![]() I concur. NiCad batteries (with their "memory" flaw) are a technology of the past. Alkaline batteries have a shelf life measured in years, so self discharge is a non-issue, unlike NiCads. Exactly wrong. NiCads don't have a memory problem and alkalines self discharge like crazy. I'd be happy to supply the research data proof on the NiCads and if you want to lose the self discharge problems go with a lithium battery pack. I'd just stick with fresh alkalines for a couple of bucks, and do. |
"Dave Burton" wrote in message
... Exactly wrong. Huh? Describing your own post? NiCads don't have a memory problem Of course they do. Continually charge them before they are fully discharged and you will find they no longer take a full charge. There's a dramatic difference in lifetime between a NiCd battery that is always fully discharged and one that's not, with the always-discharged one coming out way ahead. and alkalines self discharge like crazy. If by "self discharge like crazy" you mean "hold a charge for years", then you're right. Otherwise, you're on crack. I'd be happy to supply the research data proof on the NiCads I've got all the research data proof I need, having both killed NiCd batteries early, and babied NiCd batteries to decade long lifetimes. and if you want to lose the self discharge problems go with a lithium battery pack. Li-ion batteries self-discharge way faster than alkalines. To make matters worse, if you allow them to be stored at full charge, they wind up with a "memory effect" very similar to that found with NiCd batteries (albeit for a different reason). |
There hasn't been a 'memory' problem in nicads for decades. It is an old
tale that is untrue. Over charging NiCAD can cause volatge sag issues but if you have a decent charge that is not a problem. LiION, NiMH on the other hand have a much higher energy density per unit of weight than NiCad but they self discharge very quickly. They also have a finite life of only a few hundred charge/discharge cycles. For radios that sit in your flight bag you are much better to use NiCad's. But even those are discouraged for use because of disposal issues. Cadmium is very bad for the environment. That means the best overall solution is probably NiMH. Scott -- ------------------------------------------------------------------ Scott F. Migaldi, K9PO MI-150972 PP-ASEL-IA Are you a PADI Instructor or DM? Then join the PADI Instructor Yahoo Group at http://groups.yahoo.com/group/PADI-Instructors/join ----------------------------------- Catch the wave! www.hamwave.com "Our enemies are innovative and resourceful, and so are we. They never stop thinking about new ways to harm our country and our people, and neither do we." - George W. Bush ------------------------------------- "Peter Duniho" wrote in message ... "Dave Burton" wrote in message ... Exactly wrong. Huh? Describing your own post? NiCads don't have a memory problem Of course they do. Continually charge them before they are fully discharged and you will find they no longer take a full charge. There's a dramatic difference in lifetime between a NiCd battery that is always fully discharged and one that's not, with the always-discharged one coming out way ahead. and alkalines self discharge like crazy. If by "self discharge like crazy" you mean "hold a charge for years", then you're right. Otherwise, you're on crack. I'd be happy to supply the research data proof on the NiCads I've got all the research data proof I need, having both killed NiCd batteries early, and babied NiCd batteries to decade long lifetimes. and if you want to lose the self discharge problems go with a lithium battery pack. Li-ion batteries self-discharge way faster than alkalines. To make matters worse, if you allow them to be stored at full charge, they wind up with a "memory effect" very similar to that found with NiCd batteries (albeit for a different reason). |
![]() Dave Burton wrote: .... alkalines self discharge like crazy. I've never seen any evidence of this in any appliance I've owned. The battery in my multimeter is still good after 15 years, for example. George Patterson If you want to know God's opinion of money, just look at the people he gives it to. |
Pretty close to right.
Early nicads had a terrible memory problem. Today's nicad chemistry has gone a long way towards solving the problem, but has not completely eliminated it. The main problem with nicads today is shelf life due to self discharge and the nasty chemistry when they go to the landfill. Alkalines (including rechargeable alkalines) have what is called "five year chemistry". That is, they can sit on the shelf for five years and still give rated output when put into service. NiMH are the poor shelf life that you were probably thinking of. Excellent power/weight/size ratio, but very poor in the self discharge arena. Li-ion is probably the best mix of all, but expensive. Jim (Dave Burton) shared these priceless pearls of wisdom: - -Exactly wrong. NiCads don't have a memory problem and alkalines self -discharge like crazy. I'd be happy to supply the research data proof -on the NiCads and if you want to lose the self discharge problems go -with a lithium battery pack. I'd just stick with fresh alkalines for -a couple of bucks, and do. Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
power/weight/size ratio, but very poor in the self discharge arena Is that in terms of only self discharge...ie the power stored quickly goes to zero? Or is it in terms of being stored for long periods of time (and therefore sitting in a discharged state) they are actually ruined permanently? Because I have A BUNCH of these suckers I got really cheap and have been in storage for years......and I'd hate to think they have gone bad for good! take care Bllll |
Jim Weir wrote:
Early nicads had a terrible memory problem. Today's nicad chemistry has gone a long way towards solving the problem, but has not completely eliminated it. The main problem with nicads today is shelf life due to self discharge and the nasty chemistry when they go to the landfill. SNIP NiMH are the poor shelf life that you were probably thinking of. Excellent power/weight/size ratio, but very poor in the self discharge arena. Jim, I need to buy a set of rechargables for my new AvMap EKP-IV. It takes size AAs. I'll basically be running the unit off of aircraft power, and the batteries are just for emergencies. So, every time I fly they'll be being recharged, and very rarely used. Do you recommend Nicads or NiHH? --- Jay -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
I have standardized on NiMH for all my stuff that needs a fair slug of juice to
run -- digital cameras, handheld radios, and the like. For clocks and such that suck microamps, I have standardized on alkaline Renewals (*). If it was mine, I'd use NiMH. I have found the best source to be Thomas Distributing for quality AND price. (*)... and I change the clock batteries throughout the house and hangar at the semiannual DT/ST time change, keeping a spare set charged up a couple of days before. Jim (Jay Masino) shared these priceless pearls of wisdom: - I need to buy a set of rechargables for my new AvMap EKP-IV. It takes -size AAs. I'll basically be running the unit off of aircraft power, and -the batteries are just for emergencies. So, every time I fly they'll be -being recharged, and very rarely used. Do you recommend Nicads or NiHH? - ---- Jay Jim Weir (A&P/IA, CFI, & other good alphabet soup) VP Eng RST Pres. Cyberchapter EAA Tech. Counselor http://www.rst-engr.com |
Jim Weir wrote:
I have standardized on NiMH for all my stuff that needs a fair slug of juice to run -- digital cameras, handheld radios, and the like. For clocks and such that suck microamps, I have standardized on alkaline Renewals (*). If it was mine, I'd use NiMH. I have found the best source to be Thomas Distributing for quality AND price. Thanks! -- __!__ Jay and Teresa Masino ___(_)___ http://www2.ari.net/jmasino ! ! ! http://www.oceancityairport.com http://www.oc-adolfos.com |
![]() Jay Masino wrote: Jim Weir wrote: I have standardized on NiMH for all my stuff that needs a fair slug of juice to run -- digital cameras, handheld radios, and the like. For clocks and such that suck microamps, I have standardized on alkaline Renewals (*). If it was mine, I'd use NiMH. I have found the best source to be Thomas Distributing for quality AND price. Thanks! I use rechargeable Energizer 2300 mAh NiMH in my digital camera and GPS. They take a half hour to charge and probably take about 200 pictures, although that will depend greatly on how much you use the screen on the back of the camera. |
Thoughts on handheld Aviation radios (ICOM vs Vertex-Standard) | Barnyard BOb - | Home Built | 5 | September 8th 04 07:27 PM |
Upgrade handheld GPS, or save for panel mount? | [email protected] | Owning | 7 | March 8th 04 03:33 PM |
Ext antenna connection for handheld radio | Ray Andraka | Owning | 7 | March 5th 04 01:10 PM |
HeadSets, Handheld Radios and GPS's forsale all NEW. | George | Piloting | 0 | January 9th 04 03:01 PM |
HeadSets, Handheld Radios and GPS's forsale all NEW. | George | Aviation Marketplace | 0 | January 9th 04 03:01 PM |
