Spin Training
Old April 8th 04, 08:47 PM
Captain Wubba
Default Spin Training
Hello. I'm finishing up my CFI training. My CFI and I went up in a 172
(certified for spins) and tried to get the plane to spin for my spin
training. The airplane was loaded properly in the utility category. We
could not get the airplane to enter a fully developed spin. It would
enter the incipient stage just fine, but would not remain in the spin
for even one complete rotation. My CFI is very experienced, and has
spun this airplane numerous times before with other students. Part of
the problem may be that I weigh about 300 lbs (and am 6'6 tall), so we
are rather forward in the CG department.
What exactly are the definitions of 'spin training' that the FAA
requires for CFI logbook endorsement? I am having trouble locating
specific definitions. Does entry into and recovery from an incipient
spin count? Does it need to be a fully developed spin (with a minimum
number of turns). While I would truly love to experience some
fully-developed spins, I *did* recover correctly from the incipient
ones, both left and right. We have no other planes available that are
certified for spins, and the nearest place I can get dedicated
aerobatic training is quite a few hours away, and rather difficult to
schedule. We cannot fit into a 152 without being significantly over
the max gross weight.
While I want to do this right, I don't want to put my training (I am
almost ready for the checkride) on hiatus for several months while I
find a way to coordinate schedules and travel to the place with the
Citabria.
Any ideas, comments or suggestions?
Thanks,
Cap
Old April 8th 04, 08:57 PM
EDR
I cannot tell you what the FAA requirements are, but I will tell you
that with two full size adults in the airplane, you cannot have full
fuel onboard a Citabria/Decathlon and be with in the legal CG.
Make certain you play with the W&B before you fly.
Old April 9th 04, 09:39 PM
Robert M. Gary
So what? Why would you ever put full fuel in a Decathlon? The extra
fuel is for cross countries. We usually just kept 10 gallons in it.
When I did my CFI I went up and did 2 upright spins (each direction )
and 2 inverted spins (each direction). What a blast! I was already a
Decathlon pilot so I did some loops and rolls before heading back. We
probably burned 4 gals. Not too many people have the internal guts to
fly more than 45 minutes in a D anyway.
-Robert, CF
EDR wrote in message ...
Old April 8th 04, 09:47 PM
Leslie M. Watts
Hi Cap
I am just a PPASEL, but I requested some spin training from my CFI after
I got my PPL. Same plane- C172. Two up front and half full tanks per the
manual. I only weigh 130 or so.
I also found that the aircraft would not fully develop a spin. The only way
I
could get even an incipient spin was full power and a skid to the left (full
left
aileron and rudder) at an extreme nose up attitude... Thirty or forty
degrees.
Within one turn an extreme spiral dive would begin if I held the contols
full left.
This in itself was a little scary as VNE was only a few seconds away.
I can't say the experience really prepared me for spin recovery procedures
since
I was just doing wing drops and spiral dives that I just flew out of in a
normal
manner.
I do not consider that the C172 is virtually spinproof although it seemed
that way
at the time. I'll bet with a more aft (but in range) CG it would spin real
good...
but I'm not gonna try it of course.
Leslie M. Watts
L M Watts Furniture
Tiger, Georgia USA
http://www.alltel.net/~leswatts/wattsfurniturewp.html
Engineering page:
http://www.alltel.net/~leswatts/shop.html
Surplus CNC for sale:
http://www.alltel.net/~leswatts/forsale.html
"Captain Wubba" wrote in message
om...
Citabria.
Thanks,
Cap
Old April 8th 04, 09:53 PM
EDR
My question is:
Are you holding FULL aft elevator, FULL left or right rudder and
neutral ailerons?
Old April 8th 04, 09:45 PM
N. Funk
I know when I did my spin training, I would have to enter the spin
pretty aggresively, especially if you wanted to a right spin. I would
have to do more than a typical 1g stall, by using additional airspeed
and momentum to pull the nose up higher to induce a stall. At the exact
moment of stall I would stomp on the rudder. Sins to the left was
easier then the spins to the right. Spins to the right the plane would
always wanted to pop out and you really have to old the plane in the
spin.
Citabria.
Thanks,
Cap
Old April 9th 04, 01:28 PM
EDR
In article , N. Funk
Sins to the left was easier then the spins to the right.
This isn't one of those Liberal, Democrat aircraft is it? ;-)
Old April 8th 04, 11:45 PM
Stefan
I don't know the regs. But frankly, I think a flight instructor who's
not current on spins isn't qualified to instruct, whether the regs
require it or not.
Here in Switzerland, flight instructors are required to hold a full
aerobatic rating before they can apply for the instructor rating, and
I've always thought this was reasonable. At least it was so before we
joined JAR, it may have changed now.
BTW: I always read the term CFI (certificated flight instructor). This
rises the question: Is there such a thing as an uncertificated flight
instructor?
Stefan
Old April 9th 04, 09:42 PM
Robert M. Gary
Stefan wrote in message ...
instructor?
Yes. You can receive instruction from military instructors in some
cases that are not CFIs (not certified as instructors by the FAA). You
can also be a CGI (ground instructor). The main reason we call it a
CFI is because that is what the FAA prints on the ticket, "Certified
Flight Instructor". Back in the pre 1970's days people just had
"Flight Instructor" as a rating on the pilot's ticket. Nowadays a CFI
is a different ticket, different piece of paper in your pocket from
your pilot's cert.
-Robert, CFI
PC flight simulators Bjørnar Bolsøy Military Aviation 178 December 14th 03 12:14 PM
Cessna 150 Price Outlook Charles Talleyrand Owning 80 October 16th 03 02:18 PM
