Can anyone help with the wing profile data for a Ventus 2cm? I need
the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. Ken |
On Oct 30, 5:40*pm, wrote:
Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken Isn't this wing the same as V2b except for the added tips? S9 |
On Oct 30, 6:40*pm, wrote:
Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken the Ventus c model has 2 sets of wing tips,15m and 18m. I'am not sure if it is the same as a Ventus 2b |
On Oct 30, 8:11*pm, wrote:
On Oct 30, 6:40*pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken the Ventus c model has 2 sets of wing tips,15m and 18m. I'am not sure if it is the same as a Ventus 2b David Lednicer's site shows a different airfoil for a Ventus 2 and a Ventus 2b no mention of a Ventus 2c. |
On Oct 30, 3:40*pm, wrote:
Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken Round in front, pointy in back, and smooth over the top and under the bottom. That will do what needs to be done. Thanks, Bob K. |
On Oct 30, 6:07*pm, Bob Kuykendall wrote:
On Oct 30, 3:40*pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken Round in front, pointy in back, and smooth over the top and under the bottom. That will do what needs to be done. Thanks, Bob K. I have profiled several sets of wings and what Bob says is essentially correct. I would profile the first 6 inches and fair the rest. Getting the existing wing to "as-designed" is probably impossible because the factory probably did not get it to that state when it was built. Typically, the wing is too thick and the leading edge too blunt. |
Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. *Ken Ken SH does not publish their airfoil data, or glide polars for that matter. The Ventus airfoil has changed in subtle ways since the 1981 a/b model introduction. The most notable changes have been a sharper leading edge and a thinner profile near the wingtip, which showed up on the V2a/b and C models. Take Bob's advice and sand, smooth, and polish. Rick |
On Monday, October 31, 2011 10:51:09 AM UTC-4, Rick Walters wrote:
SH does not publish their airfoil data, or glide polars for that matter. The Ventus airfoil has changed in subtle ways since the 1981 a/b model introduction. The most notable changes have been a sharper leading edge and a thinner profile near the wingtip, which showed up on the V2a/b and C models. Take Bob's advice and sand, smooth, and polish. Rick Note also that the airfoils (even on the original Ventus) are tailored for the Reynolds number change towards the tip. One well-known expert measured the coordinates near the root and just scaled them down, reprofiled the wing using the (incorrect) airfoils near the tip, and reported an (incorrectly measured) performance improvement ! If you didn't get the coordinates from SH, beware of any profile you might obtain... So, smooth and pray ;-) See ya, Dave "YO electric" |
Ah, the joys of sanding... No better way to bond with your ship.
Similar in many ways to good foreplay... Sorry. Boggs |
The joys of ever advancing computer computational power.
As things have become possible to calculate so the glider wings get more complex. The current crop of 18m ships are currently approaching thirty profiles over the ~8.7m of wing... They generally blend the transition from one to the next, but you certainly can't measure a station and extrapolate further out or inboard. Yes they are not all made in CNC machined steel female mounds like the JS1 - and even there I am sure there is manufacturing variation, but you would have to think carefully before re-profiling significantly. Easy to disimprove things. On 2011/10/31 4:51 PM, Rick Walters wrote: On Oct 30, 3:40 pm, wrote: Can anyone help with the wing profile data for a Ventus 2cm? I need the numerical data and if possible someone who could make templates on a CNC. I have contacted US dealer with no response. Ken Ken SH does not publish their airfoil data, or glide polars for that matter. The Ventus airfoil has changed in subtle ways since the 1981 a/b model introduction. The most notable changes have been a sharper leading edge and a thinner profile near the wingtip, which showed up on the V2a/b and C models. Take Bob's advice and sand, smooth, and polish. Rick -- Bruce Greeff T59D #1771 & Std Cirrus #57 |
| Thread Tools | |
| Display Modes | |
| Interesting biplane project... look at the wing profile | Bob Kuykendall | Home Built | 15 | December 5th 08 02:58 PM |
| Yet Another wing Refinishing question | shkdriver | Soaring | 5 | November 6th 08 12:41 AM |
| LS3A Wing Profile Data | Robert Fidler | Soaring | 14 | October 27th 08 10:59 PM |
| Wing Leading Edge Refinishing | Jan Eldem[_2_] | Soaring | 4 | June 17th 08 03:40 PM |
| ASW27 wing profile templates | basils27 | Soaring | 0 | June 29th 05 12:46 PM |
