We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago,
we began to notice the engine to be rough on the right magneto during run-up. Over two weeks, it became increasingly difficult to burn it off by leaning during the run-up, until one day when it became impossible. We noticed on the engine monitor that the #5 cylinder head temp was cold during the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug which was replaced. Now, about 15 hours later (and an annual), we have the same problem with the #5 cylinder. It's going back to the shop today. Any ideas? Why the same cylinder? What should we be looking for? |
![]() David R. wrote: We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago, we began to notice the engine to be rough on the right magneto during run-up. Over two weeks, it became increasingly difficult to burn it off by leaning during the run-up, until one day when it became impossible. We noticed on the engine monitor that the #5 cylinder head temp was cold during the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug which was replaced. Now, about 15 hours later (and an annual), we have the same problem with the #5 cylinder. It's going back to the shop today. Any ideas? Why the same cylinder? What should we be looking for? Bad plug, bad mag or bad spark plug wire. |
What was fouling it? Oil? Carbon? Lead?
Lots of different answers depending on what the cause was. Rich David R. wrote: We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago, we began to notice the engine to be rough on the right magneto during run-up. Over two weeks, it became increasingly difficult to burn it off by leaning during the run-up, until one day when it became impossible. We noticed on the engine monitor that the #5 cylinder head temp was cold during the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug which was replaced. Now, about 15 hours later (and an annual), we have the same problem with the #5 cylinder. It's going back to the shop today. Any ideas? Why the same cylinder? What should we be looking for? |
I'm not sure, but i think he said it was carbon.
"Rich" wrote in message ... What was fouling it? Oil? Carbon? Lead? Lots of different answers depending on what the cause was. Rich David R. wrote: We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago, we began to notice the engine to be rough on the right magneto during run-up. Over two weeks, it became increasingly difficult to burn it off by leaning during the run-up, until one day when it became impossible. We noticed on the engine monitor that the #5 cylinder head temp was cold during the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug which was replaced. Now, about 15 hours later (and an annual), we have the same problem with the #5 cylinder. It's going back to the shop today. Any ideas? Why the same cylinder? What should we be looking for? |
"David" wrote
I'm not sure, but i think he said it was carbon. You likely have a cylinder running too rich. First off, are you leaning for taxi? You should be - and I mean leaning to the point where you can't advance the throttle to runup power without killing the engine. Second - do you have a carbureted engine or an injected one? If carbureted, not much you can do besides leaning, but if it's injected, the injectors come in several sizes and you can go to a narrower bore injector. Of course it could be lots of other reasons as well. Bad plug, bad contact in the mag, bad wire - but all those things cost money to fix. Leaning costs nothing, so you should try that first. Michael |
Yes, we are aggressively leaning before taxi.
Thanks for the info. "Michael" wrote in message m... "David" wrote I'm not sure, but i think he said it was carbon. You likely have a cylinder running too rich. First off, are you leaning for taxi? You should be - and I mean leaning to the point where you can't advance the throttle to runup power without killing the engine. Second - do you have a carbureted engine or an injected one? If carbureted, not much you can do besides leaning, but if it's injected, the injectors come in several sizes and you can go to a narrower bore injector. Of course it could be lots of other reasons as well. Bad plug, bad contact in the mag, bad wire - but all those things cost money to fix. Leaning costs nothing, so you should try that first. Michael |
![]() "David R." wrote in message ... We have a 1979 Cessna 182RG with 1350 hours since overhaul. 6 weeks ago, we began to notice the engine to be rough on the right magneto during run-up. Over two weeks, it became increasingly difficult to burn it off by leaning during the run-up, until one day when it became impossible. We noticed on the engine monitor that the #5 cylinder head temp was cold during the run-up. Our mechanic looked at it, and yep, it was a fouled spark plug which was replaced. Now, about 15 hours later (and an annual), we have the same problem with the #5 cylinder. It's going back to the shop today. Any ideas? Why the same cylinder? What should we be looking for? Bad cylinder, bad valve guides, bad plugs, bad wires -- all possibilities. |
We had a similar problem except the plug was getting fouled with oil. We
had a crack piston ring. |
How do you diagnose a cracked piston ring? Scope? Compressions?
"Kevin Chandler" wrote in message ... We had a similar problem except the plug was getting fouled with oil. We had a crack piston ring. |
I have no idea. I did not do it. The A&P made the call and got it right.
A new/used jug fixed it all. "David R." wrote in message ... How do you diagnose a cracked piston ring? Scope? Compressions? "Kevin Chandler" wrote in message ... We had a similar problem except the plug was getting fouled with oil. We had a crack piston ring. |
Compression loss on cylinder when rings line up Truth of fiction? | test it | Home Built | 10 | May 11th 04 08:11 PM |
O-200 Cylinder Repair | jls | Home Built | 3 | February 29th 04 02:45 AM |
Cylinder Wrenches for 0-320A Narrow Deck | DAVE | Home Built | 1 | December 31st 03 01:45 PM |
Stick Shake When Firing Guns | John Kunkel | Military Aviation | 17 | October 2nd 03 12:39 AM |
'Hot' cylinder after overhaul? | Tony Cox | Owning | 8 | August 10th 03 07:25 PM |
