Hello Mike,
FYI I the later Garmins (I believe that includes the 196) will record flight tracks with Altitude, the Lowrance 500 and 1000 will not. I find the 3D track very useful for: 1) Aesthetic dimension for plots of our flights to give to friends that we've given rides to. E.g. if you use http://www.gpsvisualizer.com it will color-code the track according to your altitude. 2) Instrument training. Plotting your track directly onto the approach plate. How well was I holding altitude or glidepath? E.g. http://f2.pg.photos.yahoo.com/ph/cra...&.dnm=a4c5.jpg 3) Evaluating engine/airplane performance. Leisurely after-the-fact evaluation of climb-rate. Also, when did the wheels leave the runway on those short-field takeoffs? Where was I when I cleared that 50' obstacle? And how does that compare to book? This has become more important to me since I fly with a CS prop, I've had a bit of engine trouble lately, and I occasionally fly out of a 2600' grass strip in the Texas Hill Country (that's NOT the place I want to find out that my engine is not putting out max hp!) E.g. http://f2.pg.photos.yahoo.com/ph/cra...&.dnm=1d24.jpg Cheers, John Clonts Temple, Texas N7NZ |
Please excuse me for cross posting. There are two separate
discussions going on about the Lowrance Airmap 1000. Mike, I just bought an Airmap 1000. I placed a pirep over on rec. aviation.piloting last night. I've never flown with a 195 or 196. It sounds like they are very nice, but cost more than I wanted to pay. I used to have an Airmap 100 and liked it for the intuitive interface. I'm a vfr pilot and use the Lowrance obstruction database often. As of yet I haven't used the AM 1000 unit to it's full capabilities and still have much to learn. It is very easy to use but is much more configurable than the 100. It came with a MapCreate CD set to add even more detail to the charts. It has a full phone book and poi, (places of interest) search feature. It came with a suction cup RAM mount and a RAM yoke mount. I never have had much luck with the suction cup mounts and the yoke mount would've worked but I actually used the old Airmap 100 yoke mount because it positioned the unit further away from me when the yoke was pulled fully back. It was also at a better angle and didn't interfere with anything on the panel. Battery life is said to be about 12 hours at the normal settings. There are battery saver settings that can extend that time but decrease position accuracy and update frequency. If you have found the 1000 for $625, then that is a good buy. I paid $725. I probably should have waited until Sun and Fun to see if prices dropped more but I'm so spoiled by my old unit that I consider a backup gps a potential safety of flight issue. Unfortunately, I was going to load the Map Create software on my computer and play with it today but I found that the CD set they shipped me has two of the same East coast CD so I'll have to check their customer service to see if they'll make it right. Jay Honeck says he's disappointed in the Lowrance support because they dropped the 300. I never had to use their support until now, so we'll see what happens. Lowrance has a downloadable AM 1000 simulator on their website. Garmin may have one as well if you'd like to fly before you buy. To me it boils down to how much do you have to spend and what features are most important to you. Joe Schneider Cherokee 8437R "Mike Spera" wrote in message ... Thanks for everyone's replies on the 195 vs. 196 question. Went in to look over a Garmin 196 and also looked at the Lowrance unit. I found that every advertisement for the 196 showed every page EXCEPT a map. Curious, I thought. When I called up the map page on the 196, I found it to be difficult to read. Played around with the contrast and such, but it still never looked quite "right". Maybe it was because I was inside a store that had pretty dim lighting. I probably should have spent more time with various decluttering options. Anyway, I set it down and started up the Lowrance unit and was surprised that it was MUCH easier to read. Even with the same level of detail (aka "clutter"), the Lowrance was easier to read. Well, it IS a bigger screen. I then played around with the various menus, pages, features etc. on both units without cracking open either manual. I figure that any piece of computer equipment that requires you to read the manual to get at its basic functions is not worth my investment. Curiously, again, the Lowrance unit was a bit easier to navigate. Remember, I am currently using a 10 year old unit. For better or worse, the Lowrance unit seems more aligned with my old Apollo. There is a higher similarity of the actual buttons and what they accomplish. But, the Lowrance will not do the "turn by turn" street navigation that the Garmin will do (once you pay the stiff additional $250 for the "kit"). But, the Lowrance appeared to go down to the street level for many cities right out of the box, the Garmin does not do this without the "kit". So, I could use the Lowrance to find my way around on the ground, but it will not do the turn by turn navigation. I would have to pan around the map and make up a plan. Am I correct on this? I really want to buy a quality unit because I will probably keep it for a LOOOOOOONG time. I also don't want to cheap out and buy a "second string" unit. The Lowrance unit can be had for about $625, the Garmin is $875 without the additional street kit. In aviation, I have learned that less expensive is usually not a better value. I know that Garmin has a rock solid reputation for quality units and support. Can the same be said of Lowrance? I lost GPS lock on my old Apollo about 3 times in the last 7 years, and this was only for about 10-15 seconds. I use the external antenna tossed up on the top of the glareshield (unsecured). How will the Garmin and Lowrance units do under similar usage? The Garmin mount looked much better than the Lowrance. Also, the Garmin unit snaps in and out of the mount, the Lowrance causes you to back off the screws, or back off the main socket extension to get it out. I never leave the unit in the plane when it is tied down over night. Even though I have my doubts, and the Lowrance has some limitations, AND it is less expensive (not necessarily a "good" thing), I still LIKE the Lowrance. Anyone ever use both of these units and can compare them? Thanks again, Mike __________________________________________________ ____________________ _________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
dropped the 300. A bit more precisely, I'm disappointed because they dropped their *support* of the Airmap 300, after just 48 months. When the airport database in my 300 decided to no longer function, Lowrance informed me that they could not fix the problem. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
Jay,
Hmm. Their website at http://www.lei-extras.com/store/search.asp shows current aviation database updates for the Airmap 300 available for 75 $ (single update, subscription is 61 $). Not sure what the problem is. -- Thomas Borchert (EDDH) |
current aviation database updates for the Airmap 300 available for 75 $ (single update, subscription is 61 $). Not sure what the problem is. My 300 will no longer recognize that -- or any other -- database. Without even looking at it, Lowrance diagnosed it as a "chip" problem. It's apparently a very common problem with the 300. They told me they can no longer obtain that particular chip. Thus, the 300 is orphaned. -- Jay Honeck Iowa City, IA Pathfinder N56993 www.AlexisParkInn.com "Your Aviation Destination" |
On Tue, 09 Mar 2004 19:57:10 GMT, "Jay Honeck"
wrote: They told me they can no longer obtain that particular chip. Thus, the 300 is orphaned. I have the 100. I found that the restore function was failing (it kept dropping routes). I finally figured it happened when ever certain VOR's were in the route. I reported it to Lowrance and got a reply that they confirmed the problem and would look into it. A couple of weeks later they sent me an email saying that aviation was not a big enough part of their revenue to make fixing it worthwhile. I am still using my Airmap 100, but my next GPS will not come from Lowrance. |
![]() I did make the leap and purchased the Airmap 1000. Had to wait one day for the next batch to get in stock. It was $675, not $625 as I had previously reported. Database updates are currently priced at $35, but you currently have to trade in your old SD Card for a replacement. They report that in about 3 weeks, they will be offering the database updates via download. Extended 1 year warrant was only $29. A bargain I thought. The big screen does allow for a lot of data to be displayed. I still find myself turning all but the aviation stuff "off". Don't really need the clutter of city names and interstates/roads. Although most new units allow for this control, I REALLY like the fact that the screen backlight can be dimmed WAY down. The old Apollo was too bright on its lowest (of TWO) settings. A feature(?) I was not aware of: as you approach a multi-runway airport and zoom in, not only do you get the runway layout with numbers, but the runway you are closest to aligning with "blinks" by bolding. Weird. The "split screen" was cool. One side has the map, the other has the destination (multi-runway) airport zoomed in so you can see the runways, numbers, and your current approach path. Although I was blessed with the ability to see this in my head, it confuses the heck out of my wife. So, she will REALLY appreciate this feature. Not sure if I will use the funky RAM yoke mount that came with it. I have a brand new spare Quick Clamp that was used for the old Apollo unit. It is simply a yoke clamp, large adjusting Y bolt, and angled aluminum bracket with 2 Velcro strips on the face. You put the matching Velcro strips on the back of your GPS and stick the thing on. Never once came loose and was easy to take off/put on. Well, on to the airport to give it a test. Thanks for all replies, Mike __________________________________________________ _____________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 - http://www.uncensored-news.com The Worlds Uncensored News Source |
