Replacing position light bulbs
Old December 29th 03, 06:43 AM
Mutts
Default Replacing position light bulbs
Any rental pilot/flying club types out there carrying spare postion
light bulbs with them? Do you have to be an A&P to change them? Do
owners frown on replacing bulbs without being informed first?
How hard is it to change them on Archers and 172s?
Its getting old finding the lights burned out during preflight and
everything is closed.
Old December 29th 03, 06:53 AM
Troy Towner
Two words... Preventative maintenance.
-Blue skies and a tail wind
"Mutts" wrote in message
Old December 29th 03, 06:18 PM
G.R. Patterson III
Which can be done by the owner, not a renter.
George Patterson
Great discoveries are not announced with "Eureka!". What's usually said is
"Hummmmm... That's interesting...."
Old December 29th 03, 04:01 PM
Peter Duniho
"G.R. Patterson III" wrote in message
It can also be done by the renter, as long as the renter only works on the
airplane being operated by him (which is the scenario in question here).
If the airplane is used for Part 135 service, the renter is technically not
allowed to. However, if I were that renter, and I couldn't find an approved
mechanic to do the work, I would still do it myself and let the FBO know
that some non-Part 135 service had been performed on the airplane.
Heck, for that matter, I'd let the FBO know what I'd done regardless and
make them pay for the bulb.
Pete
Old December 29th 03, 09:41 PM
G.R. Patterson III
The pilot of a rental aircraft is not the operator. The operator is the owner or
an agent (such as an FBO) who rents out the aircraft to that pilot.
George Patterson
Old December 29th 03, 06:55 PM
Ron Natalie
"G.R. Patterson III" wrote in message ...
Nope, the pilot of a rental aircraft IS the operator. You can't be an operator
without a pilot, ownership or other legal control of the aircraft is specifically called
out in the definition as not mattering. Despite the O in FBO, they are rarely an
operator by the FAR definition.
The real issue is that you must make the appropriate maintenance records and
many renters don't have access to the logs.
Old December 30th 03, 09:53 PM
Peter Duniho
owner or
Please reread the regulation (I'm assuming you read it once already). The
regulation is not talking about an "operator" in that sense. They simply
mean the pilot who is actually operating the airplane.
Old December 29th 03, 07:20 AM
Peter Duniho
No, you don't have to be an A&P. I don't have an airplane on leaseback, but
if I did, I would expect that a renting pilot would either get the FBO/club
mechanic to change the bulb if the airplane was home, or change it
themselves if the airplane was not and lights were required for their
flight.
In other words, I'd prefer that renting pilots not change bulbs (or do other
preventative maintenance that involves removing airplane parts) but
realistically, most renting pilots are entirely competent to handle the task
and would certainly be expected to do so if the task was required for safe
and legal flight.
Never changed them on either of those types, but on my own plane, it's no
harder than changing the tail light, signal, etc. bulb on a car. Usually
just a couple of screws to remove for the lens, and the bulb pops right out.
The hard part is finding the right bulb. Landing and taxi lights are
slightly harder, but still within most folks abilities.
Now, all that said, if you are frequently finding the bulbs burned out, you
may want to rethink who you're renting airplanes from, or at least suggest
to the airplane owners/operators that there might be something causing the
bulbs to fail prematurely. I've owned my airplane for nearly ten years now,
and have only had to replace two bulbs, both of them nav lights.
Pete
Old December 29th 03, 08:09 AM
Dale
If you do change the wingtip bulbs take care. The glass lens used is
easily dropped as you remove the retainer and is expensive to replace.
Been there, done that. G
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old December 29th 03, 06:20 PM
Blanche
And under no circumstances touch the new bulb with your fingers! Use
gloves or something (shirt tail?) Oil & sweat from your fingers is
not good for the bulb. In fact, if you have the box the bulbs come
in, that warning is printed (or should be) on the box.
Skycraft Landing Light Question Jay Honeck Owning 15 February 3rd 05 06:49 PM
The light bulb Greasy Rider Military Aviation 6 March 2nd 04 12:07 PM
Effect of Light Sport on General Aviation Gilan Home Built 17 September 24th 03 06:11 AM
OT but very funny after some of the posts we have had of late. Mycroft Military Aviation 1 August 8th 03 10:09 PM
