TE probe up or down?
Old September 26th 10, 09:13 PM posted to rec.aviation.soaring
kirk.stant
Default TE probe up or down?
It's raining at the field today so here is a serious soaring question
to ponder:
Should the end of the TE probe on the fin point up or down?
Informal surveys at recent contests seem to show a slight preference
for up (not counting those "swingers" that go both ways).
I've heard all sorts of reasons why each orientation is best - angle
of attack during pull-ups, airflow in front of the tail, G-effects on
the air column, blah blah blah...
I point mine up so I don't snag it when taking off the tail dolly!
Comments?
Kirk
Wet in IL
Old September 26th 10, 09:53 PM posted to rec.aviation.soaring
Dave Nadler
to ponder:
Comments?
Kirk
Wet in IL
Up. as far awat from effects of the wing (and tail) as possible.
Except on some sailplanes where down works better.
See ya, Dave "YO electric"
Old September 26th 10, 09:57 PM posted to rec.aviation.soaring
johngalloway[_2_]
to ponder:
Comments?
Kirk
Wet in IL
From Rudy Brozel's classic article on total energy:
"The head of the probe should be as close as possible to the plane of
symmetry of the horizontal tail plane. The smaller the vertical
offset, the less the elevator affects the variometer. A vertical
distance over half the depth of the horizontal tail plane is very
bad!"
http://www.nadler.com/sn10/Brozel_TE...n_20020510.pdf
John Galloway
Old September 26th 10, 10:56 PM posted to rec.aviation.soaring
Brad[_2_]
to ponder:
Comments?
Kirk
Wet in IL
bad!"
John Galloway
if I have mine up (which I prefer) it gets close to the plane the
pitot tube is in..................would that possible disrupt the flow
for the pitot?
Brad
Old September 26th 10, 11:28 PM posted to rec.aviation.soaring
sisu1a
I thought it best to point it whichever direction will keep it as
perpendicular to the airstream it's reading from for as much of the
flight regime as possible, in an attempt to keep the flow within
+/-20deg to keep the probe from reading erroneously.
Mine points down, and is really short too! I have a cruciform
tail though, so I don't get probe envy since it's well clear of the
bow wake of the tailplane. In fact I prefer it this way and well...
at least my vario tells me size doesn't matter
-Paul
Old September 26th 10, 11:50 PM posted to rec.aviation.soaring
Andy[_1_]
to ponder:
Why be so limited in your thinking? What's wrong with sideways?
Then you can ponder which of those 2 options depending on you
thermalling direction preference.
I point mine up so I'm less likely to bend it.
Andy
Old September 27th 10, 05:29 AM posted to rec.aviation.soaring
Mike Ash
In article
to ponder:
Ironic how you accuse Kirk of limited thinking and yet you yourself use
a technique which gives you a mere four total options.
When the time comes to insert my TE probe, I get out my iPhone and have
it generate a random number in the range [0, 2pi). I then orient my TE
probe to the angle that this represents in radians. In this manner I
eliminate human bias and therefore increase thermalling performance.
Mike Ash
Radio Free Earth
Broadcasting from our climate-controlled studios deep inside the Moon
Old September 27th 10, 06:28 AM posted to rec.aviation.soaring
SoaringXCellence
Ah Ha! the new indicator of a worthless thread, Someone mentions an
iPhone app.
Old September 27th 10, 06:39 PM posted to rec.aviation.soaring
Mike Ash
In article
iPhone app.
It was the iPhone mention that bothers you, and not the claim that a
randomly-chosen angle improves thermalling performance by removing human
bias?
Mike Ash
Radio Free Earth
Old September 27th 10, 05:46 PM posted to rec.aviation.soaring
Tim Mara
Pete Russel (former SAGE Variometer maker) tested TE probes in all
directions..Pete reported it worked equally as well off to the left or right
as it did up or down....
if you can't decide, ESA has made for several years their DN/ST probes that
have both up and down ends.....all users have reported that these work
really very well...
see http://www.wingsandwheels.com/page20.htm
tim
"Andy" wrote in message
to ponder:
Andy
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 5483 (20100927) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
__________ Information from ESET NOD32 Antivirus, version of virus signature database 5483 (20100927) __________
http://www.eset.com
Ka-6 TE Probe vontresc Soaring 14 August 30th 08 04:17 AM
Probe problem smf Home Built 3 July 8th 07 02:29 PM
TE Probe on ASW-15 [email protected] Soaring 4 April 29th 07 02:43 AM
Multi - probe KP Soaring 1 March 7th 05 07:03 PM
TE-Probe for 1-26D Heinz Gehlhaar Soaring 6 January 17th 05 11:52 PM
