The outer ballast tanks use a fitting what I don't have. Is there an
off the shelf workaround? tuN7o |
For the outers, yes. I don't have mine in front of me, but it's just a rigid plastic fitting of thick walled pipe. It has a slight taper iirc, but it is a friction fit. A length of PVC with the right od would work.
At 01:05 03 September 2011, Tuno wrote:
The outer ballast tanks use a fitting what I don't have. Is there an off the shelf workaround? tuN7o probably not, it's a tapered tube - the taper end is rammed into the hole in the wing and suitable supply of water applied to the other end. Find someone who has one and turn down a suitable thick walled tube to match the taper. |
![]() "Peter Wyld" wrote in message . com... probably not, it's a tapered tube - the taper end is rammed into the hole in the wing and suitable supply of water applied to the other end. Find someone who has one and turn down a suitable thick walled tube to match the taper. Schedule 80 PVC pipe or electrical conduit of an appropriate diameter would likely be a good material to make that from. It may not be a retail item, but is redily available at a wholesale plumbing or electrical supply. Alternatively, you might get lucky enough that the bell end cut from a length of ordinary PVC pipe would serve. Vaughn |
On Sep 2, 6:05*pm, Tuno wrote:
The outer ballast tanks use a fitting what I don't have. Is there an off the shelf workaround? tuN7o If you are around Minden I can probably make you one if I have either the plane or fitting to look at. . . Or a diagram. Bumper |
Saturn V S-IC-T (static test stage) fuel tank assembly is mated to the liquid oxygen (LOX) tank 6416666.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:33 AM |
A different way to add filler (OA) | mhorowit | Home Built | 0 | September 14th 05 12:51 PM |
ASW-27B ballast tank ventilation | Andy Blackburn | Soaring | 3 | October 24th 04 05:31 PM |
Oil filler cap assy | Test | Home Built | 2 | January 23rd 04 01:38 PM |
GTAW / TIG filler material recommendations | Jari Kaija | Home Built | 8 | July 3rd 03 06:01 AM |
