Cambidge 302 display polarization
Old February 13th 12, 12:32 PM posted to rec.aviation.soaring
JC
Default Cambidge 302 display polarization
Hi folks,
This weekend I flew a task with a borrowed 302.We are planning to
upgrade the panel and it was a good oportunity to try it out. It was
the first time I used one and I liked it but the display blacks out
with my polarized sunglasses and the only way to read it was lifting
them or tilting my head..
Is there a fix for this? Someone told me that newer units donīt have
this problem.
I prefer flying with polarized sunglasses so this would make me vote
against buying one in spite of it being a very nice instrument.
Thanks!
Juan Carlos
Old February 13th 12, 12:41 PM posted to rec.aviation.soaring
qflyer1
On Feb 13, 7:32*am, JC wrote:
Hi folks,
this problem.
Thanks!
Juan Carlos
You have to send it in to get the non-polarized display.
Been there.
Tim
1FL
Old February 13th 12, 02:38 PM posted to rec.aviation.soaring
Tony[_5_]
On Feb 13, 6:32*am, JC wrote:
Hi folks,
this problem.
Thanks!
Juan Carlos
get non-polarized sunglasses?
Old February 13th 12, 03:17 PM posted to rec.aviation.soaring
stephanevdv
Probably the best option. Polarized sunglasses have other problems,
sometimes creating dark zones in Perspex canopies. As far as I know,
there is no standard for the polarization of LCD-screens. You have to
turn your head one way for one instrument, the other way for the
other...
Good quality non polarized sunglasses are better for our purpose.
Something like Serengeti, Skylet etc.
Old February 13th 12, 09:55 PM posted to rec.aviation.soaring
Darryl Ramm
There absolutely is a standard. Its to not polarize aircraft instruments so they conflict with Polaroid sunglasses--which are all polarized in the same direction to cut down on reflection off water/road surfaces etc. Cambridge simply (years ago) had a batch of 302s where the glass was installed incorrectly.
There is maybe less of a practical standard for handheld devices becuase some devices are intended to use in portrait or landscape orientations. Manufacturers need to make a best guess as to which orientation is more important for users wearing polarized sunglasses. If the device is only designed to be oriented one way then the choice for them should be obvious.
Polaroid sunglasses can have significant benefits to glider pilots, including making haze dome/wisps more visible (darkening the background sky and maybe direct polarizing effects) and making gliders more visible against darker sky. This is further enhanced if the sunglasses are strong "blue blockers". Besides difficulty reading some PDA/PNA etc. screens polarized sunglasses may show stress patters in canopies. I've flown in quite a few Mecaplex canopied aircraft with Polarized sunglasses and have had no problem at all with this. The side windows on my Toyota Tundra show more patterning.
As a final note some cheaper polarized sunglasses may suffer from poor aliment of the polarizers, so you'll see different darkening in each eye as you rotate say an PDA/PNA screen or even look at different parts of the sky.
Darryl
Old February 13th 12, 09:57 PM posted to rec.aviation.soaring
Darryl Ramm
Stupid automatic spell checker, "Polaroid" snuck in in several places.. I meant polarized.
Old February 14th 12, 01:11 AM posted to rec.aviation.soaring
Tony V
On 2/13/2012 7:32 AM, JC wrote:
Hi folks,
I went to my optometrist and said that I wanted non-polarized lenses.
She said "are you a pilot?". I have a 302 that's polarized one way, and
a Filser radio that's 90 degrees different. There's only one "fix for this.
Tony "6N"
Tony V
Hi folks,
Tony "6N"
Old February 16th 12, 06:21 AM posted to rec.aviation.soaring
Garret Willat
Go to a Camera store. Get a polarized filter. The one I got was about
8in x 8 in plastic and had a cardboard frame it was used to be placed
in front of a light for stage lighting.
I had a circle cut out of it and placed it over the glass display and
taped in place. Sit in the glider and rotate the polarized plastic
until you can see the 302 screen again. Used to do this in a borrowed
DG800. It was slightly darker than ideal, but worked fine.
Old February 16th 12, 03:43 PM posted to rec.aviation.soaring
Dave Nadler
Sunglasses block light polarized direction A.
Instrument polarizer blocks light polarized A+90 degrees.
In series they block everything.
Why does adding a third polarizer in the middle
allow light through ?
Spoooooookkyyy ;-)
Cambidge logger for Sale Grider Pirate Soaring 0 August 23rd 10 05:43 PM
T.O.M. Static Display Batch 1 [03/47] - T.O.M. Static Display Index 3.jpg (1/1) Indrek Aviation Photos 0 August 20th 10 01:58 AM
Copyright Đ2004-2025 AviationBanter.
