Need Help With Compaq 1550
Old November 17th 11, 02:21 AM posted to rec.aviation.soaring
Dan Marotta
Default Need Help With Compaq 1550
It was dark in the hangar when I put the memory card back into the PDA...
backwards! I brought it home so I could get the card out and now the thing
won't boot up. It's hung at the "Q" splash screen and, when put on the
cradle, the light does not come on.
I can't shut it off, only do a hard reset, and then it goes back to the
splash screen.
Is it trash? Anybody have a suggestion?
Old November 17th 11, 06:11 AM posted to rec.aviation.soaring
Paul Remde
Hi Dan,
Take both batteries out while not connected to external power and leave them
out for about 30 minutes. Then put them back in and it should boot fine.
Paul Remde
Cumulus Soaring, Inc.
"Dan Marotta" wrote in message
thing won't boot up. It's hung at the "Q" splash screen and, when put on
the cradle, the light does not come on.
splash screen.
Old November 17th 11, 11:58 PM posted to rec.aviation.soaring
Dan Marotta
I woke up this morning with just that thought and it worked. Thanks, Paul.
Now I need to find an online manual so I can reconfigure it.
"Paul Remde" wrote in message
Hi Dan,
them out for about 30 minutes. Then put them back in and it should boot
fine.
Paul Remde
splash screen.
Old November 19th 11, 01:30 AM posted to rec.aviation.soaring
Dan Marotta
Did that, too!
Hi Dan,
fine.
Paul Remde
PDA... backwards! I brought it home so I could get the card out and now
the thing won't boot up. It's hung at the "Q" splash screen and, when
put on the cradle, the light does not come on.
splash screen.
Old November 21st 11, 01:34 PM posted to rec.aviation.soaring
Andy[_1_]
On Nov 18, 6:30*pm, "Dan Marotta" wrote:
Did that, too!
Dan, the best advise I can give for the Aero series is to use Q
utilities to make a CF backup when you have it set up the way you want
it. You can recover from any nasty event in just a few minutes and do
it at the airport without any need for a supporting computer.
At the end of the season a make a current CF backup, make sure the
main battery if fully charged, then remove the main and backup
batteries. Start of next season just replace the batteries, quick
freshen of the charge, then restore the configuration.
You can of course save the CF backup file to you PC and keep multiple
versions of it if you modify the name. That protects you from loss of
the CF card. You can make similar backup with ActiveSync but you don't
need to have it.
Andy
Old November 21st 11, 03:40 PM posted to rec.aviation.soaring
Dan Marotta
Thanks, Andy, I'll check into the CF backup. Normally, I don't quit for any
season, in fact, I had a 3.6 hour flight just yesterday. Didn't get far,
but it was fun poking around at the rotors trying to get up into the wave.
No luck this time but I did succeed a week ago.
I am using ActiveSync...
"Andy" wrote in message
On Nov 18, 6:30 pm, "Dan Marotta" wrote:
Did that, too!
need to have it.
Andy
FS: Compaq Aero 1550 w/ GN2, CAI cradle JS Soaring 0 May 13th 09 08:53 PM
looking for Compaq Aero 1550 [email protected] Soaring 3 June 5th 08 05:19 PM
Troubles with Compaq 1550 Dick[_3_] Soaring 4 September 10th 07 03:49 PM
Troubles with a Compaq 1550 Dick[_3_] Soaring 8 August 31st 07 11:56 PM
USB to Compaq Aero 1550 Cable Ira Blieden Soaring 1 April 23rd 04 03:12 PM
