I am looking for an axle for a PIK 20 trailer, or something that is
similar. If you have one or have any ideas of where to find one I would be much obliged. Thanks, Taylor |
At 05:14 08 April 2011, Taylor Drake wrote:
I am looking for an axle for a PIK 20 trailer, or something that is similar. If you have one or have any ideas of where to find one I would be much obliged. Thanks, Taylor Good luck with that; I had to put a new, American-made axle under my trailer and I have no brakes on the trailer as a result. One consolation is that the wheels are 4 inches farther apart and it trails better. |
trailer and I have no brakes on the trailer as a result. *One consolation is that the wheels are 4 inches farther apart and it trails better. You should have upgraded to electric brakes if you changed your axle and still wanted brakes without braking the bank. They are superior in every measurable category except they req a controller installed in the towing vehicle. You also could have gotten the exact size you want, since they are sold in every track width and you have the mounting pads welded at custom locations based on your provided specs. I like the Torflex axle, it's a torsion type with independent suspension and makes single axle trailers drive reeeaalll nice, custom made for a scant $160. Sounds like you had unhelpful people 'helping' you with your trailer. Glad it sorta worked in your favor at least... -Paul |
On Apr 8, 8:18*am, sisu1a wrote:
Good luck with that; I had to put a new, American-made axle under my trailer and I have no brakes on the trailer as a result. *One consolation is that the wheels are 4 inches farther apart and it trails better. You should have upgraded to electric brakes if you changed your axle and still wanted brakes without braking the bank. They are superior in every measurable category except they req a controller installed in the towing vehicle. You also could have gotten the exact size you want, since they are sold in every track width and you have the mounting pads welded at custom locations based on your provided specs. I like the Torflex axle, it's a torsion type with independent suspension and makes single axle trailers drive reeeaalll nice, custom made for a scant $160. Sounds like you had unhelpful people 'helping' you with your trailer. Glad it sorta worked in your favor at least... -Paul Forgot to mention that the Dexter had that electric brake option I opted for looks like the Torflex does also. Most all US made vehicles that have towing packs already have the wiring for the electric brake module it's pretty much plug and play. |
At 15:18 08 April 2011, sisu1a wrote:
Good luck with that; I had to put a new, American-made axle under my trailer and I have no brakes on the trailer as a result. =A0One consolati= on is that the wheels are 4 inches farther apart and it trails better. You should have upgraded to electric brakes if you changed your axle and still wanted brakes without braking the bank. They are superior in every measurable category except they req a controller installed in the towing vehicle. You also could have gotten the exact size you want, since they are sold in every track width and you have the mounting pads welded at custom locations based on your provided specs. I like the Torflex axle, it's a torsion type with independent suspension and makes single axle trailers drive reeeaalll nice, custom made for a scant $160. Sounds like you had unhelpful people 'helping' you with your trailer. Glad it sorta worked in your favor at least... -Paul I was on the road trailering to Marfa several years ago, trapped in a bad situation, and the only help I could get was at an 18-wheeler repair facility. They drove me 20 miles to a place where I could buy an axle and new wheels. It was a sad, sad story. |
Assuming that Taylor is in the USA...
Another source is Axle, Inc of Elkhart Indiana. They build Hayes leaf spring or Alko torsion bar suspension axles to your spec. Electric or hydraulic brake option. Bear in mind that neither electric nor hydraulic have a simple parking brake, like the European mechanical brake systems. http://www.axleinc.com/id2.html If the mounting dimensions are the same as the newer Cobra trailer axles, those are in stock at Williams Soaring, with mechanical brakes. Newer being the ones with a single-piece floor, slightly wider than the multi-piece ribbed floor models. http://www.williamssoaring.com/catalog/cobra.html Jim |
On Apr 8, 9:30*am, JS wrote:
Assuming that Taylor is in the USA... * Another source is Axle, Inc of Elkhart Indiana. They build Hayes leaf spring or Alko torsion bar suspension axles to your spec. Electric or hydraulic brake option. Bear in mind that neither electric nor hydraulic have a simple parking brake, like the European mechanical brake systems.http://www.axleinc.com/id2.html * If the mounting dimensions are the same as the newer Cobra trailer axles, those are in stock at Williams Soaring, with mechanical brakes. Newer being the ones with a single-piece floor, slightly wider than the multi-piece ribbed floor models.http://www.williamssoaring.com/catalog/cobra.html Jim On my Dexter axle they had an option for a mechanical parking brake lever coming out of each drum which I modified the parking lever or should I say the linkage under the trailer added a cable to the levers. So when I park and drop the trailer, lever over and it holds quite nice. See page 7 on the PDF below. http://dexteraxle.com/i/u/1080235/f/..._Lbs_12-10.pdf |
On Apr 7, 10:14*pm, Taylor Drake wrote:
I am looking for an axle for a PIK 20 trailer, or something that is similar. *If you have one or have any ideas of where to find one I would be much obliged. Thanks, Taylor I put a Dexter axle on my Cobra. They offer a 1000kg (2200lb) torsional axle seems it was about $650 + wheels were about $40 ea. That's considering you're in the USA |
G-103 Axle | Roger Fowler[_2_] | Soaring | 5 | December 21st 10 07:44 PM |
International Shipping (trailer axle) | T8 | Soaring | 6 | February 3rd 10 10:46 PM |
Cobra trailer axle | Pete Dawson | Soaring | 1 | August 15th 09 01:49 AM |
ASK 21 in Cobra trailer single or double axle? | Karaka | Soaring | 7 | June 19th 09 10:15 PM |
Cobra Trailer - U.S. Axle? | Mitch | Soaring | 8 | March 2nd 07 09:16 PM |
