I've put a little over 100 hours on my 150 since purchase in January
'03. Recently, I've begun oil analysis with Blackstone. The universal avg for copper on an O-200 is 9 ppm. My reading at 488 hrs on the engine was 18 ppm and my most recent reading at the last oil change is even higher at 25 ppm. I thought that the former 18 ppm was a byproduct of having all of my exhaust valve guides reamed. I did this because I was experience sticky valves. Reaming the exhaust valve guides has cured that and it was my best guess that doing that caused the 18 ppm reading. Now, I am getting 25 ppm in copper and there hasn't been any service on my engine. I cut the filter open and it's very clean. I know I'm not making metal. I'm a little worried but then I found this link: http://www.prime-mover.org/Engines/G...es/Copper.html I use Aeroshell 15w50 -and- I've been using TCP additive in my fuel as a lead scavenger. I'm no chemist but I think the TCP the article above refers to is the same or very similar chemical as Alcor TCP which I've been adding to my fuel. I plan to stop using the Alcor TCP and switch to a single weight oil and see what happens. Would you be worried with this reading? Does the article I linked to seem credible? I know it's not recent. Also, if TCP in the oil can leach copper, wouldn't it be able to get into the oil if used as a fuel additive? |
" wrote in message . ..
I've put a little over 100 hours on my 150 since purchase in January '03. Recently, I've begun oil analysis with Blackstone. The universal avg for copper on an O-200 is 9 ppm. My reading at 488 hrs on the engine was 18 ppm and my most recent reading at the last oil change is even higher at 25 ppm. I thought that the former 18 ppm was a byproduct of having all of my exhaust valve guides reamed. I did this because I was experience sticky valves. Reaming the exhaust valve guides has cured that and it was my best guess that doing that caused the 18 ppm reading. Now, I am getting 25 ppm in copper and there hasn't been any service on my engine. I cut the filter open and it's very clean. I know I'm not making metal. I'm a little worried but then I found this link: http://www.prime-mover.org/Engines/G...es/Copper.html I use Aeroshell 15w50 -and- I've been using TCP additive in my fuel as a lead scavenger. I'm no chemist but I think the TCP the article above refers to is the same or very similar chemical as Alcor TCP which I've been adding to my fuel. I plan to stop using the Alcor TCP and switch to a single weight oil and see what happens. Would you be worried with this reading? Does the article I linked to seem credible? I know it's not recent. Also, if TCP in the oil can leach copper, wouldn't it be able to get into the oil if used as a fuel additive? Copper is used in various places in your engine. All the rod and main bearings have it in their lay up. To get into the copper layer means there is extensive wear. That will show up as lower then normal oil pressure. The most likely source is the rocker arm bushing or the wrist pin bushings. If ya got 18 ppm of copper in the oil you will see it. Cutting open the filter will show larger pieces. Next time you change oil poir a little on a whote surface in the sunlight and you will definatly see gold sparkles in it.I assume they reamed the guides while the ctlinders were still on the motor. If they packed a little grease in the flutes of the reamer then most if not all the shaving were removed during this process. I would do another analysis and see if it is still going up. My bet it is the rocker bushing because they had to remove them to ream the guides and if it went back together a little dirty that would saw into the bushing a bit and give you an elevated reading. Ben Haas. |
Fwd: [BD4] Source of HIGH CHTs on O-320 and O-360 FOUND! | Bruce A. Frank | Home Built | 1 | July 4th 04 07:28 PM |
Choice of Paint for use over Copper foil Antennas | Charlie Precourt | Home Built | 1 | December 2nd 03 02:51 AM |
MT. DIABLO HIGH SCHOOL CONCORD, CA PHOTOS | MT. DIABLO HIGH SCHOOL PHOTOS | Home Built | 1 | October 13th 03 03:35 AM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
High Flight NOTAM | Kirk Stant | Military Aviation | 1 | September 10th 03 03:31 AM |
