I am pleased to announce IGC-approval of the Nano GNSS Flight
recorder from LXNAV d.o.o., with effect from 31 August 2010. This follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code and the Specification for IGC-approved GNSS Flight Recorders. The IGC-approval document will appear on the IGC GNSS web site shortly, together with the manufacturer's DLL file for use with the IGC Shell program for the Validation of IGC files produced by this type of recorder. This brings the number of IGC-approved recorders to 47 types, from 19 different manufacturers. For details of all existing IGC-approval documents, see: http://www.fai.org/gliding/system/fi...proved_frs.pdf By clicking the link "List of IGC-approved FRs" a PDF document will be produced with: (1) a table of all types of IGC-approved Flight Recorders, (2) a table of Manufacturers, (3) a list of all IGC-approval activity since 1996, and (4) a short history of IGC GNSS Flight Recording. An updated version of this PDF document adding the new IGC- approval has been sent to the webmaster and will also appear shortly. However, please note that it has been found that the links to the individual IGC-approval documents in the tables in the above PDF document do not work in Internet Explorer. Links have therefore been added to the bottom of the page when you first go to: http://www.fai.org/gliding/gnss Regards to all glider pilots, and good soaring (as it was in the UK yesterday!), Ian Strachan Chairman IGC GFA Committee |
Użytkownik Ian Strachan napisał:
I am pleased to announce IGC-approval of the Nano GNSS Flight recorder from LXNAV d.o.o., with effect from 31 August 2010. Looks very promising. The big question is pricing... -- WojtuÅ›.net |
On Sep 1, 5:40Â*am, Wojciech Scigala wrote:
Użytkownik Ian Strachan napisał: I am pleased to announce IGC-approval of the Nano GNSS Flight recorder from LXNAV d.o.o., with effect from 31 August 2010. Looks very promising. The big question is pricing... -- Wojtuś.net Wings and Wheels hs it advertised for $595. |
On Sep 1, 3:48*am, Ian Strachan wrote:
I am pleased to announce IGC-approval of the Nano GNSS Flight recorder from LXNAV d.o.o., with effect from 31 August 2010. This follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code and the Specification for IGC-approved GNSS Flight Recorders. The IGC-approval document will appear on the IGC GNSS web site shortly, together with the manufacturer's DLL file for use with the IGC Shell program for the Validation of IGC files produced by this type of recorder. This brings the number of IGC-approved recorders to 47 types, from 19 different manufacturers. For details of all existing IGC-approval documents, see: http://www.fai.org/gliding/system/fi...proved_frs.pdf By clicking the link "List of IGC-approved FRs" a PDF document will be produced with: (1) a table of all types of IGC-approved Flight Recorders, (2) a table of Manufacturers, (3) a list of all IGC-approval activity since 1996, and (4) a short history of IGC GNSS Flight Recording. An updated version of this PDF document adding the new IGC- approval has been sent to the webmaster and will also appear shortly. However, please note that it has been found that the links to the individual IGC-approval documents in the tables in the above PDF document do not work in Internet Explorer. Links have therefore been added to the bottom of the page when you first go to:http://www.fai.org/gliding/gnss Regards to all glider pilots, and good soaring (as it was in the UK yesterday!), Ian Strachan Chairman IGC GFA Committee awesome! Seems to me that if the bluetooth connection is good enough on this box it could make a really great no wire portable IGC logger. |
On Sep 1, 6:11*am, Tony wrote:
On Sep 1, 3:48*am, Ian Strachan wrote: I am pleased to announce IGC-approval of the Nano GNSS Flight recorder from LXNAV d.o.o., with effect from 31 August 2010. This follows test and evaluation by the IGC GNSS Flight Recorder Approval Committee (GFAC) in accordance with Annex B to the Sporting Code and the Specification for IGC-approved GNSS Flight Recorders. The IGC-approval document will appear on the IGC GNSS web site shortly, together with the manufacturer's DLL file for use with the IGC Shell program for the Validation of IGC files produced by this type of recorder. This brings the number of IGC-approved recorders to 47 types, from 19 different manufacturers. For details of all existing IGC-approval documents, see: http://www.fai.org/gliding/system/fi...proved_frs.pdf By clicking the link "List of IGC-approved FRs" a PDF document will be produced with: (1) a table of all types of IGC-approved Flight Recorders, (2) a table of Manufacturers, (3) a list of all IGC-approval activity since 1996, and (4) a short history of IGC GNSS Flight Recording. An updated version of this PDF document adding the new IGC- approval has been sent to the webmaster and will also appear shortly. However, please note that it has been found that the links to the individual IGC-approval documents in the tables in the above PDF document do not work in Internet Explorer. Links have therefore been added to the bottom of the page when you first go to:http://www.fai.org/gliding/gnss Regards to all glider pilots, and good soaring (as it was in the UK yesterday!), Ian Strachan Chairman IGC GFA Committee awesome! *Seems to me that if the bluetooth connection is good enough on this box it could make a really great no wire portable IGC logger.- Hide quoted text - - Show quoted text - next generation will have the logger and PDA/PNA type display all in one package. After that why not include a phone and camera. Ah..... the iLogger! Can't wait! WO |
Dan wrote:
next generation will have the logger and PDA/PNA type display all in one package. You mean, like Altair and LX8000? History repeating... ;-) Max |
IGC-approval for Nielsen Kellerman ClearNav GNSS Flight Recorder | Ian Strachan | Soaring | 2 | May 26th 09 03:45 PM |
New IGC-approval for GNSS Flight Recorder | Ian Strachan | Soaring | 0 | February 14th 09 08:00 PM |
IGC-approval document issued for NT Easy GNSS recorder | Ian Strachan | Soaring | 0 | January 10th 07 09:31 PM |
Date of effect now 1 April 2004 for revised IGC-approval for certain legacy types of GNSS flight recorder | Ian Strachan | Soaring | 56 | December 2nd 03 08:08 AM |
New and updated IGC-approval documents for GNSS Flight Recorders | Ian Strachan | Soaring | 0 | November 25th 03 05:55 PM |
