Best performing Vario?
Old September 22nd 12, 05:58 PM posted to rec.aviation.soaring
Craig R.
Default Best performing Vario?
In your opinion, what was the best performing vario you have ever used? Specifically, the one that got you centered in and to the top of the thermal in the least amount of time.
Let's ignore products because they have the latest "bells and whistles" add ons, latest technology, sexy appearances, or best computer processor. Basic performance is the only criteria.
I've heard some say the legacy Cambridge units and some say the Sage mechanical.
Which unit did it for you?
Old September 23rd 12, 02:30 AM
Walt Connelly Walt Connelly is offline
Senior Member
First recorded activity by AviationBanter: Aug 2010
You mean there is a vario that can get me centered in and on the top of a thermal? I'll take two and if it can find the thermal for me in the first place I'll take three.
Walt
Old September 22nd 12, 10:35 PM posted to rec.aviation.soaring
On Saturday, September 22, 2012 8:58:15 AM UTC-7, Craig R. wrote:
In your opinion, what was the best performing vario you have ever used? Specifically, the one that got you centered in and to the top of the thermal in the least amount of time. Let's ignore products because they have the latest "bells and whistles" add ons, latest technology, sexy appearances, or best computer processor. Basic performance is the only criteria. I've heard some say the legacy Cambridge units and some say the Sage mechanical. Which unit did it for you?
ClearNav CNv hands down. Work in progress but better than the 302 right now.. Low on flashy displays big on the useful bits.
John Seaborn A8
Old September 22nd 12, 10:47 PM posted to rec.aviation.soaring
John Cochrane[_3_]
ClearNav CNv hands down. Work in progress but better than the 302 right now. Low on flashy displays big on the useful bits.
John Seaborn A8
I second the opinion. Fast, smooth, accurate. And the 302 I found to
be slightly better than the (very good) SN10. Legacy cambridge (s nav,
m nav, l nav) were nowhere near as good. Those are from the 1980s and
were great in their time, but that was a while ago.
No mechanical vario should be on this list no matter how good. You
need to look out the window not stare at a vario.
John Cochrane
Old September 22nd 12, 11:01 PM posted to rec.aviation.soaring
Tim Taylor
Of the older varios I loved the Borgelt B50. Borgelt was a great vario for the time. Not sure what happened that they didn't make the transition over the last few years to the modern systems. B50 is still one of the best values for a low cost panel, about $500 to $600 and a PDA/PNA and it will work nearly as we'll as the new systems.
The ClearNav, V7 and Butterfly are all very impressive. The 302 is a good system (vario, altimeter, computer and logger in one) and could be even better with a software update.
Old September 23rd 12, 12:36 AM posted to rec.aviation.soaring
Tim,
I really liked my B-50; however, it didn't go to Logan with the HP-14. All
the HP-14 instruments went to Moses Lake and will be installed in a Jantar.
"Tim Taylor" wrote in message
Old September 26th 12, 05:15 AM posted to rec.aviation.soaring
Nothing "happened" Tim. We replaced the B50 with the B500 in late 2005 and the B40 (over 1000 sold) with the B400. The B500 and now the B600 and B800 even incorporate GPS navigation, wind and a glide computer. Otherwise they perform the same vario functions but with some extras like the little green light and subtle audio change to tell you when the climb is better than the 20 second average.
The B500 has recently been replaced by the B600(linear vario scale) and B800 (log scale expanded in the +/- 2 knot range) but otherwise similar except for some new features like the visual and audio comparison of the running average climb rate to the whole of thermal so far average, to tell you when to think about leaving, a real Performance Index to tell you how each glide from the top of the last thermal to current position compares to the clean glider at the same weight(helps with "bugs" setting) and the B800 and B600 have
bi-directional comms with color moving map glide computers like XCSoar which means you can make changes on the glide program and have them go straight to the vario and also the other way round.
A Vertica V2 (basically like new Oudie with new bright screen but HALF the price)plus a B600 or B800 main unit makes a very low cost complete X country vario and moving map glide computer system when running XCsoar.
If you want just a vario(no speed to fly) as a standby(mechanical replacement) or for the club single or two seater have a look at our B300 Club vario, B400 vario with standby battery pack, the B700(like B400 but with log scale and both 20 sec and whole of climb average and comparator), the ultimate standby vario which you'll leave running all the time and soon the B900(B700 with linear scale). We've also bench tested the B200 audio add on for mechanical varios as I know some of you won't let go of your favorite mechanical vario until it is pried out of your cold, dead hands :-)
We're also working on some advanced concepts which will make all existing varios totally obsolete but they will be able to be added to our B600 and B800.
Old September 22nd 12, 11:07 PM posted to rec.aviation.soaring
Jim[_32_]
My new ClearNav Vario is magic (even in its incomplete version). Still waiting for the software to be completed and integrated with the ClearNav display. ICG approval is also "still coming".
-Jim
Old September 23rd 12, 12:10 AM posted to rec.aviation.soaring
Dave Springford
ILEC SB9 electric vario, (but they don't make them anymore)
Bohli vario - not sure if they are still made, but the last time I looked they were rather pricey.
LX Nav V5 or V7 vario
Old September 23rd 12, 01:58 AM posted to rec.aviation.soaring
I loved the LNav and think it hard to beat when tuned right.
I have the new ClearNav vario and it is even better.
UH
WTB: 57mm Cambridge Vario/FS: 80mm Cambridge Vario ufmechanic Soaring 0 March 24th 09 06:31 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Aviation Photos 3 January 20th 08 04:10 PM
Martin Mars, Performing Live In Downtown Vancouver! Zomby Woof Naval Aviation 2 January 11th 08 07:10 PM
Navy Performing Well, Keeps Eye on Future Force Otis Willie Naval Aviation 0 February 14th 05 11:06 PM
AN-2 performing a loop Maro_SK Aerobatics 1 March 25th 04 09:18 PM
