Do any commercial gliderports use an .igc trace to log flight times?
Of the commercial gliderports you have been to, how were they keeping track of flight times when they rented a glider to you? I am looking for an electronic way to automatically log rental glider flight times. |
On Monday, March 25, 2013 8:22:40 PM UTC-4, Scott Alexander wrote:
I am looking for an electronic way to automatically log rental glider flight times. http://dittolog.com/learn-about-dittolog/ |
Thanks Dave for that suggestion. Has anyone on this forum used this before?
Looking to help upgrade the local commercial gliderport from an archaic method to an up to date automated electronic method. |
Believe you can also use FLARM and a PDA (etc) to automatically log the release from tow (when the distance between towplane and glider starts to change). Devices can upload the information to the office computer when the towplane is in WiFi range.
Contact Mark Fisher at Swift Avionics. Jim swiftavionics DOT com DOT au |
On Mar 26, 11:30*am, JS wrote:
Believe you can also use FLARM and a PDA (etc) to automatically log the release from tow (when the distance between towplane and glider starts to change). Devices can upload the information to the office computer when the towplane is in WiFi range. Contact Mark Fisher at Swift Avionics. Jim swiftavionics DOT com DOT au Doesn't meet the need of what you're looking for, but I have to give credit them for being original and I certainly can't speak for how well it worked. A few years ago I saw a rental Blanik with a Hobbs meter installed. It was powered by a solar panel and connected to a switch, I believe a repurposed stall warning switch mounted on the exterior of the fuselage. When the glider was flying, the the circut was closed and the meter logged time. Don't know if this actually worked as designed, but found it amusing. |
Hi,
Winter also makes 2 versions of a flight hours meter. You can see details he http://www.cumulus-soaring.com/winte...Hours_Counters Best Regards, Paul Remde Cumulus Soaring, Inc. _________________________________ "RS" wrote in message ... On Mar 26, 11:30 am, JS wrote: Believe you can also use FLARM and a PDA (etc) to automatically log the release from tow (when the distance between towplane and glider starts to change). Devices can upload the information to the office computer when the towplane is in WiFi range. Contact Mark Fisher at Swift Avionics. Jim swiftavionics DOT com DOT au Doesn't meet the need of what you're looking for, but I have to give credit them for being original and I certainly can't speak for how well it worked. A few years ago I saw a rental Blanik with a Hobbs meter installed. It was powered by a solar panel and connected to a switch, I believe a repurposed stall warning switch mounted on the exterior of the fuselage. When the glider was flying, the the circut was closed and the meter logged time. Don't know if this actually worked as designed, but found it amusing. |
Warner Springs, CA tracks the times.
They note the time that you pass by the office window under tow, and again on landing. So far it's always within a minute of the time hack I make from takeoff to landing. On Monday, March 25, 2013 5:22:40 PM UTC-7, Scott Alexander wrote: Do any commercial gliderports use an .igc trace to log flight times? Of the commercial gliderports you have been to, how were they keeping track of flight times when they rented a glider to you? I am looking for an electronic way to automatically log rental glider flight times. |
Logging Glider Flight Time | RN | Soaring | 9 | August 7th 12 04:31 PM |
Rules for Logging Glider PIC Time | Markus Graeber | Soaring | 7 | January 8th 12 12:30 AM |
Glider Rental Insurance: | Tony V | Soaring | 1 | August 18th 10 05:06 PM |
Glider Rental Insurance: | BTiz | Soaring | 0 | August 18th 10 04:53 AM |
Glider Rental Insurance: | Walt Connelly | Soaring | 5 | August 18th 10 02:03 AM |
