Loading luggage in other than Mooney
Old June 25th 04, 06:12 PM
Robert M. Gary
Default Loading luggage in other than Mooney
The other day I saw a guy drive up to his Bonanza with a car load of
bags. This is something I've done for years in my Mooney but many
years since I've flown a Bonanza or Cessna. In my Mooney, the baggage
door opens at the top of the cabin (the door is long enough that it
goes down to the middle and opens like a clam shell, much like a car's
trunk). I can easily load heavey bag on top of heavy bag in the Mooney
by dropping them down on top of each other. How did I do it back in
the Bonanza days? It looks like I must have had to load a bag in the
bottom door , reach in, hold that bag up and then slide another bag
under it. Or perhaps I climbed in through the back seat and loaded the
bags that way.
How do most of the Bonanza/Cessna pilots here do it? Why would anyone
put a baggage door on the bottom of the baggage area. Its like loading
your truck though a little hole near the license plate on your car.
-Robert
Old June 25th 04, 07:31 PM
Steve Robertson
Why would anyone build a plane with manual gear and hydraulic flaps, like
many Moonys? Why would anyone build a plane with only one door like
Cherokees, Moneys, and most Beechcraft? Why would anyone build a plane
with the wing on top? Why would anyone build a plane with the wing on the
bottom? Why ... ?
Look, I think your question is probably a tounge-in-cheek jab at Bonanza
drivers. But it comes off as pretty close to being a troll. It would be
pretty impractical to put a top hinged baggage door on a Bone because the
top of fuselage is several feet higher off the ground than a Mooney. Maybe
Cessna could have done it, but I suspect the engineering and production
costs of such a feature would result in a higher price.
By the way, why do they stick the tail on backwards on Mooneys?
Steve Robertson
N4732J 1967 Beechcraft A23-24 Musketeer Super III
bags that way.
-Robert
Old June 25th 04, 08:17 PM
tony
Didn't you know? We Mooney jocks like our tail backwards.
AJW
Old June 25th 04, 09:21 PM
gatt
"tony" wrote in message
LOL! There HAD to be a comeback 'cause I'm sure Steve isn't the first
person to look at a Mooney tail and think "wtf is up with that?"
-c
Old June 25th 04, 09:02 PM
Marco Leon
Stand down there Steve. Why are you so harsh? I think Robert had a
legitimate question and it partially applies to Cherokee drivers (although
putting very heavy bags in the baggage area of many Cherokee models isn't a
great idea). Also, I'm sure he would have thought up a better subject in
which to slam Bo and Cessna models.
BTW, I heard--probably from this newsgroup--that the Mooney tail design was
for better handling at higher angles of attack (say in a flare).
Marco
"Steve Robertson" wrote in message
bottom? Why ... ?
Steve Robertson
bags that way.
-Robert
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old June 25th 04, 08:35 PM
kage
That's easy cause your 201 won't hold much. A couple of tooth brushes and
underwear maybe!
I don't remember my Mooney 1977 201 (N201MW), other than it didn't hold much
weight. Everything in aviation is a compromise. In my Cessna 185 I give up a
little speed to my Mooney. But after I load 8 hours of fuel (92 usable), and
four FAA passengers (170#) I can still load 180 pounds of baggage.
Try that in your Bonanza! Further, my 185 is a PIG, as far as weight. Dual
IFR GPS, G330-TIS TXP, KX-165A, HSI, DME, ADF etc etc. OK, so I can only go
140 knots. But at least my stuff comes along with.
Best,
Karl
m...
bags that way.
-Robert
Old June 27th 04, 10:12 PM
Robert M. Gary
"kage" wrote in message ...
underwear maybe!
I have a 1000 lbs even of useful load in my Mooney. I only drink 10
gal/hr so I don't need as much gas.
-Robert
Old June 25th 04, 09:01 PM
Maule Driver
Well, Mooney/Bonanza discussions are a little out of my league ... a bit
below me if you will.
But I'll bet the real reason has to do with Mooney's steel tube cabin cage
versus what I think is a stressed skin (monowhatever) structure on the
Cessna's and Bo's. I think that steel tube structure is what tends to be
corroded on older Mooneys.
My Maule has a cargo door almost as big as the other 3, yes 3, passenger
doors. Tube and fabric allows that easily.
We pile 4 in there, 70lbs of luggage in the back, another 20 with the
passengers, and 4 hours of fuel. It's just going so slow that we need the 4
hours to get anywhere.
But put 2 in and *anything* you could possibly want with 4.5 hours. It's a
clean machine!!
m...
bags that way.
-Robert
Old June 25th 04, 10:31 PM
Dan Luke
bags that way.
I use a hydraulic ram, a chainsaw and vaseline to make suitcases fit
through the baggage door on the Cutlass.
Dan
C172RG at BFM
Landing a Mooney Jon Kraus Owning 42 November 16th 04 08:00 PM
Mooney M20 K on Grass ? Andrew Boyd Owning 0 August 13th 04 04:00 PM
that Mooney in DC ADIZ Cub Driver Piloting 10 November 13th 03 10:15 PM
Can someone explain wing loading? Frederick Wilson Home Built 4 September 10th 03 03:33 AM
Cirrus vs Mooney Charles Talleyrand Owning 6 July 9th 03 12:35 AM
