Engine Questions
Old January 19th 04, 09:17 PM
Bill A.
Default Engine Questions
I'm still trying to select an aircraft to build from scratch and it's
starting to look like it's coming down to the engine (budget reasons of
course). I really like the Pietenpol Aircamper but from what I've read you
need a Rotex or other "aircraft" engine and of course that's expensive. I
was also thinking of the Volksplane, which I don't like as much but it can
use a VW engine which I can find cheap and I've torn down and rebuilt a
couple of them so I'm more familiar with them.
So the question's are.does anyone have experience (good or bad) with a VW
engine in an Aircamper? What other scratch build planes work well with VW
engines other then the Volksplanes? What other engines would fall into the
same price range has a VW (which I would be getting used and rebuilding
myself)?
Thanks all
Bill A.
Canoga Park, CA
PS. If anyone has a Pietenpol, Volksplane, or similar plane in the LA area I
sure would like to take a look at it.
Old January 19th 04, 09:45 PM
Jan Carlsson
Check out the Corby Starlet nice plane.
http://members.eaa.org/home/homebuil...20Starlet%20CJ
-1.html
Jan Carlsson
www.jcpropellerdesign.com
"Bill A." skrev i meddelandet
ink.net...
myself)?
Thanks all
Bill A.
Canoga Park, CA
I
Old January 19th 04, 10:17 PM
clare @ snyder.on .ca
On Mon, 19 Jan 2004 21:17:11 GMT, "Bill A."
A Piet can be flown with LOTS of different engines. The Model A Ford
was the first engine - all 40? HP. The 50HP model B followed, and then
the Corvair.
If the Model A worked, I'm sure a 200 plus cu inch later model inline
four or six could be made to work as well. You want something with
"grunt" - lots of torque at low RPMs.
myself)?
Thanks all
Bill A.
Canoga Park, CA
Old January 20th 04, 01:39 AM
James Lloyd
If you just need a single seat plane,a jeanie,s tennie is a good choice.
Old January 20th 04, 02:21 AM
jls
"Bill A." wrote in message
ink.net...
need a Rotex
Rotax? Nope. Pietenpols use old Ford A-Model engines, Corvair engines,
and affordable old Continentals like the A-65 and C-85. If you are on a
tight budget in Southern California, the Pietenpol Aircamper may be the way
to go. Do a google and you'll find all kinds of Piet groups. The Piet
clan gather every summer in Brodhead, Wisconsin for a fly-in. It is said
that if you visit with them a spell will be cast over you and you'll be a
Piet-head for the rest of your life.
myself)?
Thanks all
Bill A.
Canoga Park, CA
I
Old January 20th 04, 04:11 AM
Bill A.
On Mon, 19 Jan 2004 21:21:06 -0500, " jls"
link.net...
need a Rotex
I've done a bit of searching online but I can't seem to find
any Continentals for sale that aren't already attached to
something. Where would I find some and what's the ballpark
price? Are Corvair engines still around with as few
Corvairs that were produced I would think the supply would be
limited (along with parts) and can you still find Ford Model
A engines any more, much less parts? What would be the most
economical, commonly used engine out there now a days?
myself)?
Thanks all
Bill A.
Canoga Park, CA
I
Old January 20th 04, 04:48 AM
Richard Lamb
link.net...
need a Rotex
I fly a VW.
But it won't swing enough prop to fly an Air Camper.
The Piet Air Camper was designed around the Ford engine.
The plane needs that mass of metal up front to balance properly.
With a lighter, a longer mount is needed to keep the plane in balance.
Longer noses usually mean less yaw stability.
A Contenental A-65 - A-85 seems to work out ok.
At least you see them flying now and then.
Richard
Old January 20th 04, 05:45 PM
Jay
I suppose if the VW is lighter and more powerful than the model A
engine, you could always mount it in the same place put lead weights(a
car battery?) up front.
I'd vote for the longer nose/lighter plane though, you can always
enlarge the rudder. Also as far as strait line stability, the
fuselage area in front of the CG may be offset to some degree by the
gyroscopic effect of the spinning mass being further from the CG.
Regards
I fly a VW.
Richard
Old January 20th 04, 04:53 PM
jls
link.net...
you
need a Rotex
engines,
way
Try Barnstormers.com, Trade-a-Plane, and Ebaymotors.com for old
Continentals. We just found one, an A-65 we can convert to A-80, nearby
for just over 1k and will put about 2k in it for rebuild. For 3k you can't
beat it. Subarus will work too, as someone suggested. You probably need
a redrive for a high-turning Soob engine. Corvair engines are plentiful
and parts are not hard to find. And believe or not there are plenty of old
A-Model Ford engines, but I don't know the price. I'll ask a friend who
just bought one.
I do recall an A-65-powered Piet with a big lead weight bolted to the front
of the engine. I wouldn't want that so when you build the Piet designed
for the heavy Ford engine, you have to be careful about W&B.
Just keep shaking the bushes and you will find it. Get somebody to send
you the old articles from Mechanix Illustrated where Bernie Pietenpol said
he could have you flying for about $500 and you'll be sold. Or was that
$200? 50?
Old January 20th 04, 10:19 PM
Tom Cummings
" jls" wrote in message news:j7dPb.38883
Corvair engines are plentiful as well as the parts. We are talking rebuilds.
Use '64 through '69 engines and view http://www.flycorvair.com/
and http://www.corvaircraft.com/ for more specifics on selective cases and
heads to use.
Corvair College V was just held this past weekend at Hanover, CA.
Tom
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 1 January 2nd 04 09:02 PM
Homebuilt Aircraft Frequently Asked Questions (FAQ) Ron Wanttaja Home Built 0 October 2nd 03 03:07 AM
Corky's engine choice Corky Scott Home Built 39 August 8th 03 04:29 AM
