Oxygen Generators
Old September 23rd 13, 05:23 PM posted to rec.aviation.soaring
JohnDeRosa
Default Oxygen Generators
Has anyone investigated the use of an oxygen generator rather than carrying an O2 cylinder?
According to this study from sea level up to 18,000 it seems to work. http://oai.dtic.mil/oai/oai?verb=get...er= ADA371747
"We conclude that from sea level to 18,000', molecular sieve based O2 concentrators are capable of providing medical grade supplemental O2 for at least 8 hours."
Pricey but for those the fly with O2 every day then over the long term it would be cheaper as there would be no refills. Here is a unit for $3K. http://www.emedstores.com/xpo2-porta...extra-battery/
Might they be less dangerous in an accident? Is battery power an issue?
- John
Old September 23rd 13, 06:56 PM posted to rec.aviation.soaring
Vaughn
The devil is in the details! But the specks on that unit say 10,000 feet.
These things are mostly made for airline travel. I don't think we've
ever seen more than about 6,000 feet cabin altitude inside an airliner,
(Yes, I travel with an altimeter) so there is little incentive for the
manufacturer to make them work much higher, or even test them at high
altitudes.
My wife needs to travel with oxygen. We have rented several different
Portable Oxygen Concentrators (POCs) with uniformly good results, and
finally bought our own. Assuming pulse oxygen delivery, we get
excellent battery life on trips.
Try before you buy! You can easily rent these units. Fly one with with
a pulse oximeter ($39.99 at Walmart) to verify that it works for you and
to determine your settings. The settings have a big impact on battery life.
Vaughn
Old September 23rd 13, 11:39 PM posted to rec.aviation.soaring
JohnDeRosa
On Monday, September 23, 2013 12:56:34 PM UTC-5, Vaughn wrote:
Fly one with with a pulse oximeter ($39.99 at Walmart) to verify that it works for you...
Vaughn
Actually only $35 at Walmart.
http://www.walmart.com/ip/Choicemmed...r-1ct/17325061
Old September 26th 13, 08:10 PM posted to rec.aviation.soaring
On Monday, September 23, 2013 2:39:28 PM UTC-8, JohnDeRosa wrote:
On Monday, September 23, 2013 12:56:34 PM UTC-5, Vaughn wrote: Fly one with with a pulse oximeter ($39.99 at Walmart) to verify that it works for you... Vaughn Actually only $35 at Walmart. http://www.walmart.com/ip/Choicemmed...r-1ct/17325061
Pulse oximeters are poor indicators of O2 saturation for glider pilots. Peripheral (as in fingers)vaso-constriction is common at the temperature and altitudes we fly. I used one for a few years and was over consuming Oxygen in an effort to keep the saturation above 95%. I use a EDS delivery system and consistantly got values of around 86% when above 6000 feet. I actually went to a Pulmonologist to see what, if anything, was wrong with my lungs and found that my lung capacity and ventilation were above normal. So I tossed out the oximeter and just trust the equipment to deliver the right amount of O2. So far so good.
Old September 27th 13, 04:49 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Oximeter issues
wrote, On 9/26/2013 12:10 PM:
O2. So far so good.
Since I can keep O2 saturation above 95% at even 18000' using the normal
EDS settings, does that mean I have excellent circulation? Or really
good lung function?
It does drop into the 90-95% range sometimes, but that's also when I
realize my breathing is very shallow; i.e., I don't seem to be inhaling
very much after I hear the "poosh" of the EDS oxygen pulse.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old September 27th 13, 05:57 PM posted to rec.aviation.soaring
That's amazing at your age Eric. Probably a defective oximeter.
Old September 30th 13, 12:47 AM posted to rec.aviation.soaring
son_of_flubber
good lung function?
It could also mean that you breathing too rapidly or deeply (mild hyperventilating). Hyperventilation will dilate your finger blood vessels and RAISE the pulse oximeter saturation number. And hyperventilation will simultaneously constrict your cerebral blood vessels, and thereby LOWER the O2 saturation of the blood going to your brain (thereby inducing mild hypoxia). Vasodilation may also lower the temperature of your core and induce the mental dulling effects of mild hypothermia.
See http://www.danlj.org/~danlj/Soaring/...-p18-20-22.pdf
If you're making any conscious effort to "breath", you may be mildly hyperventilating.
A common way to breath at the correct rate is to talk (or sing) out loud, this distracts you from thinking about your respiration rate. The autonomic nervous system works best without conscious or emotional intervention.
Old September 30th 13, 05:15 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
O2. So far so good.
good lung function?
email me)
I think it probably means you are in good health and have good equipment and procedures.
I've experience hyperventilation induced hypoxia. You will feel horrible. Tingling extremities, headache, and yeah... a fingertip pulse ox reading of 92 - 95%.
Unmentioned so far... hypoxia comes with tachycardia. So when you see 92%+ saturation but 110 - 120 pulse rate, there's your confirmation. If you have a decent quality (e.g. Nonin) pulse ox, you see a strong pulse indication, high saturation, pulse below 90 and you feel normal and alert, you are doing it right.
-Evan Ludeman / T8
Old September 23rd 13, 07:28 PM posted to rec.aviation.soaring
Bob Kuykendall
The late Les Sebald carried a chemical oxygen generator of the type used on airliners as a backup oxygen source in his HP-14. He worked for United Airlines, and I imagine that he had access to expired units that were out of date but probably still good. I remember seeing that Les's O2 generator was carefully mounted so that the airframe was protected from the rather high heat generated as a byproduct of the chemical reaction that produced the oxygen.
Thanks, Bob K.
Old September 23rd 13, 09:24 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
JohnDeRosa wrote, On 9/23/2013 9:23 AM:
unit for $3K.
issue?
Not a cost saver for glider pilots that fill their own bottles. I can
fill my 14 cf bottle for $5 from my welding bottle, then get 12 hours
off of it. It would take a lot of refills to pay for the $3000 unit.
I haven't heard of ox cylinders being a danger in glider accidents, so I
don't think the ox generator would help any.
I suspect it might not work well in flights where the cockpit
temperature goes below freezing, but did not look into it.
email me)
Vortex generators? Waveguru Soaring 3 December 17th 12 04:21 PM
Generators that use Wind power. a[_2_] Home Built 6 July 17th 08 02:36 AM
vortex generators. Stew Hicks Home Built 2 July 17th 06 12:56 AM
Vortex Generators Source Pietpilot Home Built 0 August 14th 04 10:35 PM
Generators, redundancy, and old stories Michael Owning 2 March 3rd 04 06:25 PM
