Retrofitting diesels on existing airplanes doesn't make much sense in the
US, where the fuel cost differences between 100LL and Jet-A are relatively small. However, using diesels on new airplanes makes a lot of sense. If you look at the price of a Diamond plane in Europe, the diesel version is actually about $5,000 cheaper than the same airplane with a Lycoming engine. For less money, you get better mileage and FADEC. For an FBO or a flying club, that has a lot of pilots putting a lot of hours on their airplanes, saving money on gas, and potentially saving on maitnenance because pilots are not over-leaning or shock cooling the engines, could make a BIG difference in the operating costs of the planes. Mike Schumann "Thomas Borchert" wrote in message ... They are pricey now (although still lots cheaper than turbines) They are? You consider 40,000 $ one-time retrofit cost on a 172 and 20,000 $ replacement cost after 2400 hours (with a full guarantee for those 2400 hours) expensive, compared to your average Lycoming with Pete knows how many top overhauls until TBO? I'm not sure... -- Thomas Borchert (EDDH) |
"Mike Schumann" writes:
potentially saving on maitnenance because pilots are not over-leaning or shock cooling the engines, could make a BIG difference in the operating costs of the planes. You might have that backwards: students (and renters) tend to run overrich, not overlean, at least from what I've heard. It's the overrich operation that does the damage (fouled plugs, stuck valves, etc.). Does anyone have an actual report of an engine being damaged by overlean operation? It would be interesting to read. The only danger I can think of would be running lean far above 75% power and causing detonation, though vibration from an extremely rough-running engine could also do something nasty. All the best, David -- David Megginson, , http://www.megginson.com/ |
David,
You might have that backwards: students (and renters) tend to run overrich, not overlean, at least from what I've heard. It's the overrich operation that does the damage (fouled plugs, stuck valves, etc.). The point is: Students, renters and pilots in general shouldn't have to worry about this 30s-era-stuff. I wouldn't have believed how convenient the one-lever operation of a Thielert diesel is until I flew the Diamond Star TDI. It is great: That one lever isn't even connected mechanically to the engine. There are engine instruments, but the only one that really matters is the "percent power" gauge. Everything else is handled by the computers - even if you slam the throttly forward hamfistedly, they will accelerate (sp?) the engine as gently as makes sense from a mechanical standpoint. -- Thomas Borchert (EDDH) |
Thomas Borchert wrote in message ...
Rj, Thoughts? Have you heard of the D-Jet by Diamond? Thomas, Yes I have, although it's useful load looks like it will be less than my Bonanza. (That shouldn't be a taken as a slight to Diamond--a company that knows how to deliver a good product, on time). What the GA aircraft industry really needs is to rethink the now dated migration path from complex singles. The old way was to advance to a light twin. If you look at the insurance and accident data, moving to a faster/higher (maybe turbine powered) single is probably the better answer. Somehow the affordability gap has to narrow, so a $300K complex driver isn't staring at a $2M take it or leave it choice. RJ |
Rj,
what I like about the D-Jet concept is that it will be a turbine, but it will be restricted to 25,000 feet, so it really is the most similar of the light jets to a "normal" piston engine single. They avoid all sorts of problems by that restriction. -- Thomas Borchert (EDDH) |
And at $40k for the engine, cowling mod's etc. VERY Steep $$$!!
-- Thx, {|;-) Victor J. (Jim) Osborne, Jr. take off my shoes to reply |
Jr.,
And at $40k for the engine, cowling mod's etc. VERY Steep $$$!! 40k$ includes everything firewall forward and behind (throttle, ECU et cetera) -- Thomas Borchert (EDDH) |
Mike,
agreed on all points! -- Thomas Borchert (EDDH) |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | June 2nd 04 07:17 AM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | May 1st 04 07:29 PM |
Homebuilt Aircraft Frequently Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | April 5th 04 03:04 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
Homebuilt Aircraft Frequently-Asked Questions (FAQ) | Ron Wanttaja | Home Built | 0 | July 4th 03 04:50 PM |
