blue foam & cutting it
Old November 22nd 03, 10:16 AM
Richard Riley
Default blue foam & cutting it
On Sat, 22 Nov 2003 09:01:09 -0000, "karel adams"
:dear all,
:what is the blue foam around which composite parts are built?
:is it polyurethane? what brand names does it carry in europe?
It is absolutely NOT polyurethane. Polyurethane will release cyanide
gas if you try to hot wire it. DON'T.
It is Polystyrene foam, trade name Styrofoam by Dow chemical. The
form usually used in homebuilding is PI (Pipe Insulation) Billets, or
FB (Fabrication Billet) or BB (Bouyancy Billets), made by Dow. The BB
is a little ligher and weaker than the PI or FB, which are the same
thing. The PI's come in 8x16x104 inch blocks, or, lately, 10x20x104.
Don't use white EPB (Expanded Polystyrene Bead) board, often sold for
insulation, or used to make molded foam things like cheap ice chests.
You can recognise it because if you break it, it looks like it's made
from thousands of tiny round beads fused together. That's exactly
what it is. It's chemically the same, and you can hot wire it, but
it's not nearly as strong in flex or tension.
Here are a couple of halfway decent primmers on hotwiring
http://www.info-central.org/construction_hotwire.shtml
http://www.spacemodeling.org/new/how_to/Foam_Cutter.htm
Note - you don't have to use nichrome wire. I've used .020 stainless
safety wire, and titanium MIG wire with good results.
Old November 22nd 03, 05:13 PM
Lpmcatee356
Thank you! That was as extensive an answer as one could wish for!
I have found the local importer for Dow and sent them e-mail...
Karel
Hingene (BE)
I don't know what the situation is like in your country, but here in the USA we
don't tell the Dow rep that we are going to use the foam for airplanes. If we
do they won't sell it to us.
I build lots of boat docks and boats G
Old November 23rd 03, 05:24 PM
Nathan Young
"karel adams" wrote in message ...
dear all,
also, where can i find a description of how to build
an electrically heated cutting wire for the same?
Aircraft Spruce sells a book discussing 'Moldess Composite
Construction'. This book was written by Burt Rutan. They also sell a
'kit' comprised of foam, various fiberglass weaves, and epoxy. I used
this to build a few test wings and learned a lot in the process.
(Including a deep hatred for sanding).
Going from memory... The cutter used in the book is a long strip of
2"x2" with a 1/2" copper pipe snug fit into 1/2" holes in either end
of the 2"x2". A small hole is drilled through the ends of the copper
pipe, the cutting wire is fed through the holes, and looped a few
times around each pipe. Tension is applied to the cutting wire by
rotating the copper pipes (a bit like tensioning a guitar string).
I used a car battery and lightweight jumper cables (from a battery
charger) as the current source. Fasten one of the jumper cables to
the copper pipe on the cutting tool.
A variable resistance needs to be added in the path to control current
and hence the heat in the cutting element. For this, I used another 3
foot section of 2"x2" (attached to the workbench) with a wire strung
between two nails at either end. Connect the other jumper cable to
one end of the wire.
Connect a heavy-duty alligator clip to other copper pipe on the
cutting tool through a length of wire. Attaching the alligator clip
to resistance wire completes the circuit and allows current to flow.
This will cause the both the cutting wire and the resistance wire to
heat. Current can be adjusted by moving the alligator clip in various
locations along the wire.
It is a bit of an art to select the right current for cutting. Too
hot and the foam will melt away, leaving divots and shriveled foam in
the cut. Too cold and the wire will not cut well - which will stretch
the wire and leave a cut that is not even.
Having said this - you can probably purchase a better assembly
(Aircraft Spruce?) than you can build. Or borrow one - talk to your
local EAA chapter - if anyone has built an EZ - then they should have
a foam cutter.
-Nathan
Foam BD5ER Home Built 17 September 20th 03 05:07 PM
blue foam, pink foam, yellow foam? Corrie Home Built 26 September 1st 03 06:01 PM
