Komet Trailer - Winter Project
Old July 28th 12, 10:03 PM posted to rec.aviation.soaring
Bastoune
Default Komet Trailer - Winter Project
Well, it appears that Bill did not get a good response to his question 14 years ago. Has the state of science improved to the point that removing the tongue from the trailer is now a feasible endeavor? I have the same problem as Bill and could use some RAS tips... Thanks!
Bastoune
Old July 28th 12, 10:32 PM posted to rec.aviation.soaring
Papa3[_2_]
Bastoune
I replaced the tongue on my trailer maybe 13 years ago. IIRC, the only additional thing I had to do was to spray a fair amount of penetrating oil into the sleeve (using the holes where the two bolts were located) and applying some significant torque to twist the whole thing out. Time may have dulled my memory a bit on the exact details, but I do recall it being "intuitively obvious" (i.e. no crazy, hidden stuff).
Old July 28th 12, 11:26 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Bastoune
I replaced the tongue on my trailer maybe 13 years ago. *IIRC, the only additional thing I had to do was to spray a fair amount of penetrating oil into the sleeve (using the holes where the two bolts were located) and applying some significant torque to twist the whole thing out. * Time may have dulled my memory a bit on the exact details, but I do recall it being "intuitively obvious" (i.e. no crazy, hidden stuff).
My 1985 Komet has two big U bolts that clamp down on the outer tube
that the tongue assembly slides into. You have to loosen these in
addition to pulling out the two big cross bolts that Erik mentions.
-Evan / T8
Old July 29th 12, 03:39 AM posted to rec.aviation.soaring
Dan Mockler
You can purchase a replacement tongue from Anschau for
around 559 Euro's.
Dan
question
that removing
the same
pro=
Bastoune
=A0IIRC, the
only=
penetrating
oil=
located) and
app=
lying some significant torque to twist the whole thing out. =A0
Time may
ha=
it being
"i=
outer tube
in
mentions.
-Evan / T8
Old July 29th 12, 04:33 AM posted to rec.aviation.soaring
Dan Mockler
around 559 Euro's.
Dan
question
that removing
the same
pro=
Bastoune
=A0IIRC, the
only=
penetrating
oil=
located) and
app=
Time may
ha=
it being
"i=
outer tube
in
mentions.
-Evan / T8
Komet Trailer Question Jay Allardyce Soaring 9 December 3rd 11 12:16 AM
Komet trailer painting jim Soaring 2 March 9th 10 04:12 PM
Trailer tires for old (1981) Komet Trailer [email protected] Soaring 3 May 13th 09 10:24 PM
Old Komet Trailer thermalrider Soaring 7 October 11th 08 04:13 PM
Komet trailer strut John Shelton Soaring 5 November 15th 03 05:04 PM
