Hi,
I wonder whether the lift over resistance coefficient diagram (aka polar diagram or lilienthal diagram) of a given airplane changes much with altitude. The rationale behind the question is, that I read somewhere, that commercial aircraft are flying in the so called "coffin corner", that is so high they can't go faster because of compression and can't go slower because of stall. Why should they do this, when they could well be a little lower and comfortly fly at the point of optimal angle of access, well away from stall. Do optimal point and stall point come closer together with increasing height? |
"dominik lenné" wrote in
: Hi, I wonder whether the lift over resistance coefficient diagram (aka polar diagram or lilienthal diagram) of a given airplane changes much with altitude. The rationale behind the question is, that I read somewhere, that commercial aircraft are flying in the so called "coffin corner", that is so high they can't go faster because of compression and can't go slower because of stall. Why should they do this, when they could well be a little lower and comfortly fly at the point of optimal angle of access, well away from stall. Do optimal point and stall point come closer together with increasing height? Are you sure you are refering to commercial aircraft ? sure sounds as if you thinking of the U-2 with its VERY narrow flight envelope at close to max. |
On Feb 11, 5:50*pm, John Szalay john.szalayATatt.net wrote:
"dominik lenné" wrote : Hi, I wonder whether the lift over resistance coefficient diagram (aka polar diagram or lilienthal diagram) of a given airplane changes much with altitude. The rationale behind the question is, that I read somewhere, that commercial aircraft are flying in the so called "coffin corner", that is so high they can't go faster because of compression and can't go slower because of stall. Why should they do this, when they could well be a little lower and comfortly fly at the point of optimal angle of access, well away from stall. Do optimal point and stall point come closer together with increasing height? *Are you sure you are refering to commercial aircraft ? sure sounds as if you thinking of the U-2 with its VERY narrow flight envelope at close to max.- Hide quoted text - - Show quoted text - Glider pilots talk alot about polar curves. The peak is the best L/ D point. Lift is proportional to mass flow over the wings so thin air (up high) and slow speed reduce lift. Drag decreases with thin air, partially compensating. I'm not aware that any commerical flight would be allowed to operate at a level where this makes a difference. Plus, Class-A air space does not extend above FL600. |
| Thread Tools | |
| Display Modes | |
| High on Final, Summary; was Polar with spoilers extended? | Steve Leonard | Soaring | 4 | October 27th 07 08:22 AM |
| Discus polar curve at high speeds | [email protected] | Soaring | 12 | December 20th 05 02:59 AM |
| High altitude & RPM | abripl | Home Built | 1 | September 1st 05 01:12 AM |
| Polar diagram for Mosquito? | Dave Boulter | Soaring | 9 | February 2nd 05 08:07 PM |
| High-altitude autorotations? | Bill McClain | Military Aviation | 17 | March 15th 04 05:23 PM |
