Handheld battery question
Old September 18th 04, 08:43 AM
RobsSanta
Default Handheld battery question
My brain has totally gone blank for this simple question, I know I should
have paid more attention in school !!!.
I just was given a 12volt 1200mAh battery and a 200mh 3W wall charger by a
friend who is quitting flying. It has been that long since he used the
battery he doesn't remember charging times etc.
So the obvious question is, how long should it take to full charge this
battery using the supplied wall charger ? By the looks of it, the charger
looks like your standard charger, no auto cutofff etc.
Rob.
Old September 18th 04, 09:04 AM
Morgans
"RobsSanta" wrote in message
news:WNQ2d.43479$9Y5.11833@fed1read02...
SNIP
Rob.
Divide 1200 by 200, and the short answer is 6 hours. That is the short
answer.
The wall chargers are sometimes really far off in the real value vs. the
stated value, sometimes 50%, or more. That means it could take 12 hours or
4 hours. You could rig up a splice to test the output with a meter, or you
could charge for varying times and check the battery voltage. When the
battery is reading about 1.28V per cell, after it has rested an hour or so,
it is pretty close to full.
Or you could charge it 8 to 12 hours, and go with it. ;-)
Jim in NC
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.762 / Virus Database: 510 - Release Date: 9/13/2004
Old September 18th 04, 09:08 AM
Peter
I just was given a 12volt 1200mAh battery and a 200mh 3W wall charger ...
Assuming the charger is actually 200 mA (milliamps) then if things were
100% efficient it would take 1200 mA-hr/200 mA = 6 hr to fully charge.
But allow an extra 25% or so for inefficiencies and about 7 - 8 hours
should do if it starts out fully discharged.
Old September 18th 04, 04:53 PM
Chris W
For NiMH and NiCd, you take the battery capacity * 1.4 (I don't know
where the 1.4 came from I just read it somewhere) and then divide it by
the charge rate. That gives you the number of hours. So 1200 * 1.4 /
200 = 8.4 hours or 8 hours and 24 minutes. As others have said that is
assuming the charger "really" puts out 200ma. If you have a good volt
meter and can monitor the charge from time to time, when you slow charge
a NiMH or NiCd battery the fully charged voltage should be about
1.45V/cell while it is on the charger. This voltage will drop to
1.3V/cell or so shortly after the charger is removed. So what I would
do is record the voltage during charge every 20 or 30 min and if it
reaches 1.45V/cell stop charging. If it seems to plateau at a slightly
lower voltage then stop there.
Chris W
Bring Back the HP 15C
http://hp15c.org
Not getting the gifts you want? The Wish Zone can help.
http://thewishzone.com
Old September 18th 04, 11:23 PM
Dave S
Is it proper to multiply the mA rating x the number of batteries/cells?
like.. 2 1200 mA batteries would in theory take 12 hrs minimum?
Dave
by a
Old September 19th 04, 05:50 AM
Chris W
if they hare in parallel yes the mAh rating goes up for the pack, but
normally they are in series, so the pack voltage goes up and the mAh
stays the same.
Chris W
http://hp15c.org
Old September 19th 04, 06:13 AM
Peter Duniho
"Chris W" wrote in message
news:2n73d.69282$mu.28256@okepread07...
stays the same.
He's asking about charging time, not battery life.
Old September 19th 04, 06:46 AM
Chris W
stays the same.
I guess I wasn't very clear was I. If they are in parallel the mAh goes
up and therefor the charging time when charging at a fixed mA rate.
But in series the mAh doesn't go up so the charging time would stay the
same. Of course your charger has to be able to put out a high enough
voltage or the battery will never charge.
Chris W
http://hp15c.org
Batteries, charger for Yaesu handheld - NiCad or NiMH? David Herman Owning 10 November 7th 04 05:30 PM
Handheld battery question RobsSanta General Aviation 8 September 19th 04 04:07 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 03:38 PM
Icom A5 Battery Tester ?? Harry Gordon Piloting 5 January 10th 04 02:29 PM
ICom A-5 Question - Battery Level Indicator Harry Gordon Piloting 22 December 5th 03 01:07 AM
