Introductory acrobatic lesson - long
Old June 7th 04, 05:34 AM
Jack Allison
Default Introductory acrobatic lesson - long
I'm a lucky guy. For my b-day this year, my wife bought me an hour of
introductory acrobatic time at a semi-local FBO (Attitude Aviation,
Livermore, CA). I decided to go up in their Super Decathlon. So,
yesterday, I took the opportunity to experience several "firsts". My first
tail wheel experience, first tandem seating experience, first time flying
anything with a stick vs. yoke, first time flying with a constant speed
prop, first time strapping on a parachute. Basically, my first time flying
anything but a C-172/152 and doing more than a steep turn. Hey, at least it
was still a high wing...I haven't crossed over...yet :-)
Of course I had to fly from my home airport instead of drive. It was a
great morning to fly and enjoy the views of the delta area and the back side
of Mt. Diablo. It had been about a month since I'd flown so felt great
getting back in the air. I even pulled off a decent landing on the short
runway at LVK. First time I'd been to LVK despite having flown over it
several times.
I had a chance to get acquainted with the Decathlon for about 20 minutes
before my instructor returned from his previous lesson. I looked over the
POH, sat in the plane (without making airplane noises) and kept thinking
"wow, this different...really different". Peter, my instructor showed up
and we got started with some more aircraft orientation, pre-flight
procedures, parachute familiarization, bail out procedure, etc. Now there's
something to think about. If I hear the words "BAIL OUT BAIL OUT BAIL OUT",
I need to remove my headset, release the 5-point seatbelt harness assembly,
pull the door release pin, then fall out of the airplane head-first...then,
of course, find the release handle on the parachute (evidently, it can come
out of it's velcro-pocket and be hiding underneath and behind your left
arm...fortunately, I'm learning this with both feet firmly planted on ground
instead of while free-falling). It all sounds simple enough but I can
imagine how difficult it must be in the panic of a live bail out scenario,
especially if you're spinning or somehow being tossed about in the airplane.
Ok, so after we get our parachutes on, it's time to climb in the airplane.
And I thought it was difficult without the parachute. I get to start up and
taxi out. For those students who are being challenged to keep a tricycle
gear plane on the yellow line, that's absolutely nothing compared to taxiing
in a tail wheel plane. Much more of a challenge. Fortunately, it's about
100 yards to the run up area.
My instructor handles the takeoff which is interesting since your view of
the world changes dramatically when the tail wheel comes off the ground.
Once we're about 200 ft. AGL, he gives me the airplane and I manage an
uncoordinated right crosswind departure. Man, it's tough keeping the ball
in the cage. Oh, ya, another first, seeing a turn coordinator for regular
and inverted flight. As we climb out toward Mt. Diablo, I get to run
through some S-turns and basic coordination drills. After 5 minutes or so,
I start to figure out that it takes lots of rudder to keep things
coordinated.
Once we're at 7000 MSL in the practice area, we line up on a ridge below us
and it's time for loops. My instructor demonstrates the first one. Lower
the nose, I read off airspeed and when we hit 130, hard pull up (and I learn
what 4 Gs feels like for the first time), float over the top (look left and
right, verify wings are level...but, wait a minute, everything is upside
down :-) ), look up through the top window, pickup up the ridge line on the
ground, and recover. Very cool. Way better than any roller coaster I've
been on. Now, it's my turn. While I manage to keep the wings level, I
didn't pull up hard enough (hit just under 3 Gs on the pull up) and we were
a bit slow over the top...but hey, I did my first loop. I do a couple more
and manage to get better with each one.
Next up, aileron rolls. Pitch up 30 degrees, neutralize the stick, full
deflection (to the left in this case), wings level, neutralize ailerons,
recover from approx. 30 degrees nose down pitch attitude. Sounds simple
enough, now it's my turn. I pick a point on the horizon, imagine a vertical
line up through it, pitch up, think I neutralize the stick (I didn't, had
some back pressure), full left deflection, and the nose traces a big circle
around my point on the horizon. I get to try a few more and when I really
neutralize the stick prior to full left deflection, I manage pretty decent
rolls. It's very cool to see the world spin around in front of you.
Next up, my personal favorite for this ride...spins. This is the one thing
I most wanted to experience because, during the PPL training, you get the
head knowledge on how to recover from a spin but are not required to
physically recover from a spin. My instructor demonstrates the first spin.
Slow to 55 MPH, full left rudder and bam, the plane rolls over to the left,
points down and I'm watching the world spin around while pointed at the
ground. After 2.5 revolutions, full right rudder, neutral stick, revolution
stops, neutral rudder (this is the part I'll forget when I get to do them),
slight forward stick, then recover from the dive. Wow, that was *very*
cool. Now it's my turn. I forget to neutralize the stick when we enter the
spin and as a result, we get into an accelerated spin. When I go to
recover, I forget to release full right rudder (fortunately, we didn't start
a spin to the right). By now, I'm thinking this is great experience but it
sure is easy to mess up when recovering from a spin. I do one more and
it's
about the same as my first one except my instructor has to assist in the
recovery a bit more than the first one. Evidently, I like accelerated spins
more than the garden variety :-) By now, my brain is on serious overload
and I'm feeling ever so slightly queasy. Not like I'm going to hurl any
minute or anything but a bit light headed and very slight upset stomach.
I'm thinking it's about time to call it quits...but not after some hammer
heads.
My instructor demonstrates a nice hammerhead. Pitch down, airspeed to 130,
pull up to the vertical, look left and right, full left rudder when the
string on the strut begins to luff, recover after you're pointing straight
down. My turn. I pitched up beyond vertical and it felt more like a loop
that we fell out of at the top than anything else. I can imagine what it
must have looked like from outside the airplane.
By now, the upset stomach and light headed feeling are a little stronger so
I decide to call it a day. We head back to LVK and my instructor handles
the landing. Of course, since I'm up front, I get to taxi back to parking.
And, once again, I'm thinking that taxiing in a tricycle gear plane is a
piece of cake compared to this. I mange to keep it pretty much on the
yellow line though.
We debrief and I learn that many first time acrobatic rides only last .3 or
..4 hours. We managed 1.1. My instructor thanks me for calling it early
once I felt like I did. He tells me that I'd most likely acclimate and that
it's not uncommon to get similar feelings of nausea when you do acrobatics
for the first time.
Overall, this was a great experience. I can see why folks get hooked on
acro. If I lived closer to LVK, I could see myself getting checked out in
some of their planes and doing this on a regular basis. It's a ton of fun
and I'd highly recommend anyone to find an acro instructor and, at a
minimum, go through some spin training. It was a great experience and I'd
do it again in a heartbeat.
Jack Allison
PP-ASEL
"When once you have tasted flight, you will forever walk the Earth
with your eyes turned skyward, for there you have been, and there
you will always long to return"
- Leonardo Da Vinci
(Remove the obvious from address to reply via e-mail)
Old June 7th 04, 06:23 AM
Roy Epperson
Great post! It's great that you got to experience acrobatics.
Your spin experience reminds me how much I use to enjoy spinning (spin
rated) planes. I remember once during the Vietnam war era, I was out doing
some spins, cleared area, and as I entered the first turn a jet fighter went
under me on a knife edge. Needless to say, I recovered and went back to the
airport.... put me in my "place".
This was in San Luis Oblispo, CA and it was all too common for recent Cal
Poly grads who were Air Force or Navy recent fighter grads would come back
and straff the campus. I'd seen him off in the distance straffing the
campus during one of my climb outs to do another spin. Needless to say, he
saw me too...
Old June 7th 04, 05:23 PM
G.R. Patterson III
I sincerely hope you mean a low pass, rather than strafing. Strafing is shooting at
something on the ground.
George Patterson
None of us is as dumb as all of us.
Old June 8th 04, 05:09 AM
Roy Epperson
"G.R. Patterson III" wrote in message
shooting at
I stand corrected....
Old June 7th 04, 06:43 AM
tony roberts
Livermore, CA).
Hi Jack
Mine was cancelled due to lousy weather
But - next week . . .
Glad to hear that it went so well,
Tony
Tony Roberts
PP-ASEL
VFR OTT
Night
Almost Instrument
Cessna 172H C-GICE
Old June 7th 04, 06:54 AM
Philip Sondericker
in article nospam-095D74.22464006062004@shawnews, tony roberts at
wrote on 6/6/04 10:43 PM:
Hi Jack
Let's greet Mr. Allison with "Hello", "Tally-ho" or "Salutations" from now
on, shall we?
Old June 7th 04, 07:18 AM
John Harper
So I think I must have flown the Decathlon shortly before or after
you... what time did you fly? I had an interesting experience, that
I'm NOT in a big hurry to repeat. I did a fairly unsatisfactory
Immelman and as I was recovering from the resulting
partial split-S, the stick wouldn't come back. Fortunately I've
been taught to expect the rear stick to get tangled up in things
so I groped around behind me and discovered that the soft
cushion on the rear seat squab had come adrift and was blocking
the stick. Once I dislodged it things worked properly and I
recovered, but I figured that further acro wasn't prudent.
It's interesting because I've got Immelmans to the point where
they're routine. But (following a discussion on this newsgroup)
I started trying to fly loops at exactly 3G and tried that
with Immelmans too. Not cool. You lose too much speed and
just kind of fall awkwardly off the top. (3G *loops* are
really nice, they feel very elegant). Sometimes you start to spin,
other times you just split S, but either way Max wouldn't have
been proud of me.
One of the real defining moments of acro is when you get into
an inadvertent spin and recover without really thinking about it.
Acro is a lot of fun but in addition it really gives you confidence
handling the plane. And the Decathlon is a great plane for it,
it has enough performance to keep you busy but it's very hard
to get yourself into serious trouble.
Glad you had fun!
John
"Jack Allison" wrote in message
first
flying
it
side
several times.
there's
OUT",
assembly,
head-first...then,
come
ground
airplane.
and
taxiing
so,
coordinated.
us
learn
and
were
more
vertical
circle
thing
spin.
left,
revolution
them),
start
it
it's
spins
heads.
130,
so
parking.
yellow line though.
or
that
for the first time.
Jack Allison
PP-ASEL
- Leonardo Da Vinci
Old June 7th 04, 02:58 PM
Dudley Henriques
"John Harper" wrote in message
news:1086589290.295808@sj-nntpcache-3...
been proud of me.
Glad you had fun!
John
Hi John;
Am I assuming correctly that you had trouble with the rear cushion even
though the rear harness and belt were as tight as they could be
tightened and CONNECTED over the cushion for solo aerobatics?
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
Old June 7th 04, 03:48 PM
MLenoch
D:
Had another dead stick with the 51 this weekend.
V
Old June 7th 04, 04:15 PM
Dudley Henriques
"MLenoch" wrote in message
D:
V
Close in to the field I take it? Oil pressure or coolant?
Dud
Ultralight Club Bylaws - Warning Long Post MrHabilis Home Built 0 June 11th 04 05:07 PM
SWRFI Pirep.. (long) Dave S Home Built 20 May 21st 04 03:02 PM
SWRFI Pirep.. (long) Dave S Piloting 19 May 21st 04 03:02 PM
IFR Long X/C and the Specter of Expectations David B. Cole Instrument Flight Rules 0 February 24th 04 07:51 PM
Long Range Spitfires??? ArtKramr Military Aviation 3 September 9th 03 10:05 PM
