Hi,
I recently bought a glider and it has a GPS-NAV unit with a GPS20 in it. It seemed to work fine when I bought it, but this weekend I powered it up and it comes up with a "GPS Fail Press ON Key". When I press the "ON" key, it just goes through the cycle again and comes back to the same page. It is running LCD version 5.3E, GPS version 6.0. The initial screens all look good including the internal battery voltage (3.0v). Any ideas or suggestions? Cheers, Morteza |
On 9/25/11 10:04 PM, Morteza Ansari wrote:
Hi, I recently bought a glider and it has a GPS-NAV unit with a GPS20 in it. It seemed to work fine when I bought it, but this weekend I powered it up and it comes up with a "GPS Fail Press ON Key". When I press the "ON" key, it just goes through the cycle again and comes back to the same page. It is running LCD version 5.3E, GPS version 6.0. The initial screens all look good including the internal battery voltage (3.0v). Any ideas or suggestions? Cheers, Morteza Almost certain to be cabling, corrosion, bent/abused pins in the telco connectors. Also RTFM for the Model 20 and make sure the LED on the Model 20 tells you it has a GPS signal/lock. Darryl |
On Sep 25, 11:13*pm, Darryl Ramm wrote:
On 9/25/11 10:04 PM, Morteza Ansari wrote: Hi, I recently bought a glider and it has a GPS-NAV unit with a GPS20 in it. It seemed to work fine when I bought it, but this weekend I powered it up and it comes up with a "GPS Fail *Press ON Key". When I press the "ON" key, it just goes through the cycle again and comes back to the same page. It is running LCD version 5.3E, GPS version 6.0. The initial screens all look good including the internal battery voltage (3.0v). Any ideas or suggestions? Cheers, Morteza Almost certain to be cabling, corrosion, bent/abused pins in the telco connectors. Also RTFM for the Model 20 and make sure the LED on the Model 20 tells you it has a GPS signal/lock. Darryl Thanks Darryl, I brought it home with me and now it does not show the same error message and seem to be working which is probably pointing to some sort of cabling problem. However, I also noticed that the DCE connection does not have the positive power coming out anymore. This is the cable that sends serial along with power to the PDA. I have been doing some reading and it seems model 20 can supply about 500mA of +5v. I am wondering if there is an internal fuse that is blown. Paul Remde's site has a note about a "resettable fuse" (http:// www.cumulus-soaring.com/goddard.htm) but I can't find any other references to it. Cheers, Morteza |
Hi Morteza,
The internal fuse resets itself when it cools down. Are you measuring the +5 V for the PDA across pins 8 (+5V) and 5 (common)? When you saw the error message, I'm assuming you saw that on the GPS-NAV LCD Navigation Display - is that correct? If so, and since it seems to be working better now, it could be (as Darryl suggested) a cable issue. Or the GPS engine could be dead or dying. You may want to contact Gary Kammerer at www.clearnav.net. Best Regards, Paul Remde Cumulus Soaring, Inc. "Morteza Ansari" wrote in message ... On Sep 25, 11:13 pm, Darryl Ramm wrote: On 9/25/11 10:04 PM, Morteza Ansari wrote: Hi, I recently bought a glider and it has a GPS-NAV unit with a GPS20 in it. It seemed to work fine when I bought it, but this weekend I powered it up and it comes up with a "GPS Fail Press ON Key". When I press the "ON" key, it just goes through the cycle again and comes back to the same page. It is running LCD version 5.3E, GPS version 6.0. The initial screens all look good including the internal battery voltage (3.0v). Any ideas or suggestions? Cheers, Morteza Almost certain to be cabling, corrosion, bent/abused pins in the telco connectors. Also RTFM for the Model 20 and make sure the LED on the Model 20 tells you it has a GPS signal/lock. Darryl Thanks Darryl, I brought it home with me and now it does not show the same error message and seem to be working which is probably pointing to some sort of cabling problem. However, I also noticed that the DCE connection does not have the positive power coming out anymore. This is the cable that sends serial along with power to the PDA. I have been doing some reading and it seems model 20 can supply about 500mA of +5v. I am wondering if there is an internal fuse that is blown. Paul Remde's site has a note about a "resettable fuse" (http:// www.cumulus-soaring.com/goddard.htm) but I can't find any other references to it. Cheers, Morteza |
On Sep 26, 4:35*am, "Paul Remde" wrote:
Hi Morteza, The internal fuse resets itself when it cools down. *Are you measuring the +5 V for the PDA across pins 8 (+5V) and 5 (common)? When you saw the error message, I'm assuming you saw that on the GPS-NAV LCD Navigation Display - is that correct? *If so, and since it seems to be working better now, it could be (as Darryl suggested) a cable issue. *Or the GPS engine could be dead or dying. *You may want to contact Gary Kammerer atwww.clearnav.net. Best Regards, Paul Remde Cumulus Soaring, Inc. "Morteza Ansari" wrote in message ... On Sep 25, 11:13 pm, Darryl Ramm wrote: On 9/25/11 10:04 PM, Morteza Ansari wrote: Hi, I recently bought a glider and it has a GPS-NAV unit with a GPS20 in it. It seemed to work fine when I bought it, but this weekend I powered it up and it comes up with a "GPS Fail Press ON Key". When I press the "ON" key, it just goes through the cycle again and comes back to the same page. It is running LCD version 5.3E, GPS version 6.0. The initial screens all look good including the internal battery voltage (3.0v). Any ideas or suggestions? Cheers, Morteza Almost certain to be cabling, corrosion, bent/abused pins in the telco connectors. Also RTFM for the Model 20 and make sure the LED on the Model 20 tells you it has a GPS signal/lock. Darryl Thanks Darryl, I brought it home with me and now it does not show the same error message and seem to be working which is probably pointing to some sort of cabling problem. However, I also noticed that the DCE connection does not have the positive power coming out anymore. This is the cable that sends serial along with power to the PDA. *I have been doing some reading and it seems model 20 can supply about 500mA of +5v. I am wondering if there is an internal fuse that is blown. Paul Remde's site has a note about a "resettable fuse" (http://www.cumulus-soaring.com/goddard.htm) but I can't find any other references to it. Cheers, Morteza Hi Paul, Thanks for the reply. Yes, the error was on the GPS-NAV display. It has been working on the bench at home and eve after quite a few power cycles no error messages have come up. With that said, pin 8 is not supplying the +5v, so the PDA is not working. I am wondering if the "resettable fuse" you talked about on your web page is in need of resetting! Cheers, Morteza |
Hi Morteza,
The fuse should not need resetting. It resets itself when it cools down. If it isn't supplying 5V power then it must have been damaged and probably needs repair. Please contact Gary Kammerer at www.clearnav.net. Best Regards, Paul Remde Cumulus Soaring, Inc. "Morteza Ansari" wrote in message ... On Sep 26, 4:35 am, "Paul Remde" wrote: Hi Morteza, The internal fuse resets itself when it cools down. Are you measuring the +5 V for the PDA across pins 8 (+5V) and 5 (common)? When you saw the error message, I'm assuming you saw that on the GPS-NAV LCD Navigation Display - is that correct? If so, and since it seems to be working better now, it could be (as Darryl suggested) a cable issue. Or the GPS engine could be dead or dying. You may want to contact Gary Kammerer atwww.clearnav.net. Best Regards, Paul Remde Cumulus Soaring, Inc. "Morteza Ansari" wrote in message ... On Sep 25, 11:13 pm, Darryl Ramm wrote: On 9/25/11 10:04 PM, Morteza Ansari wrote: Hi, I recently bought a glider and it has a GPS-NAV unit with a GPS20 in it. It seemed to work fine when I bought it, but this weekend I powered it up and it comes up with a "GPS Fail Press ON Key". When I press the "ON" key, it just goes through the cycle again and comes back to the same page. It is running LCD version 5.3E, GPS version 6.0. The initial screens all look good including the internal battery voltage (3.0v). Any ideas or suggestions? Cheers, Morteza Almost certain to be cabling, corrosion, bent/abused pins in the telco connectors. Also RTFM for the Model 20 and make sure the LED on the Model 20 tells you it has a GPS signal/lock. Darryl Thanks Darryl, I brought it home with me and now it does not show the same error message and seem to be working which is probably pointing to some sort of cabling problem. However, I also noticed that the DCE connection does not have the positive power coming out anymore. This is the cable that sends serial along with power to the PDA. I have been doing some reading and it seems model 20 can supply about 500mA of +5v. I am wondering if there is an internal fuse that is blown. Paul Remde's site has a note about a "resettable fuse" (http://www.cumulus-soaring.com/goddard.htm) but I can't find any other references to it. Cheers, Morteza Hi Paul, Thanks for the reply. Yes, the error was on the GPS-NAV display. It has been working on the bench at home and eve after quite a few power cycles no error messages have come up. With that said, pin 8 is not supplying the +5v, so the PDA is not working. I am wondering if the "resettable fuse" you talked about on your web page is in need of resetting! Cheers, Morteza |
I'm seeing this myself now. I'll check the cables thoroughly and perhaps make new ones. Thanks for posting Morteza.
Cambridge 302 Problem - Help | Leroy Tire | Soaring | 2 | August 8th 10 05:05 PM |
Cambridge 302 problem..HELP Please | Colin Milner | Soaring | 0 | July 20th 09 07:15 PM |
Cambridge 302 problem..HELP Please | Robert Holliday | Soaring | 11 | June 25th 09 02:15 PM |
Cambridge 302 problem..HELP Please | Andy[_10_] | Soaring | 2 | June 24th 09 09:21 PM |
Cambridge 302 problem: "Could not get FAT.(A)" while trying to download flight logs | Jason Armistead | Soaring | 5 | July 13th 03 02:36 PM |
