Winter Flying, all over again
Old December 12th 03, 03:54 AM
Jay Honeck
Default Winter Flying, all over again
So this afternoon was perfect VFR, after the storms of yesterday.
Realizing that we wouldn't be able to fly for at least another week, due to
upcoming holiday commitments, it was obvious what needed to be done:
Fly -- right now!
Problem: Two inches of snow had fallen yesterday, on top of heavy rain, and
the then plummeted to 12 above zero. This combination invariably resulted
in a pounded-down layer of hard snow over glare ice -- the perfect scenario
for a "no-brakes" runway condition...
Oh well. I originally trained in Wisconsin, in winter, and learned early-on
how to deal with snow and icy runways. We've flown in the upper MidWest for
ten years, and have simply learned to adapt. With my son home sick in bed
(Flu? Half his school is out with it!) we loaded up my daughter and headed
to the frigid hangar...
Sure enough, the hangar door was frozen to the ground. A firm yank on the
chain broke it free, but the door was heavy with the frozen concoction that
had blown against it, and then frozen solid. Between the weight and the
cold, it was at least twice as heavy to lift as on a hot summer's day!
Then came the fun of pre-flighting in wind chills of -10 degrees. While my
daughter played in the snow (how come they never seem to feel the cold?) I
naturally opted for an "in-hangar" pre-flight -- but it was still damned
cold. Finally, we had to face the fun of pulling Atlas out of his hangar,
onto the packed down ice and snow. This required both of us, since as one
would lose traction, the other could keep pulling...
With our dual cylinder and sump heaters, the engine was as warm as on any
August afternoon, and started on the first blade. We inside were not so
pampered, and shivered in the cold while we tried to minimize our
exhalations, lest they freeze on the windows. Taxiing required more RPMs
than normal, just to roll us across the crusty white stuff...
Arriving at the end of the taxiway, we were greeted by a fellow pilot
working the pattern. The sky was a brilliant azure blue and hot pink, with
the sun already setting on this mid-December day. Sunset is at 4:30 at this
time of year, and the winds were dying down accordingly. Everything
sparkled intensely in the blindingly white, new snow...
Waiting for his arrival in the pattern, I determined that we had plenty of
time for a normal run-up and departure. With my 10-year old daughter as
co-pilot, I asked her to hold the yoke while I ran up to 2000 RPM. We
immediately started sliding, so I knew that the NOTAM for this runway would
read "Braking action: Nil". Exercising the prop, I was amazed at how stiff
the linkage was, but all checks were "in the green", so we rolled out onto
runway 30 for departure.
Turning was "interesting", requiring differential braking to get aligned
with the runway. But then, with a last glance at the sky and the gauges,
it was time to go!
Throttle response was smooth and throaty, as all six cylinders heaved into
action as one. The runway crunched beneath us as the takeoff roll swiftly
accelerated, but directional control was accomplished as much with rudder as
by steering. This was one slick runway!
Atlas fairly leapt off the ground, despite carrying 84 gallons of gas, and
dragging through all that crunchy snow. It felt like we had an extra 100
horsepower, as we climbed out at an impossibly steep deck angle, up and into
the pattern. As I turned crosswind, then downwind, calling out my position
to my fellow pilots, I was astounded to note that I was climbing like a
rocket through 2300 feet -- 1600 feet, AGL -- before hitting downwind!
Needless to say, I pulled the throttle back, trying to minimize shock
cooling as much as possible, and started drifting back down to pattern
altitude! Still, starting that high, it was impossible to lose that much
altitude in a normal pattern, so I extended downwind while scrubbing away as
much excess altitude as possible.
The air was thick and deliciously full of lift -- I just could NOT get Atlas
to come down! Amazingly, the winds aloft were zipping us along at 125
knots, with the throttle at idle, but it was absolutely still air. Banking
smoothly onto base leg, we settled into a stabilized approach that couldn't
have been more solid had we been mounted on rails...
This first one would be a touch and go, and I opted for two notches of
flaps. Knowing that the surface was irregular but mostly cleared of snow, I
concentrated on minimizing any side stresses, aiming deliberately and
carefully down the imaginary center-line, completely obscured as it was...
....ever so gently, the wheels kissed the snow. I immediately applied full
power, and Atlas literally howled at the moon, and all I could see was sky.
Mary, in the back seat, exclaimed that I had cheated, and never touched the
runway -- but Atlas and I knew better...
Up and around again, this time more aware of our increased performance, I
opted to depart the pattern for a brief flight over to my daughter's school,
and our home. Circling slowly in the angled sunlight, we took some great
pictures of her favorite playground....
Then it was back to the pattern, but this time I would do a low approach
down Runway 25. This would give Mary the optimal angle to take pictures of
the Inn with the setting sunlight highlighting the new snow. Down final we
glided, while I applied the proper cross-wind correction to keep us aligned
with the extended centerline, Mary snapping away... Then it was full power,
and off we climbed once again.
Finally, it was time for our fun to end. The cabin was now toasty warm, and
the sun was setting on the horizon like a giant ball of fire. Atlas was
performing flawlessly, the wind was right down the runway at 4 knots, and
all was right with the world. The lights of the city were winking on, and I
clicked the PTT repeatedly in order to fire up the suddenly needed runway
lights.
This one would be full stop, without brakes. Luckily, runway 30 is over
4500 feet long, and the snow would provide a fair amount of directional
control. Down we slid on final, just a smidge slower than normal, utilizing
all three notches of flaps, and touched down ever-so-lightly on the
snow-covered runway. Holding the nosewheel off as long as possible,
maintaining directional control with rudder once again, I was rewarded with
one of those rare, perfect landings. They don't come very often, but this
was one of those landings where you know that there is absolutely no way to
improve upon any single aspect of it -- we had achieved the nirvana of
landings. Even Mary "oooohed" as we smoothly rolled out, easily stopping
before the first intersection -- without brakes.
Some days are better than others. This one made me glad that we don't lock
the hangar door after Halloween, like so many of our hangar neighbors...
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old December 12th 03, 05:29 AM
StellaStar
Great writeup, Jay! There's nothing like winter flying, especially in a plane
with good cabin heat...and the dense, cold air is so smooth, you climb like
that first solo without the instructor!
I was on the road Monday night, with dense ground fog over Iowa's snow and the
big full moon so bright in the clear sky above, it made the night sky
bluish...and remembered my night x-c four years ago. The 133-year perigee
solstice moon was just rising as we turned crosswind and flew into it, and the
rest of the trip was equally magical.
Old December 12th 03, 06:39 AM
BTIZ
tell me again why I live in Las Vegas? LOL
Not to worry.. areas around Las Vegas got snow... the city got rain..
freezing level is about 3000AGL, well below IFR MEA altitudes.. most birds
are walking.. the highway over the mountain pass was closed.. causing a
100mile or better detour around the mountain..
about 150 miles north of here.. and at 5500MSL (airport elevation) it snowed
all day and dropped 3 inches of snow.. almost did not make it home tonight..
BT
"Jay Honeck" wrote in message
news:_ZaCb.514281$Fm2.498883@attbi_s04...
to
Fly -- right now!
and
scenario
early-on
for
bed
that
with
this
would
stiff
it was time to go!
swiftly
as
into
position
as
Atlas
Banking
couldn't
I
sky.
school,
of
we
aligned
power,
and
I
lights.
utilizing
with
to
lock
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 12th 03, 01:47 PM
Jay Honeck
snowed
tonight..
You're killin' me!
In Wisconsin, 3 inches of December snow is considered a "nice day". Here
in Iowa, people take it a bit more seriously -- they might not drive to the
mall, for instance.
Of course, snow on a mountain road can get pretty interesting...
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 12th 03, 08:26 PM
Jack Allison
Ya, what he said! Ice and snow on a runway eh? Hmmm, don't know what
you're talking about :-)
A cold winter day flying out here is when it drops below 40. Now *that's*
when I'll break out my flying gloves. Brrrrrrr :-)
Then again, we do get those wonderful days where the fog just sits in the
central valley for days on end. Great for IFR work though (next fall for
me).
Nice writeup. Glad you could convert cash into lift on a cold almost winter
day.
Jack Allison
PP-ASEL
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old December 12th 03, 02:28 PM
Harry Gordon
Jay,
I really enjoyed reading your experience. I went Christmas shopping
yesterday - in a short sleeve shirt. Of course here in South Central Texas
(San Antonio) that is about all you need for this time of the year :-).
We're going to do a little flying tomorrow and it looks like the temp will
be in the 60 - 65 range. The wind is predicted to be 10-20 MPH. I hope I
don't forget my suntan lotion (hahahahaha).
Harry
PP-ASEL
to
Fly -- right now!
and
scenario
early-on
for
bed
that
with
this
would
stiff
it was time to go!
swiftly
as
into
position
as
Atlas
Banking
couldn't
I
sky.
school,
of
we
aligned
power,
and
I
lights.
utilizing
with
to
lock
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 12th 03, 03:36 PM
Gene Seibel
I just love phrases like that.
Gene Seibel
Hangar 131 - http://pad39a.com/gene/plane.html
Because I fly, I envy no one.
Old December 12th 03, 06:06 PM
After the rain, we had 8 inches of snow here the other night and the snow
blew all day Wednesday. They canceled school at noon that day and never
plowed any of the roads until Thursday afternoon. Wednesday's private
ground school had to be canceled mostly because visibility was less than 1/8
mile with 20-30mph winds out of the west with snow and blowing snow
everywhere. But last night the airport had been plowed out and it was time
to go flying!! Until the plane wouldn't start... even though it had sat in
the heated hanger all day, the battery in the Archer had seen it's better
days. So we pushed it back inside, got the doors buttoned up and hooked up
the charger for an hour. By this time it was down to 0F outside so after
pulling it out a second time, I jumped in and after 2 hesitant cranks of the
prop it fired and started. All the lights of the city and of the runway
glowed against the bright snow, and the lights of the freight traffic coming
into CWA just 20 miles north made for a beautiful night of flying. (not to
mention that great full moon!) 2.1 hours, a night time checkout, a hold, 4
instrument approaches with 4 touch and goes later we were done. Even though
it was after 9:00, it was almost too nice to quit.
Jim Burns III
Remove "nospam" to reply
Old December 13th 03, 04:57 AM
Jay Honeck
Even though
Sweet, Jim.
I'm tellin' ya, the very best flying is in winter!
Jay Honeck
Iowa City, IA
Pathfinder N56993
Old December 13th 03, 03:20 PM
G.R. Patterson III
Easy for you to say - *your* plane has a decent heater.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Winter flying ops Viperdoc Owning 4 December 24th 04 01:29 AM
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
Mountain flying instruction: McCall, Idaho, Colorado too! [email protected] General Aviation 0 March 26th 04 11:24 PM
FA: WEATHER FLYING: A PRACTICAL BOOK ON FLYING The Ink Company Aviation Marketplace 0 November 5th 03 12:07 AM
the thrill of flying interview is here! Dudley Henriques Piloting 0 October 21st 03 07:41 PM
