Question on 172 M electrics... (1974 Skyhawk II)
Old April 9th 04, 01:57 AM
Default Question on 172 M electrics... (1974 Skyhawk II)
Hi All!
We do not have a wiring diagram (yet) for our plane.
The Cigar Lighter socket is dead, and we need to fix it to
power our new portable GPS. (or have a poower cable installed....)
Which 12V point (bus) should it be wired to? (dont want to
unwrap the harness to check out the wiring. )
Inline fuse or one of the panel breakers?
Would it have been disconnected for some reason?
(I have heard there was an AD on some aircraft to disco it)
TY!
Dave
Old April 9th 04, 04:14 AM
Found it! discoed in 1983...
Looks like it can be reconnected if we install a fuse or
breaker in line...
Can anybody confirm this?
Dave
On Fri, 09 Apr 2004 01:07:13 GMT, "G.R. Patterson III"
Yep. As you've heard, there was an AD (at least in the U.S.) to either put it on its
own circuit breaker or fuse or to disconnect it. Most owners opted to disconnect it.
I don't know Canadian practice, but in the States there would be an AD log in the
back of the airframe logbook. Check the text of all those shown as complied with
until you find that one. I've been told that you can reactivate the outlet by adding
a breaker, but you'd need to check the AD text to be sure.
George Patterson
This marriage is off to a shaky start. The groom just asked the band to
play "Your cheatin' heart", and the bride just requested "Don't come home
a'drinkin' with lovin' on your mind".
Old April 9th 04, 07:24 AM
C J Campbell
breaker in line...
Sure. Just install a fuse or breaker. The fuse is probably easier.
Old April 9th 04, 06:03 PM
Newps
Bill Zaleski wrote:
You must have a mechanic perform the work in accordance with the AD
and sign off the compliance.
Anybody can do the work, the mechanic must sign it off.
Old April 10th 04, 01:19 AM
Bill Zaleski
Yes, correct to the extent that you describe, but not only must the
mechanic sign it off, but he must personally observe the work being
done before it is signed off. After the fact maintenence sign-offs,
though common, are illegal. Guess you want the reference? FAR 43.3
(d)
I should have used the word "inspect" instead of perform. Sorry.
VOR/DME Approach Question Chip Jones Instrument Flight Rules 47 August 29th 04 05:03 AM
ICom A-5 Question - Battery Level Indicator Harry Gordon Piloting 22 December 5th 03 12:07 AM
Legal question - Pilot liability and possible involvement with a crime John Piloting 5 November 20th 03 09:40 PM
T Tail question Paul Austin Military Aviation 7 September 23rd 03 06:05 PM
