FAA form 337?
Old January 22nd 04, 06:30 AM
Paul Lee
Default FAA form 337?
Some equipment I installed mentions form 337 - for example VOR/LOC/GS receiver,
IFR GPS, etc., Is 337 required in a new kit project? It is for "Major repairs
and alterations".
Or does the DAR approve the whole package together?
Please advise any required procedures.
Paul Lee, SQ2000 canard project: http://www.abri.com/sq2000
Old January 22nd 04, 07:05 AM
Jerry Springer
337 IS NOT required for experimental aircraft.
Jerry
and alterations".
Old January 22nd 04, 04:37 PM
Ron Natalie
"Tarver Engineering" wrote in message ...
No, homebuilts are type certificated under Part 21 as Experimental.
No John, they are not. They do not have type certificates. What they
have are individual airworthiness certificates issued under 21.191. There
is no type certification of experimentals.
Nothing in part 43 (maintenance. preventive maintenance, rebuilding, and
alteration) applies to aircraft with experimental certificates. This is specifically
stated in 43.1(b). 337's don't apply to homebuilts.
The only thing that applies is that the limitations attached to the airworthiness
certificate will say to notify the FSDO for major alterations and require a 5
hour test period and also remind the owner to update the registration if the
engine /propeller make/model changes.
Old January 22nd 04, 04:38 PM
Tarver Engineering
m...
There
You had best get with the "experimental aircraft association" on that one,
Ron.
Old January 22nd 04, 05:59 PM
Bob Kuykendall
That's a contradiction. 14 CFR 21.21 and 14 CFR 21.181 are quite clear
on this. Experimental aircraft are "certificated," yes, but they don't
hold "type certificates."
Bob K.
Old January 22nd 04, 06:10 PM
Tarver Engineering
"Bob Kuykendall" wrote in message
om...
You are mistaken, "Experimental" is a Type, under CFR 14 Part 21.
The difference is that an Experimental is not elidgeable for STC, but
"Normal Catagory" type airplanes are.
Aeronautical Engineering Help needed Marc A. Lefebvre US-775 Home Built 94 January 11th 04 12:33 PM
lots of P&LE pics form early years. W. D. Shellenberger Home Built 2 November 29th 03 08:15 PM
Calculating vertical time and distance in a stall turn (US Hammerhead) Dave Aerobatics 3 November 20th 03 10:48 AM
I love Jim Campbell Badwater Bill Home Built 81 August 19th 03 09:10 AM
Any 1 bound for Oshkosh form Philadelphia? AWSOME Home Built 0 July 26th 03 07:28 AM
