For a low wing aircraft with dual wing tanks, what is the point of having a fuel selector valve. It seems to be a source of some fuel exhaustion caused accidents. Wouldn't it just be easier to feed off both simultaniously? In theory, Yes it would be easier to feed off both simultaniously but the reality is that it wouldn't happen that way. It will always pull from the tank giving the least resistance and, when that tank ran out of fuel, it would continue to try and pull from it until you contacted the ground. The only way to guarantee a fairly equal use from both wings is to switch the lead from the tanks on a regular basis. In addition, the balanced use of fuel from each tank will help keep the plane from having a heavy wing. Bob Reed www.kisbuild.r-a-reed-assoc.com (KIS Builders Site) KIS Cruiser in progress...Slow but steady progress.... "Ladies and Gentlemen, take my advice, pull down your pants and Slide on the Ice!" (M.A.S.H. Sidney Freedman) |
Yes. My Velocity has a 5 gal header tank hard-plumbed to the two wing
tanks. The two wing tanks self-level within a gallon or two during normal flight (and sitting in the hanger). A pick-up tube in the header tank goes off to the fuel system thru one on/off valve that remains always on. Can't get much simpler than that. Sid Knox Velocity N199RS Starduster N666SK KR2 N24TC W7QJQ For a low wing aircraft with dual wing tanks, what is the point of having a fuel selector valve. It seems to be a source of some fuel exhaustion caused accidents. Wouldn't it just be easier to feed off both simultaniously? |
Fuel Drip Containment | Sven | Home Built | 28 | October 27th 03 10:28 PM |
Yo! Fuel Tank! | Veeduber | Home Built | 15 | October 25th 03 02:57 AM |
Pumping fuel backwards through an electric fuel pump | Greg Reid | Home Built | 15 | October 7th 03 07:09 PM |
Fuel pressure Problems | smf | Home Built | 3 | September 7th 03 08:25 PM |
Question ~ Does fuel injection add weight? | Barnyard BOb -- | Home Built | 0 | July 6th 03 09:47 PM |
