Benchtops & Shelving
Old March 3rd 04, 08:06 PM
Jim Weir
Default Benchtops & Shelving
I'm about to start building the "furniture" for the hangar. After a lifetime of
building "manly" workbenches out of DF 4x4s milled to take 2x4 crossmembers, and
having the concomitant rot and deterioration of wood, I'm considering making the
framing out of 1¼ PVC Schedule 40 pipe and fittings. The problem is what to use
for the bench tops and shelving underneath.
So far, all my "heavy duty" workbenches have been made out of 3/4" plywood with
a 2" doubler plate along the front and back, and my electronic workbenches have
been either solid core or hollow core doors with an appropriate varnish or Deft
coating on them.
However, since I'm going to a new method of framing, I'd like thoughts on what
you have used as workbench/shelving materials. The benches will be about 2'
wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick
and cheap is high on the list of attributes I'm looking for.
Thoughts appreciated.
http://www.rst-engr.com
Old March 3rd 04, 08:30 PM
Gary Thomas
coating on them.
Just out of curiosity what's wrong with "manly" workbenches? And why
would DF 4x4's
rot away during your lifetime in a hanger that one presumes is dry
enough to do good
work on an airplane and/or anything else? I'd stick with the "manly"
frame and use
replaceable particle board tops. When driving something apart with a
"meanit" hammer
there's nothing like a good stout structure underneath. Shelving and
storage
compartments can be lighter duty but a workbench is for WORK. The first
time you set
something heavy on that pvc base you'll remember with fondness those old
"manly" benches:-)
Gary Thomas
Old March 4th 04, 06:28 AM
would DF 4x4's rot away during your lifetime in a hanger that one presumes
is dry
enough to do good work on an airplane and/or anything else? I'd stick
with the "manly"
frame and use replaceable particle board tops.
I agree. 25 years ago I built a workbench in my unheated garage. It has a
framework of untreated 2X4s and a screwed-down benchtop of 3/4 inch particle
board. Legs are 4X4s. Despite our damp Pacific Northwest climate, it seems
as strong today as when it was built.
-Elliott Drucker
Old March 3rd 04, 09:24 PM
Mike Z.
My favorite bench is still 2x4 legs, 2- 2x6 stringers under the top (add a couple cross braces) a top glued up of about 3-4 layers
of particle board to around 2+ inches thick. Then just nail a couple cross pieces in the legs and lay on a shelf.
Build it like a dock. Fast, easy, sturdy as heck and pretty cheap. You can stiffen up the shelf with a 2x4 glued and nailed on each
edge so it won't sag.
Probably can't in your hanger but even easier if you can nail or screw one stringer to the wall.
Mike Z
"Jim Weir" wrote in message ...
coating on them.
Old March 3rd 04, 09:32 PM
Del Rawlins
on what you have used as workbench/shelving materials. The benches
will be about 2' wide and 6' long. Yes, I know, solid moulded Teflon
would be best, but quick and cheap is high on the list of attributes
I'm looking for.
I know you are looking for something other than wood, but these are my
favorite workbenches:
http://www.eaa1000.av.org/technicl/w...l/worktabl.htm
Cheap will depend on the cost of materials in your locality, but as for
quick I can knock out 3-4 of these in an afternoon/evening. I like to
paint them with cheap latex house paint more to make them easier to
clean rather than prevent rot. If they start to get messed up you can
just run a sander over the tops and paint them again. If you want a
special benchtop just lay some mdf over the top and when it gets messed
up, turn it over.
Del Rawlins-
Remove _kills_spammers_ to reply via email.
Unofficial Bearhawk FAQ website:
http://www.rawlinsbrothers.org/bhfaq/
Old March 3rd 04, 10:13 PM
B2431
of
and
use
with
have
Deft
coating on them.
what
As for the top a removable surface is nice. My bench has 2 layers of 1/2"
plywood glued together (it was free) and a layer of masonite screwed on on top.
If the surface gets damaged or wears I can easily remove and replace it. If I
were using it only for electronics I'd just lay a sheet of linoleum or similar
using no screws or glue. The frame of my bench is rabitted to accept the top so
the linoleum would not slide off if I used it. You can just lift it out to
replace it.
Dan, U. S. Air Force, retired
Old March 3rd 04, 10:38 PM
Bill Daniels
lifetime of
crossmembers, and
making the
to use
with
have
Deft
coating on them.
what
2'
quick
The best workbench top I have ever seen was an old bowling alley. It seems
that a local alley was damaged by fire but several of the alleys survived.
A friend of mine talked the insurance company into giving him the alleys if
he would remove them to clear the site for rebuilding.
It took a lot of friends with chain saws and a rented truck with a crane but
two of the alleys made it back to his shop and became spar benches. They
were dead flat, about 6" thick, and made of very hard laminated wood. They
sat on welded 2" square steel tube frames. My friend is long dead but the
work benches are probably still in use.
Bill Daniels
Old March 3rd 04, 10:54 PM
Jim Weir
Oooookay, let me try again.
What NONLUMBER bench tops have you ever seen or considered that might work?
I'm not making 747s, fellers, nor am I building spars. The worst I might want
to do is bend up a 4" x 6" bracket out of 5052H32 and drill it with a Harbor
Freight benchtop drill press.
Jim Weir
-However, since I'm going to a new method of framing, I'd like thoughts on what
-you have used as workbench/shelving materials. The benches will be about 2'
-wide and 6' long. Yes, I know, solid moulded Teflon would be best, but quick
-and cheap is high on the list of attributes I'm looking for.
-Thoughts appreciated.
Old March 4th 04, 01:11 AM
G.R. Patterson III
Sorry, I misunderstood. Since you put it that way, none. I do have an old table
saw base and top that I use for metalwork, but I think you will not find one
that's six feet long. Anything else I can think of is either too flimsy or has
a wooden base structure (like Formica kitchen countertops).
George Patterson
A diplomat is a person who can tell you to go to hell in such a way that
you look forward to the trip.
Old March 4th 04, 01:42 AM
Jim Weir
Well, I have a couple I covered with thin (about 16 Ga) sheet steel.
When I want a "soft" top, I drop a piece of plywood on top.
Of course, they are supported by a welded 1 inch steel tube frame, not
PVC pipe and spot welded to the frame.
The sheet steel was given to me and the steel tube cost about $30.
Got any friends in the scrap metal business?
Jim Pennino
Remove -spam-sux to reply.
