I'm new to the OLC & have had several flights rejected. Reason given:
IGC-file cannot be read or has wrong format! Please send the file via http://www.onlinecontest.org/olc-2.0/gliding/help.html Error by parsing IGC-File; For input string: "u78" Flights were downloaded from a 302 & attempted to upload to OLC using SeeYou. Any suggestions pls? Thanks, Bill |
Hi Bill,
Please include a link to the flight on the OLC. What is the filename? It is common for people to accidentally upload the wrong file. The filename should include the 302's serial number. SeeYou no longer can do uploads to the OLC. I'm not sure why, but I don't think it is Naviter's fault. I recommend uploading using the OLC web page. Best Regards, -- Paul Remde Cumulus Soaring, Inc. What is the "BillT" wrote in message ... I'm new to the OLC & have had several flights rejected. Reason given: IGC-file cannot be read or has wrong format! Please send the file via http://www.onlinecontest.org/olc-2.0/gliding/help.html Error by parsing IGC-File; For input string: "u78" Flights were downloaded from a 302 & attempted to upload to OLC using SeeYou. Any suggestions pls? Thanks, Bill |
![]() This is has been an issue in the past, especially with a 302 and using SeeYou. Best not to use SeeYou. This has been a long standing bug in the Cambridge/SeeYou/OLC interface. Use only the Cambridge utility, 3UTIQ257 if using an IPAQ product, or 3UTPC256 if using a laptop, to download the file from the 302 to your computer or IPAQ. Then you may upload the file to the OLC web site using the direct claim method. Seems to eliminate all the invalid file problems by removing SeeYou from the process. Regards, Linwood Stevenson TN Record Keeper |
flight rejected? | GARY BOGGS | Soaring | 2 | May 10th 11 03:58 AM |
Diamond goal flight rejected due to typo | Scott Alexander[_2_] | Soaring | 67 | June 26th 10 01:55 AM |
Tired of having your aviation photos being rejected? | APW | Aviation Photos | 12 | October 16th 08 08:21 PM |
OLC - 20 rejected, 18 Accepted | Jack | Soaring | 2 | June 4th 06 05:17 AM |
BUSH REJECTED PLANS TO GO AFTER TOP TERRORIST | WalterM140 | Military Aviation | 7 | September 24th 04 01:09 AM |
