Many people have asked me why I have generators on my airplane rather
than converting to alternators. My airplane is a PA-30. The only legal alternator conversion is the InterAv STC. This is a non-redundant conversion - the alternators used require power to the field and the regulators use interruptor relays. Thus if the battery or master contactor fails, both alternators will immediately go offline. No gear, no flaps, no lights - all from a single point failure. Unacceptable in a serious night/IFR machine. Generators, of course, ground the field. Even if the battery or master contactor fails, the generators keep going. The voltage will fluctuate and some avionics may die, but some (especially the modern uncertified ones with good power supplies) should keep working, and of course flaps, gear, and lights will never know the difference. An old-time pilot told me I was wrong - that the generator system was also non-redundant due to the paralleling relay. But of course even if that fails, you can still run on one generator, I replied. No, he told me - it can fail and make the whole airplane dark. I never understood how - until it happened. For those not familiar with the paralelling relay, here's how it works. It's actually two relays, each hooked to the armature line of a generator. When both generators are making power, both relays close. When they do, they allow current to flow between the paralelling coils of the voltage regulators, balancing the load. At other times, the voltage regulators are fully conventional. The design is actually 1940's tractor technology. At the time, generators were simply not built to handle 100 ampere loads. When one particularly large tractor was built that needed 100 amps, the designers had a choice - design an oversize generator (with all the tooling this involved) or find a way to make two stock generators work together. They chose the latter. Redundancy was never the issue. Piper took this design and transplanted it wholesale into the PA-30. We pay a lot of money in certification costs to ensure that designs are not simply lifted from industrial equipment and modified willy-nilly. There is supposed to be failure analysis and such. Of course this is the FAA running the show, so that doesn't happen. Really, I blame myself for trusting the certification process. I should never have assumed that just because the FAA certified it the design made sense for an airplane - and it doesn't. You see, the design was not really lifted wholesale. Circuit breakers were added to each generator - after the regulator. It was the worst possible place. No circuit breakers would have been better - but the FAA wouldn't certify that. The proper place to have them would have been in the armature line - but that's not where piper put them. Generators have more than one failure mode. They can fail off, but they can also fail in an overvolt/overamp condition. This occurs when, for whatever reason, the field line shorts to the case. This can occur if the technician assembling the generator is a little sloppy in soldering in the feedthrough for the field. A little solder goes over the side. However, the inside of the case is painted, so the solder is covered with an insulator. When the generator is assembled, the through bolt shouldn't touch the feedthrough anyway - but the clearance is tiny. Over time, and with vibration, the paint can wear away. At first the field will short intermittently, but eventually the short can become permanent. The PA-30 is not normally equipped with a voltmenter, so there is no chance of catching the problem while it is still intermittent. Even when it becomes permanent, the only indication will be battery overcharge. Since the ammeter is of the +/- 0-100 amp variety, noticing a 10-20 amp charging current isn't trivial. It's also not that hard to exceed 50 amps on the bus at that voltage. Normally the paralelling relay would distrbute the load, but since the field on the generator is shorted, it will take all or most of it. The breaker will pop. Of course if the plane is equipped with a voltmeter, the pilot will likely notice the overvolt condition (as I did). The pilot will then troubleshoot, and realize that even turning off both field switches will not solve the problem. He will then attempt to resolve the problem by pulling generator breakers, and will quickly identify the misbehaving generator, pull its breaker, turn off its field switch (which accomplishes precisely nothing) and use the other generator to complete the flight. Either way (whether the breaker pops or the pilot pulls it) the outcome is the same (minus any damage to avionics). Because the breaker is downstream of the regulator, the armature from the misbehaving generator is still delivering juice to the paralelling relay. Thus the relay is attempting to parallel the working generator (which is now carrying the entire load) and the idling generator with the shorted field. THERE IS NO CURRENT LIMIT THROUGH THE PARALELLING RELAY! There is no fuse, no breaker, nothing. In short order, the voltage regulator coils will be fried, and both generators will go offline. However, it can be even worse. As the regulator on the still-normal generator begins to malfunction, this regulator will deliver an overcurrent. This can weld the contactor shut. Then, when the field goes offline, the armature will short the battery to ground, putting about a 40 amp load on the battery. This, in addition to the normal load, will discharge the battery in short order unless the pilot pulls the other generator circuit breaker. Did I mention that these live under a floor panel? Go ahead, ask me how I know... The fix is simple. Add a fuse to the paralelling line (and a switch would be better) and move the circuit breakers to the armature lines where they belong. Now what are the chances the FAA will let me do it? Michael |
![]() Michael wrote: Now what are the chances the FAA will let me do it? Don't ask. Don't tell. George Patterson A diplomat is a person who can tell you to go to hell in such a way that you look forward to the trip. |
In article , "G.R. Patterson III"
writes: Now what are the chances the FAA will let me do it? Don't ask. Don't tell. Forgiveness is sometimes easier to get than permission. If caught, seek forgiveness. Chuck |
