On the last two flights, the needle on my 302 stopped moving. Cycling
the power didn't bring the needle to life, but the everything else continued to work: audio, slow/fast arrows, averager, MC setting, GPS. The first flight, it began moving again after a half hour or so; on the second flight, it didn't start working again until I tried it again about an hour after I landed. Is there fix for this besides sending it back to Cambridge? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
If you don't want to use the flight recorder, you could open it up and
reseat the inter-board connectors (using contact cleaner sparingly). Strip and reassembly is not difficult with care. If you want to use the flight recorder for any claim/competition then opening kills the electronic seal, so it needs to go to the factory (or approved repair agent outside the US) anyway after fixing. At 04:22 23 October 2011, Eric Greenwell wrote: On the last two flights, the needle on my 302 stopped moving. Cycling the power didn't bring the needle to life, but the everything else continued to work: audio, slow/fast arrows, averager, MC setting, GPS. The first flight, it began moving again after a half hour or so; on the second flight, it didn't start working again until I tried it again about an hour after I landed. Is there fix for this besides sending it back to Cambridge? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Oct 23, 10:36*am, Peter Purdie wrote:
If you don't want to use the flight recorder, you could open it up and reseat the inter-board connectors (using contact cleaner sparingly). *Strip and reassembly is not difficult with care. If you want to use the flight recorder for any claim/competition then opening kills the electronic seal, so it needs to go to the factory (or approved repair agent outside the US) anyway after fixing. At 04:22 23 October 2011, Eric Greenwell wrote: On the last two flights, the needle on my 302 stopped moving. Cycling the power didn't bring the needle to life, but the everything else continued to work: audio, slow/fast arrows, averager, MC setting, GPS. The first flight, it began moving again after a half hour or so; on the second flight, it didn't start working again until I tried it again about an hour after I landed. Is there fix for this besides sending it back to Cambridge? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) some older models had a problem with the indicater coming loose or falling off, again requiring an opening of unit to reclue the needle on its axle and of course a reseal by approved dealer or factory. |
On Oct 23, 12:07*pm, Mottley wrote:
On Oct 23, 10:36*am, Peter Purdie wrote: If you don't want to use the flight recorder, you could open it up and reseat the inter-board connectors (using contact cleaner sparingly). *Strip and reassembly is not difficult with care. If you want to use the flight recorder for any claim/competition then opening kills the electronic seal, so it needs to go to the factory (or approved repair agent outside the US) anyway after fixing. At 04:22 23 October 2011, Eric Greenwell wrote: On the last two flights, the needle on my 302 stopped moving. Cycling the power didn't bring the needle to life, but the everything else continued to work: audio, slow/fast arrows, averager, MC setting, GPS. The first flight, it began moving again after a half hour or so; on the second flight, it didn't start working again until I tried it again about an hour after I landed. Is there fix for this besides sending it back to Cambridge? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) some older models had a problem with the indicater coming loose or falling off, again requiring an opening of unit to reclue the needle on its axle and of course a reseal by approved dealer or factory.- Hide quoted text - - Show quoted text - Since we talking 302 problems, mine started to loose GPS signal intermittently. I suspect it is not the the GPS antenna since today the signal did not came back until I restarted the 302. Any suggestions? Ramy |
Hi Ramy,
I recommend verifying that the antenna is firmly attached to the back of the 302 - not just finger tight. It may be that a new antenna would fix the problem. Or perhaps the GPS engine needs replacement. I recommend sending it to Cambridge for repair. Paul Remde Cumulus Soaring, Inc. "Ramy" wrote in message ... On Oct 23, 12:07 pm, Mottley wrote: On Oct 23, 10:36 am, Peter Purdie wrote: If you don't want to use the flight recorder, you could open it up and reseat the inter-board connectors (using contact cleaner sparingly). Strip and reassembly is not difficult with care. If you want to use the flight recorder for any claim/competition then opening kills the electronic seal, so it needs to go to the factory (or approved repair agent outside the US) anyway after fixing. At 04:22 23 October 2011, Eric Greenwell wrote: On the last two flights, the needle on my 302 stopped moving. Cycling the power didn't bring the needle to life, but the everything else continued to work: audio, slow/fast arrows, averager, MC setting, GPS. The first flight, it began moving again after a half hour or so; on the second flight, it didn't start working again until I tried it again about an hour after I landed. Is there fix for this besides sending it back to Cambridge? -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) some older models had a problem with the indicater coming loose or falling off, again requiring an opening of unit to reclue the needle on its axle and of course a reseal by approved dealer or factory.- Hide quoted text - - Show quoted text - Since we talking 302 problems, mine started to loose GPS signal intermittently. I suspect it is not the the GPS antenna since today the signal did not came back until I restarted the 302. Any suggestions? Ramy |
Navy stops video on YouTube | [email protected] | Naval Aviation | 5 | August 23rd 07 02:03 AM |
Central Valley, CA stops | xxx | Piloting | 11 | May 2nd 07 12:18 AM |
IFR flight plan with multiple stops | gregscheetah | Instrument Flight Rules | 20 | August 21st 06 12:32 PM |
Fuel & Breakfast stops on the way to Oshkosh | Eric Bartsch | Piloting | 7 | July 20th 06 10:06 PM |
Suggested Lunch Stops "Near" Washington, D.C.? | Jay Honeck | Piloting | 33 | June 9th 05 04:43 PM |
