Go Back   Home » AviationBanter forum » rec.aviation newsgroups » General Aviation
AVIATIONTOOLBOX: automatic route selection
Old October 14th 04, 02:08 AM
Kyler Laird
Default AVIATIONTOOLBOX: automatic route selection
I've been asked to help write some code to assist in flight planning
by choosing routes. I have just enough Computer Science and IFR
background to make me dangerous. I said that I'd donate my effort
if it results in Free code the community can use. So we're making
this a community project.
Although this sounds like a fairly simple task, performed by DUAT(S)
and IFR students daily, there are a lot of complexities and I suspect
that there are lots of opportunities for the community to optimize
the process. Here's are some of my thoughts to kick around.
All the data we need should be in the FAA ATA-100 collection.
http://aviationtoolbox.org/old/ATA-100/
Flights will mostly be along airways.
http://aviationtoolbox.org/old/ATA-1...ats/Awy_rf.txt
Preferred routes should be used when possible.
http://aviationtoolbox.org/old/ATA-1...ats/Pfr_rf.txt
Transitions between airports and airways will be handled with
standard arrival and departure procedures when possible.
http://aviationtoolbox.org/old/ATA-1.../Stardp_rf.txt
Here's a simple-minded algorithm with lots of holes to fill.
Provide start and end airports and altitude
restrictions.
Get started with a standard departure or create one.
Use preferred route or create one using least cost
(mileage) routing. There are 20,757 airways.
Finish using a standard approach or create one.
So...suggestions?
Thank you.
--kyler
Old October 14th 04, 02:24 AM
Paul Tomblin
restrictions.
So...suggestions?
I started playing around with this idea years ago before when I was going
to write an on-line flight planner. (That was an idea I started work on
and then abandoned, and then a year or two later when I discovered CoPilot
I decided that this was a better use of all the FAA data I had collected.)
What I thought I'd do for the first cut at the algorithm was:
Find every VOR that's within "X" degrees of a straight line between
the start and end
At that VOR
- Find every VOR that's within "X" degrees of a straight line between
that VOR and the end point.
- Continue iterating until there are no VORs between you and the end
point.
When you have all your candidate routes, throw away any that don't
have airways between the VOR. Maybe make an exception if the distance is
less than "Y". Sort from shortest to longest.
Obviously that needs some work to handle DPs and STARs and preferred
routes.
Paul Tomblin http://xcski.com/blogs/pt/
Today Has Been Two Of Those Days.
-- Mike Andrews
Old October 14th 04, 02:59 AM
Matt Whiting
restrictions.
So...suggestions?
the start and end
At that VOR
point.
routes.
I'd think some of the approaches taught in any good operations research
course would be much better. It's been 20+ years since I took my last
OR course, but I'd look into a good OR text before writing code. There
a much better methods than a brute force, exhaustive search approach.
Matt
Old October 14th 04, 05:44 AM
Ben Jackson
I keep meaning to apply Dijkstra's algorithm to airway routing.
The key will be choosing edge costs.
You can do this all with appropriate costs assigned to the routes and
transitions that you want. The tricky part is weighting thoses costs
properly against whatever you consider to be overriding factors (eg
forecast winds, icing, aircraft performance, distance, available nav
equipment, ...)
Ben Jackson
http://www.ben.com/
Old October 14th 04, 10:47 AM
Julian Scarfe
"Ben Jackson" wrote in message
news:tCmbd.121529$He1.75934@attbi_s01...
I tried something similar for Western Europe. Thinking aloud... My
algorithm was basically:
a) load the entire airway network as a graph using distances as costs
b) link airports to the network using SIDs and STARs (important in Europe,
probably less so in US)
c) add preferred routes using the a cost of
start_to_end_great_circle_distance * factor, where factor is just less than
1.
d) run Dijkstra's algorithm (I was doing this in Perl so I just used the
Graph module from CPAN) for a departure airport
e) store the least cost routing from the departure airport to everywhere
else in a database
Repeat for other departure airports of interest. Processing time for one
departure airport for my network was about 30s on a fairly typical desktop
machine. YMMV, literally. ;-)
Provided your airway network only changes every 28 days (can't speak for the
US but that's what happens in the rest of the world for aeronautical data),
you've then got "static" routes valid for a month which means that to run
this for 100 airports or so, it should be a case of "do the calculation once
and store the results".
equipment, ...)
Adding dynamic issues is not only difficult from a "what cost factor do I
use?" point of view, but actually affects the entire strategy. Calculating
weighted factors based on winds means that you have to do a calculation for
the entire network (you may be able to preload the network, but you still
have to run a weighting factor calc for each edge) which is likely to be
very time consuming. You then have to run Dijkstra's algorithm to get the
least-cost routes. But now we're doing that for *every* flight, which means
that we wait for both steps of the processing (edge costs + Dijkstra)
instead of doing a database lookup on stuff that's run once a month.
I wondered about a middle ground. If you could store the 10 or even 100
least-cost routes for a particular airport-pair, then running those routes
for a single flight would be relatively quick (either individually or doing
Dijkstra on the much reduced network). But Dijkstra doesn't produce the
runners up, only the winner, so how do we find the set of 10 or 100 routes
to consider? Do you knock out legs and run the algorithm again? If so,
which ones?
Reducing the network to waypoints within x miles of the great circle for a
particular flight (a little like Paul Tomblin's suggestion) is one
possibility, but, at least in Europe, x would have to be pretty big. On a 3
hour trip to Germany from my home base in the UK, I basically have the
choice between an initial route that goes east over Holland, or south and
then south east over Belgium. For a 450 mile route, I have to consider a
band of possibilities at least 150 miles wide.
Anyway, just sharing some thinking.
Julian Scarfe
Old October 14th 04, 04:08 PM
Kyler Laird
"Julian Scarfe" writes:
That was my first thought...'course it's about all I remember about
network theory...
What's the difficulty here? The airway file contains distances.
Are we not treating airways as the network edges?
1.
Hmmmm...I like that. It would allow for lots of tweaking too.
else in a database
I wasn't planning to do a lot of precomputation. When we get into altitude
restrictions it just gets too complicated. The shortest path for me from
Indiana to California is going to be much different than for someone who is
going to stay below 8,000'. Besides altitude restrictions, I can imagine
wanting to specify avoidance of MOAs, long overwater segments, busy
airspace, etc.
the entire network
Oh, yeah...winds too.
It's not clear to me that this is a terrible burden. A student
sitting in front of enroute charts can figure out reasonable solutions
so I assume I can program a computer to do the same in short order.
I think that learning to disregard edges that aren't of interest is
the key. This seems fairly simple at first but in mountainous regions
with low altitude restrictions it could get difficult because you might
need to go far away from a direct route.
This doesn't sound so bad to me. I don't have a grasp on the power
required to solve it though.
Indeed! I appreciate the thoughts!
--kyler
Old October 14th 04, 04:16 PM
Dave Butler
I always got stuck at trying to find a reasonable choice for the node at which
the enroute structure should be entered and exited. Once you pick the end points
(where to enter and leave) the choice of routes is just an OR optimization
problem, as others have noted.
Perhaps altitude requirements need to be included in the costs.
Dave
Old October 14th 04, 08:50 PM
Ben Jackson
I think you can do better than that by ordering your edges better. You
know more than just edge costs, you also have coordinates for each node.
You can choose to explore edges that move you closer to the destination
first.
IIRC, the key to making Dijkstra fast is to find a solution as early as
possible. That establishes a baseline cost that allows massive pruning
of the search space.
Right. But if I'm going to do the work then I want it to calculate all
of the factors that I would, given infinite time and patience on my part.
Ben Jackson
http://www.ben.com/
Old October 15th 04, 10:11 AM
Julian Scarfe
desktop
news:rTzbd.249118$D%.142632@attbi_s51...
first.
That may be the case. I should have said that what I was trying to do was
create a server-based system for large numbers of users with different
dep-dest pairs. In that case, I'm looking at all potential destinations in
parallel. The strategy for a client-based system starting from scratch for
every single flight might be rather different.
Julian
Old October 20th 04, 04:56 PM
Jerry Kaidor
"Julian Scarfe" wrote in message ...
*** I would modify that to use a combination of distance and MEA as
the cost.
I've found that in my personal flight planning, lower MEAs often
translate into a better flight, even if they involve a bit of a
dogleg.
- Jerry Kaidor ( )
AVIATIONTOOLBOX: automatic route selection Kyler Laird Instrument Flight Rules 19 October 22nd 04 08:02 PM
NAS and associated computer system Newps Instrument Flight Rules 8 August 12th 04 06:12 AM
filing IFR plan for VFR flight conditions Paul Safran Instrument Flight Rules 53 May 11th 04 04:07 AM
AVIATIONTOOLBOX: alpha version of route mapping tool Kyler Laird General Aviation 0 January 1st 04 10:21 PM
