Hello,
How safe is Eclipse Aviaion's decision to expose the wheel on jet that cruises at 41,000 feet? Has this been done before? On what airplane? |
In article , stephen
wrote: Hello, How safe is Eclipse Aviaion's decision to expose the wheel on jet that cruises at 41,000 feet? Has this been done before? On what airplane? What difference does it make how high the airplane flies? The Cessna Citation has had exposed wheels since it was developed in the late 60's/early 70's. |
On Sat, 06 Dec 2003 02:31:24 GMT, EDR wrote:
In article , stephen wrote: Hello, How safe is Eclipse Aviaion's decision to expose the wheel on jet that cruises at 41,000 feet? Has this been done before? On what airplane? What difference does it make how high the airplane flies? The Cessna Citation has had exposed wheels since it was developed in the late 60's/early 70's. I think he's asking about either excess tire pressure bursting the tire or the tire expanding and getting stuck in the wheel well. Some sort of variation on the question comes up a couple to times a year here. The answer is usually that no, the maximum pressure differential is about 15 psi, which is trivial for a tire. Don |
![]() "Don Tuite" wrote in message ... On Sat, 06 Dec 2003 02:31:24 GMT, EDR wrote: In article , stephen wrote: Hello, How safe is Eclipse Aviaion's decision to expose the wheel on jet that cruises at 41,000 feet? Has this been done before? On what airplane? What difference does it make how high the airplane flies? The Cessna Citation has had exposed wheels since it was developed in the late 60's/early 70's. I think he's asking about either excess tire pressure bursting the tire or the tire expanding and getting stuck in the wheel well. Some sort of variation on the question comes up a couple to times a year here. The answer is usually that no, the maximum pressure differential is about 15 psi, which is trivial for a tire. Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. They are filled with dry nitrogen. |
In a previous article, "Tom" said:
Some sort of variation on the question comes up a couple to times a year here. The answer is usually that no, the maximum pressure differential is about 15 psi, which is trivial for a tire. Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. They are filled with dry nitrogen. Yes, and at sea level it's pushing against 15 psi, and in vacuum they're pushing against nothing, which means the maximum pressure differential between ground and cruise is 15 psi. -- Paul Tomblin http://xcski.com/blogs/pt/ "We choose to go to the moon in this decade and do the other things, not because they are easy, but because they are hard...." - John F Kennedy |
![]() "Paul Tomblin" wrote in message ... In a previous article, "Tom" said: Some sort of variation on the question comes up a couple to times a year here. The answer is usually that no, the maximum pressure differential is about 15 psi, which is trivial for a tire. Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. They are filled with dry nitrogen. Yes, and at sea level it's pushing against 15 psi, and in vacuum they're pushing against nothing, which means the maximum pressure differential between ground and cruise is 15 psi. Your math doesn't add up (how cliche' ) |
![]() "Paul Tomblin" wrote in message ... In a previous article, "Tom" said: Some sort of variation on the question comes up a couple to times a year here. The answer is usually that no, the maximum pressure differential is about 15 psi, which is trivial for a tire. Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. They are filled with dry nitrogen. Yes, and at sea level it's pushing against 15 psi, and in vacuum they're pushing against nothing, which means the maximum pressure differential between ground and cruise is 15 psi. I believe he's talking about the differential between the air in the tires and the outside air. |
Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. Apparently, another "sorry" would be in order. What he's saying is that the difference between sea level and outer space is only around 15psi, which is PROBABLY an almost insignificant fraction of the pressure usually existing inside a properly inflated tire. Besides, it doesn't make any difference if the wheel is behind a wheel well door if it is still not in the pressure vessel of the fuselage. An extrapolation of this discussion: the tires on the Space Shuttles. To the best of my knowledge, they stay inflated the whole time, even in near zero pressure on orbit. David Sproul, Bethesda, MD |
![]() "DaveSproul" wrote in message ... differential is about 15 psi, which is trivial for a tire. Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. Apparently, another "sorry" would be in order. What he's saying is that the difference between sea level and outer space is only around 15psi, which is PROBABLY an almost insignificant fraction of the pressure usually existing inside a properly inflated tire. I suppose that he could be saying THAT! I figured he was addressing the outside/inside air pressure. This group is not known for high literacy content :~) |
![]() "Tom" wrote in message ... Sorry, but the tires on a Citation are inflated to 120 +/- PSI on the nose wheel and 98 PSI on the mains. They are filled with dry nitrogen. Not maximum pressure, maximum pressure differential. Normal sea level pressure is about 14.7 psi. |
more radial fans like fw190? | jt | Military Aviation | 51 | August 28th 04 04:22 AM |
Hiroshima/Nagasaki vs conventional B-17 bombing | zxcv | Military Aviation | 55 | April 4th 04 07:05 AM |
VW-1 C-121J landing with unlocked nose wheel | Mel Davidow LT USNR Ret | Military Aviation | 1 | January 19th 04 05:22 AM |
Ta-152H at low altitudes | N-6 | Military Aviation | 16 | October 13th 03 03:52 AM |
The Little Wheel in Back | Veeduber | Home Built | 6 | September 8th 03 10:29 AM |
