Alternator field cycling & alternator damage
Old November 11th 04, 07:29 PM
Nathan Young
Default Alternator field cycling & alternator damage
Scenarios:
#1. Most planes have an over-voltage protection that opens the
circuit to the alternator field windings. Let's say that while the
alternator is delivering about 30amps (lights, avionics, pitot heat,
etc) - the OVR gets tripped, causing the alternator field to be
dropped immediately to 0 volts.
#2. Assume scenario #1 happens (due to a transient condition - not an
alternator failure)... It takes the pilot some time to realize the
alternator is offline, so the avionics and lights drain the battery
for several minutes. Anyway, the pilot cycles the alternator field
current to bring the alternator back online. The battery is run-down
a bit, so the current delivered by the alternator spikes from zero to
around 30-40 amps, and then gradually tapers off as the battery is
charged.
Question: Can either one of these dramatic swings in the alternator
field voltage/current, and/or the alternator output current damage the
alternator?
Last, does anyone have a link to a good tutorial on the components in
a typical alternator?
Thanks,
Nathan
Old November 11th 04, 09:10 PM
Nathan Young wrote:
: Scenarios:
: #1. Most planes have an over-voltage protection that opens the
: circuit to the alternator field windings. Let's say that while the
: alternator is delivering about 30amps (lights, avionics, pitot heat,
: etc) - the OVR gets tripped, causing the alternator field to be
: dropped immediately to 0 volts.
Aside from the magnetic field breakdown of the field's windings, this will be
fairly harmless. The regular is designed to deal with this, as it's a small amount of
current and the inductance isn't that big.
: #2. Assume scenario #1 happens (due to a transient condition - not an
: alternator failure)... It takes the pilot some time to realize the
: alternator is offline, so the avionics and lights drain the battery
: for several minutes. Anyway, the pilot cycles the alternator field
: current to bring the alternator back online. The battery is run-down
: a bit, so the current delivered by the alternator spikes from zero to
: around 30-40 amps, and then gradually tapers off as the battery is
: charged.
Again, it might not be the best on the system, but it's designed to deal with
it. The field current will "spike," but it still doesn't draw more than a few amps.
As long as the battery isn't too gone and "squishy," or have bad connections, the
current overshoot should be absorbed harmlessly by the battery with a negligible
voltage overshoot.
: Question: Can either one of these dramatic swings in the alternator
: field voltage/current, and/or the alternator output current damage the
: alternator?
Both of those are fairly normal designed-in operations of all the components,
so it should be fine. The one that has a tendency to cook alternator diodes is the
old, "disconnect the battery and see if it still runs" automotive trick. The
self-inductance of the armature windings (read: stator 3-phase coils) is very high for
a typical alternator. They are also designed to push out lots of current... the
back-emf of an idling (or slightly higher than idling) alternator shoving out 50A is
generally on the order of 60-90V. That gives you an indication of how much inductance
there is (and consequently how much 1/2*L*I^2 energy is stored there). If that load
suddenly goes away (like disconnecting a heavily chargining dead battery), that "load
dump transient" of the stator inductor energy can't do anything but spike the bus to
dissipate.
As long as the battery and connections are in good shape, this shouldn't
happen in an aircraft. If your battery is weak and you flip off the pitot heat,
landing light, and nav lights just as the electric landing gear stops drawing
40A, you could easily spike things high enough to trip the overvoltage relay (if it's
fast enough to catch it).
Hope that helps,
-Cory
* Cory Papenfuss *
* Electrical Engineering candidate Ph.D. graduate student *
Old November 12th 04, 03:04 AM
John_F
On Thu, 11 Nov 2004 19:29:57 GMT, Nathan Young
Scenarios:
The field is always switching between 14 volts and zero volts. This
is the way it works since the inductance of the field is used to
average the voltage pulses of the voltage regulator. All modern
alternator regulators are really switching regulators.
charged.
This should not be a problem unless the main 60 amp alternator output
circuit breaker is weak and then trips. If this happens on some
Cessna's (172M is one) you will generally fry the regulator, the
alternator field winding, the over voltage light and possibly a stator
diode within seconds.
You need to find the reason it is tripping off line.
alternator?
Only if the circuit breaker on the alternator output opens.
Cessna put out a manual on charging systems that is reasonable. Most
are very similar to automotive units. A good text on automotive
charging systems is good.
The FAA's airframe and power plant general handbook EA_AC 65-9A has a
lot of information on this also.
Thanks,
Nathan
Old November 13th 04, 05:16 AM
Obviously John F knows his charging systems. I'm gonna add my
comments or revisions on top of or within his, while asking him to
comment on mine if he happens to read this post again.
circuit to the alternator rotor winding. Let's say that while the
alternator stator is delivering about 30amps (lights, avionics, pitot
heat,
dropped immediately to 0 current.
The field is always switching at about 100 Hz between 14 volts and
zero volts. This
is the way the regulator works since the inductance of the field is
used with a flyback diode to
average the switching of the voltage regulator. All modern solid
state
alternator regulators are really switching regulators. The flyback
diode is connected across the rotor circuit to conduct the induced
current when the regulator momentarily switches off.
an
charged.
circuit breaker is weak and then trips again. When the alternator
stator is delivering current and suddenly disconnected by some
mechanical means (such as that breaker) from the load, there is a
negative inductive voltage pulse induced into the regulator, since it
always remains connected to the alternator output. This pulse is
caused by the collapsing field of the stator. If this happens on some
Cessna's (172M is one) you might possibly fry the regulator, the over
voltage light (cheap) and possibly a stator diode within
milli-seconds. I'd be surprised though if there were no reverse or
flyback diodes in the regulator design to protect against this.
alternator?
Only possibly if the circuit breaker on the alternator output opens.
If the rotor field remains connected to the regulator, the collapsing
field flux of the rotor will cause a negative voltage spike that
should be handled by the regulator's flyback diode. I'm not sure what
happens to the magnetic energy in the stator if the breaker pops, but
theoretically the stator output voltage should spike in the negative
direction. The regulator will have to absorb this.
are very similar (but not identical) to automotive units. A good text
on automotive
Aircraft systems are different in that they add the possibility of the
alternator output breaker dropping the load, which doesn't happen in
cars. Aircraft systems also have a master contactor that, if it
stutters, can create a situation in which the aircraft electronics
become the flyback diode for any current transients in the system. A
low battery for instance will cause the master contactor to possibly
stutter when the starter is engaged. As long as the battery remains
on line, the aircraft electronics are probably able to handle the
voltage transients from the starter or other devices. But if the
battery should momentarily disconnect, there is really no place for
the induced currents to flow other than fry electronics stuff. Solid
state devices are the worlds fastest fuses. They also don't like
reverse voltage transients.
Using a scope and an electric motor to temporarily power the
alternator, we found that the trip setting of the overvoltage sensor
on our 172M had drifted low. We fixed it by replacing it. I recall
there was a screw of a multiturn tweekpot on the side of the old
OVsensor that probably allowed the trip point to be adjusted. We
didn't see it until we had it out of the airplane though. Rather than
mess with it, we replaced the whole unit.
Old November 14th 04, 02:52 AM
John_F
On 12 Nov 2004 21:16:36 -0800, ) wrote:
I agree with Daneth except for one thing. When the stator circuit is
opened while providing current the inductive spike is POSITIVE. The
voltage always tries to continue the current in the same direction it
was flowing hence the voltage spike on the stator output is positive.
The alternator will put out about +90 volts DC "CONTINOUS" with 12
volts on the field at normal engine RPM if the stator output is
unloaded. Add to the +90 volts the (+) inductive kick of the stator
inductance when the load is removed and you have several hundred volts
for a few hundred microseconds followed by 90 volts continuous for as
long as you have field current. The field current takes 10's of
milliseconds to drop to zero after the OV relay turns the regulator
off.
Cold weather, a hard to start engine and a old tired 60 amp alternator
breaker that was later found to trip at 35 amps cost me a new voltage
regulator, a new alternator, a new breaker, and a new over voltage
lamp when the breaker popped one cold night just after take off. The
OV light did not last long when fed 90 volts and was like a red flash
bulb. (What was that flash??) By the time I went around the pattern
to land the regulator and alternator field was also fried. On a
Cessna 172M the 5A field circuit breaker is NOT in series with the
alternator field winding. The 5A field circuit breaker only powers a
field relay coil in the voltage regulator that pulls 0.2 amp max.. It
is a good thing that I did not notice that the 60 amp breaker had
popped until I had landed or I may have been replacing a lot of
expensive radios.
I have no idea what the alternator output voltage really went to when
at least 90 volts was fed to the alternator field winding when the
regulator shorted and the OV relay coil contacts welded closed from
the over voltage.
It appears that Daneth is also knowledgable on Cessna charging
systems.
heat,
zero volts. This
state
an
charged.
alternator?
on automotive
Old November 14th 04, 08:28 AM
Economic Girly Man
My deepest sympathies.
How did you determine that you *fried* the alternator field? How exactly did it
fail (open, shorted ???) Any failures on the stator side (diodes ???)
EGM
Old November 14th 04, 09:02 PM
John_F
A visual inspection of the alternator showed that the windings on the
rotor were black and shedding burned insulation. An ohmmeter showed
less than one ohm field resistance. The stator windings looked good
and tested good as did the diodes.
John
On Sun, 14 Nov 2004 08:28:00 GMT, Economic Girly Man
EGM
Old November 12th 04, 09:33 PM
John Galban
Nathan Young wrote in message . ..
charged.
This is exactly what happens every time I start my airplane.
Battery is a bit low from delivering a bunch of amps to the starter.
After I let go of the key, the alternator goes from zero to 30-40
amps, then gradually tapers off.
