Hi again,
I have for a colleague a 30-yr old former Air Canada 737 pilot who doesn't take too kindly to questions of my kind ![]() recently about how forward thrust happens, he said that the engine blades simply turn the other direction. With nothing to back up my hunch, I still feel something amiss and implausible in what he said, but if true, I must confess it represents fantastic braking within the engine to first get the blades to a stop spinning, and next spin the other way! Could someone please confirm or deny what my colleague told me? That pilot, by the way, says he has not heard of 'chandelles' or 'phugoids' or even 'angle of attack'. Leaves me thinking that either Denker's book contains non-standard terminology (unlikely) or Canadians use a different set of terms (likely). OR he's feigning to keep me away ![]() Ramapriya |
Ramapriya wrote:
When I asked him recently about how forward thrust happens, he said that the engine blades simply turn the other direction. If by "forward thrust" you mean "reverse thrust" where the air is being pushed toward the front of the plane instead of the back, then yes, the propellers of some aircraft are capable of twisting enough to provide reverse thrust. The C-130 Hercules cargo plane is a good example of this and there are a number of civilian models that have this option, as well. With nothing to back up my hunch, I still feel something amiss and implausible in what he said, but if true, I must confess it represents fantastic braking within the engine to first get the blades to a stop spinning, and next spin the other way! They don't stop spinning nor do they turn in the opposite direction. They simply twist about their axis enough so that the air is pushed in the opposite direction. To demonstrate, drive down the highway with your arm outstretched and your hand flat. Now twist your arm so that the front of your hand (the side facing the wind) is angled up, Your arm will tend to rise. Now twist your arm so that the front of your hand is angled down. Your arm will fall. This is a very simplistic demonstration of what happens with thrust-reversing propellers. -- John T http://tknowlogy.com/TknoFlyer http://www.pocketgear.com/products_s...veloperid=4415 ____________________ |
Ramapriya wrote:
Hi again, I have for a colleague a 30-yr old former Air Canada 737 pilot who doesn't take too kindly to questions of my kind ![]() recently about how forward thrust happens, he said that the engine blades simply turn the other direction. If you're talking about reverse thrust, he's full of it. The engines do not change direction. The exhausted air is redirected forward. Different styles are used on different engine, but there's some sort of device on the rear end of the engine that just mechanically redirects it. Here's sort of a simple "bucket" style: http://sitemaker.umich.edu/thrust.re...deployed_2.jpg The high bypass fans in the later 737's have doors in the cowl, not the greatest but I found this picture of one deployed: http://www.geocities.com/airliners_a...verse_0206.jpg |
![]() Ramapriya wrote: I have for a colleague a 30-yr old former Air Canada 737 pilot who doesn't take too kindly to questions of my kind ![]() recently about how forward thrust happens, he said that the engine blades simply turn the other direction. With nothing to back up my hunch, I still feel something amiss and implausible in what he said, but if true, I must confess it represents fantastic braking within the engine to first get the blades to a stop spinning, and next spin the other way! With propellor aircraft that have this feature, the blades can be tilted such that they blow air towards the front instead of the back. I've not heard that this can be done on fan jets, and it's impossible on true jets. The reverser feature with which I'm familiar on jet engines is a sort of bucket that lowers down over the engine exhaust and turns it around 180 degrees. Could someone please confirm or deny what my colleague told me? That pilot, by the way, says he has not heard of 'chandelles' or 'phugoids' or even 'angle of attack'. Leaves me thinking that either Denker's book contains non-standard terminology (unlikely) or Canadians use a different set of terms (likely). OR he's feigning to keep me away ![]() I'd say that he doesn't want you to ask him questions. Another possibility is that he actually has no pilot experience at all. George Patterson If a man gets into a fight 3,000 miles away from home, he *had* to have been looking for it. |
I got this from the GE webpage:
Thrust Reverser: Thrust reversers serve as an aircraft's main brakes on landing. There are three types of thrust reversers: translating cowl, clam shell and turboprop reverse pitch. All three literally reverse the engines thrust by closing in when deployed by the pilot pushing the air out the front of the engine rather than the back. This motion decreases the speed of the aircraft and is the loud noise you hear when landing. I'm assuming you're mostly concerned with 'jets', then you would be wondering about the clamshell and translating cowl. Clamshells when activated deflect the exhaust forward, and the translating cowl only sends the bypass air forward. A couple of discussions on thrust reversal: http://www.airliners.net/discussions...ead.main/54508 http://www.airliners.net/discussions...ead.main/43007 -lance smith |
maybe that's why he's a "former" 737 pilot...
the piston engine blades on propellers do not "turn the other direction", but they do change pitch enough to create reverse thrust.. on a jet engine, it's a matter of thrust attenuators changing the flow of the air around the engine or exhaust direction BT "Ramapriya" wrote in message om... Hi again, I have for a colleague a 30-yr old former Air Canada 737 pilot who doesn't take too kindly to questions of my kind ![]() recently about how forward thrust happens, he said that the engine blades simply turn the other direction. With nothing to back up my hunch, I still feel something amiss and implausible in what he said, but if true, I must confess it represents fantastic braking within the engine to first get the blades to a stop spinning, and next spin the other way! Could someone please confirm or deny what my colleague told me? That pilot, by the way, says he has not heard of 'chandelles' or 'phugoids' or even 'angle of attack'. Leaves me thinking that either Denker's book contains non-standard terminology (unlikely) or Canadians use a different set of terms (likely). OR he's feigning to keep me away ![]() Ramapriya |
On 8 Nov 2004 22:54:58 -0600, Andrew Sarangan
wrote: But not knowing angle of attack is surprising. This is basic concept everyone learns in primary ground school. However, I am not sure how much aerodynamics a 737 pilot has to know. At that level you are so far removed from the stick and rudder flying that it is quite possible they have forgotten the basics. I consider the heavy iron pilots as more like a systems manager than a stick and rudder pilot. Opening can of worms and running, but don't a number of 737's have an AOA meter? |
Ramapriya wrote:
Hi again, 30-yr old former Air Canada 737 pilot Yeah. Right. |
Thrust vs Shaft Horse Power? | Evan Williams | Military Aviation | 9 | July 22nd 04 02:45 AM |
max altitude and Mach 1 | Boomer | Military Aviation | 22 | June 1st 04 08:04 PM |
P-38 Exhaust | Stephen Harding | Military Aviation | 10 | April 19th 04 07:03 AM |
Forward Swept Wings | Canuck Bob | Home Built | 16 | October 3rd 03 05:50 PM |
Harrier thrust vectoring in air-to-air combat? | Alexandre Le-Kouby | Military Aviation | 11 | September 3rd 03 01:47 AM |
