Did an oil change on my Tripacer. I've done them before and they're pretty
easy. This one though, it looks like my oil screen cover is leaking like crazy. I actually changed the oil last month right before it went into annual. They flew it (looks like a couple of hours worth) with no leaks apparent. I flew it for the first time last week and when I was parked to gas up noticed oil dripping. Went up today and checked the torque on the oil screen housing and they were all tight. Came back after 20 minutes or so and found I had left a trail of oil. Lost a good part of a quart. I'm thinking I may not have torqued them down evenly and I'm going to try replacing the gasket and going around the bolts a little at a time. I usually retorque them after I run for a while after an oil change because the gasket tends to crush some. Any ides or suggestions on why this is happening? The surfaces are (were) clean. I'll check better when I replace the gasket. TIA. mike regish '53 Tripacer |
"mike regish" wrote in message news:Dj3Bc.81904$Sw.45236@attbi_s51...
Does the oil screen have a crush washer? Did you use a new one? Bill Hale Did an oil change on my Tripacer. I've done them before and they're pretty easy. This one though, it looks like my oil screen cover is leaking like crazy. I actually changed the oil last month right before it went into annual. They flew it (looks like a couple of hours worth) with no leaks apparent. I flew it for the first time last week and when I was parked to gas up noticed oil dripping. Went up today and checked the torque on the oil screen housing and they were all tight. Came back after 20 minutes or so and found I had left a trail of oil. Lost a good part of a quart. I'm thinking I may not have torqued them down evenly and I'm going to try replacing the gasket and going around the bolts a little at a time. I usually retorque them after I run for a while after an oil change because the gasket tends to crush some. Any ides or suggestions on why this is happening? The surfaces are (were) clean. I'll check better when I replace the gasket. TIA. mike regish '53 Tripacer |
It's a paper washer. It was new.
Today I found that the bolt flanges were cracked. Fortunately, a fellow TP owner has installed the soin on filter on his and had his cover. mike regish "Bill Hale" wrote in message om... "mike regish" wrote in message news:Dj3Bc.81904$Sw.45236@attbi_s51... Does the oil screen have a crush washer? Did you use a new one? Bill Hale Did an oil change on my Tripacer. I've done them before and they're pretty easy. This one though, it looks like my oil screen cover is leaking like crazy. I actually changed the oil last month right before it went into annual. They flew it (looks like a couple of hours worth) with no leaks apparent. I flew it for the first time last week and when I was parked to gas up noticed oil dripping. Went up today and checked the torque on the oil screen housing and they were all tight. Came back after 20 minutes or so and found I had left a trail of oil. Lost a good part of a quart. I'm thinking I may not have torqued them down evenly and I'm going to try replacing the gasket and going around the bolts a little at a time. I usually retorque them after I run for a while after an oil change because the gasket tends to crush some. Any ides or suggestions on why this is happening? The surfaces are (were) clean. I'll check better when I replace the gasket. TIA. mike regish '53 Tripacer |
A310 engine change | Andy | General Aviation | 0 | October 25th 04 07:48 AM |
oil change on my Tripacer | mike regish | Owning | 0 | June 19th 04 07:00 PM |
change of name. | M. H. Greaves | Military Aviation | 6 | April 10th 04 04:49 PM |
Time to change the air in your tires | Rich S. | Home Built | 18 | March 22nd 04 06:47 PM |
Updated information on Tripacer for sale in Durham NC, USA | Lori Fields | General Aviation | 0 | December 9th 03 04:05 PM |
