Anyone happen to have these two NTSB regs handy? I'm reviewing for my BFR
on Monday (haven't been flying for about 5 years) and haven't been able to access the NTSB site (www.ntsb.gov?). Thanks. |
![]() "Mike Noel" wrote in message ... Anyone happen to have these two NTSB regs handy? I'm reviewing for my BFR on Monday (haven't been flying for about 5 years) and haven't been able to access the NTSB site (www.ntsb.gov?). Thanks. 830.5 Immediate notification. The operator of any civil aircraft, or any public aircraft not operated by the Armed Forces or an intelligence agency of the United States, or any foreign aircraft shall immediately, and by the most expeditious means available, notify the nearest National Transportation Safety Board (Board) field office \1\ when: (a) An aircraft accident or any of the following listed incidents occur: (1) Flight control system malfunction or failure; (2) Inability of any required flight crewmember to perform normal flight duties as a result of injury or illness; (3) Failure of structural components of a turbine engine excluding compressor and turbine blades and vanes; (4) In-flight fire; or (5) Aircraft collide in flight. (6) Damage to property, other than the aircraft, estimated to exceed $25,000 for repair (including materials and labor) or fair market value in the event of total loss, whichever is less. (7) For large multiengine aircraft (more than 12,500 pounds maximum takeoff weight); (i) In-flight failure of electrical systems which requires the sustained use of an emergency bus powered by a backup source such as a battery, auxiliary power unit, or air driven generator to retain flight control or essential instruments; (ii) In-flight failure of hydraulic systems that results in sustained reliance on the sole remaining hydraulic or mechanical system for movement of flight control surfaces; (iii) Sustained loss of the power or thrust produced by two or more engines; and (iv) An evacuation of an aircraft in which an emergency egress system is utilized. (b) An aircraft is overdue and is believed to have been involved in an accident. \1\ The Board field offices are listed under U.S. Government in the telephone directories of the following cities: Anchorage, AK, Atlanta, GA, West Chicago, IL, Denver, CO, Arlington, TX, Gardena (Los Angeles), CA, Miami, FL, Parsippany, NJ (metropolitan New York, NY), Seattle, WA, and Washington, DC. 830.15 Reports and statements to be filed. (a) Reports. The operator of a civil, public (as specified in Sec. 830.5), or foreign aircraft shall file a report on Board Form 6120.1/2 (OMB No. 3147-0001) \2\ within 10 days after an accident, or after 7 days if an overdue aircraft is still missing. A report on an incident for which immediate notification is required by Sec. 830.5(a) shall be filed only as requested by an authorized representative of the Board. (b) Crewmember statement. Each crewmember, if physically able at the time the report is submitted, shall attach a statement setting forth the facts, conditions, and circumstances relating to the accident or incident as they appear to him. If the crewmember is incapacitated, he shall submit the statement as soon as he is physically able. (c) Where to file the reports. The operator of an aircraft shall file any report with the field office of the Board nearest the accident or incident. \2\ Forms are available from the Board field offices (see footnote 1), from Board headquarters in Washington, DC, and from the Federal Aviation Administration Flight Standards District Offices. |
Thanks Ron. I spent two hours in the air and two hours on the ground today
and am back in business. Mike at AVQ "Ron Natalie" wrote in message m... "Mike Noel" wrote in message ... Anyone happen to have these two NTSB regs handy? I'm reviewing for my BFR on Monday (haven't been flying for about 5 years) and haven't been able to access the NTSB site (www.ntsb.gov?). Thanks. 830.5 Immediate notification. The operator of any civil aircraft, or any public aircraft not operated by the Armed Forces or an intelligence agency of the United States, or any foreign aircraft shall immediately, and by the most expeditious means available, notify the nearest National Transportation Safety Board (Board) field office \1\ when: (a) An aircraft accident or any of the following listed incidents occur: (1) Flight control system malfunction or failure; (2) Inability of any required flight crewmember to perform normal flight duties as a result of injury or illness; (3) Failure of structural components of a turbine engine excluding compressor and turbine blades and vanes; (4) In-flight fire; or (5) Aircraft collide in flight. (6) Damage to property, other than the aircraft, estimated to exceed $25,000 for repair (including materials and labor) or fair market value in the event of total loss, whichever is less. (7) For large multiengine aircraft (more than 12,500 pounds maximum takeoff weight); (i) In-flight failure of electrical systems which requires the sustained use of an emergency bus powered by a backup source such as a battery, auxiliary power unit, or air driven generator to retain flight control or essential instruments; (ii) In-flight failure of hydraulic systems that results in sustained reliance on the sole remaining hydraulic or mechanical system for movement of flight control surfaces; (iii) Sustained loss of the power or thrust produced by two or more engines; and (iv) An evacuation of an aircraft in which an emergency egress system is utilized. (b) An aircraft is overdue and is believed to have been involved in an accident. \1\ The Board field offices are listed under U.S. Government in the telephone directories of the following cities: Anchorage, AK, Atlanta, GA, West Chicago, IL, Denver, CO, Arlington, TX, Gardena (Los Angeles), CA, Miami, FL, Parsippany, NJ (metropolitan New York, NY), Seattle, WA, and Washington, DC. 830.15 Reports and statements to be filed. (a) Reports. The operator of a civil, public (as specified in Sec. 830.5), or foreign aircraft shall file a report on Board Form 6120.1/2 (OMB No. 3147-0001) \2\ within 10 days after an accident, or after 7 days if an overdue aircraft is still missing. A report on an incident for which immediate notification is required by Sec. 830.5(a) shall be filed only as requested by an authorized representative of the Board. (b) Crewmember statement. Each crewmember, if physically able at the time the report is submitted, shall attach a statement setting forth the facts, conditions, and circumstances relating to the accident or incident as they appear to him. If the crewmember is incapacitated, he shall submit the statement as soon as he is physically able. (c) Where to file the reports. The operator of an aircraft shall file any report with the field office of the Board nearest the accident or incident. \2\ Forms are available from the Board field offices (see footnote 1), from Board headquarters in Washington, DC, and from the Federal Aviation Administration Flight Standards District Offices. |
Hendricks Crash- NTSB Prelim | C Kingsbury | Instrument Flight Rules | 10 | November 14th 04 02:18 AM |
Single-Seat Accident Records (Was BD-5B) | Ron Wanttaja | Home Built | 41 | November 20th 03 05:39 AM |
