Is there a way to permanently load in a way point, such as home base?
Thx in advance. VL |
Use the outer knob to go to the WPT group of pages. Use the inner knob to
select the last page where you can enter the waypoint. You can also press MENU to see the list of user waypoints. You can enter the point as a radial and distance, two radials, or lat long. You can also enter it graphically. Go to NAV page 2, the map. Press in on the cursor knob. You should now have an arrow. Move the arrow to where you want to make the point. While you are doing this, you can zoom or press the clear button to change the declutter and zoom. When you are at the point that you want to make a waypoint press ENT and you will create a waypoint at the point. Note that you can play with inputing the name of another waypoint such as a VOR in the appropriate field to get the VOR radial and distance of the point. Most of the Garmin mapping GPS receivers have a similar type function. To get rid of the cursor, press on the knob again. John Bell www.cockpitgps.com "MLenoch" wrote in message ... Is there a way to permanently load in a way point, such as home base? Thx in advance. VL |
But it appears that if you want to mark the present position a quick way is
to press the inner knob to activate the cursor. The cursor should start at the present position. Now press ENT to create the point. Also, on the waypoint creation page, hit the CLR button when one of the names of a waypoint for giving a radial reference is highlighted. You should get P.POS I have some tricks on using the 430 for navigation in the navigation section of my book at www.cockpitgps.com. Essentially, use the map for situational awareness and the data fields for precision. Configure the data fields to show TKE, XTK, DIST, and WPT. TKE will tell you how many degrees to adjust your heading in order to parallel the course and XTK will tell you how far off course you are. The big deal is using the TRACK data (TKE is the difference between DTK and TRACK). You can just fly the GPS with the CDI like a VOR, but using the track information such as in TKE should make it easier. Hope this helps, John Bell |
Question on Garmin GNC 250XL | Ron | Home Built | 1 | October 24th 04 08:26 AM |
Garmin 250XL Question | Carl Orton | Owning | 0 | April 28th 04 02:54 AM |
Garmin 430 question | smf | Instrument Flight Rules | 4 | December 1st 03 03:03 AM |
Garmin audio panel question | Brinks | Owning | 1 | September 10th 03 08:41 PM |
GARMIN 196 QUESTION | Cub Driver | Piloting | 5 | July 9th 03 04:29 PM |
