![]() I flew over to Apple Valley (APV) to put in a little cross country time with a GPS MAP 196 in a Cessna 150 - and to indulge in a $150 diet-Pepsi. This particular airplane is the only available rental at my home patch at IYK, which we locals lovingly refer to as Inyokern International. (If you have a couple airplanes and want to be your own boss, there's an empty FBO facility there begging for occupation. I'm sure the airport management district will give you a good deal. But that's, as they say, another story. Back to Apple Valley. After dumping my waste water, replacing it with the diet soda, and getting the kinks out of my knee and back, I wandered back to the airplane. It had been in plain sight all the time, just across the tarmac from a pilot friendly little cafe. So I did a cursory walk-around, wiggling a few things here and there and checked the oil. The trip over only burned an hour's fuel out of full tanks so I was good to go. Mind you, I have less than ten hours in this airplane so I'm not intimately familiar with all its quirks. I know it is well maintained and the owner is the CFI that brought me back into flying after a 25-year layoff. This morning, the airmass over the Antelope Valley was rock solid. My airspeed was within two knots going and coming. The airplane trimmed out and flew with only an occasional nudge to keep the altitude within ±40 feet. My only gripe is an out of trim condition that requires a tiny bit of pressure on the right rudder pedal to keep the ball in the cage. The engine started without priming. I taxied to the end of R-18, the favored calm wind runway, did the complete "Before Takeoff" checklist and waited for Cessna in front of me to depart. When they lifted off. I announced my intentions (non-towered field) rolled onto the runway, shoved the throttle in and started the takeoff roll. The owner likes us to hold a little back pressure on the takeoff to ease wear and tear on the nose gear, so it takes a bit longer to gather speed and lift off. No sweat, APV R-18 is 6,498 feet. The plane lifted off just as it had before, then.... WHAT THE HECK IS THAT NOISE!?! Something was rattling and thumping hard enough and loud enough to be heard over the muffling of my passive headset. It sounded mechanical, but didn't ding like metal. Engine was smooth. Carb heat was off. Controls felt fine. Hmmm, did I screw the dip-stick in after I checked the oil? Oil pressure was good. No streaks on the side windows. Actually, I'd had an inkling something amiss about halfway through the takeoff roll, but it didn't register as anything serious. I dropped the nose, ready to cut the throttle and land straight ahead but didn't like the perspective. I rejected the notion to land on the crossing runway at the end. My choice was a shallow left turn at 500 AGL into a close-aboard downwind. I pulled full carb heat and brought the power back to hold 80K and altitude. The Cessna that departed in front of me stayed in the pattern for a normal downwind to shoot T&Gs. I called on the CTAF and told him I had a sick airplane and asked him to extend downwind and let me have the runway. He graciously obliged, as did the airplane ready to take the runway. Just past midfield, I dropped ten-degrees of flaps. No change in the rattle, thump. I did a shallow 180 just past the approach end, feeling confident that I had plenty of energy in case the fan should stop spinning. Lined up, I dropped another 10 degrees of flaps. The landing was a kisser. I should do that every time. I turned off the runway at the first available intersection. By that time I had the carb-heat off but didn't mess with the flaps. Instead of turning onto the taxiway, I drove straight ahead into a resident hangar area. While the plane was still rolling, I pulled the moisture to lean-off, switched off the mags, and opened the master switch. Here's the embarrassing part. The noise? When I'd shut the door, I'd left the tail end of the seat belt strap hanging outside-just about two-, maybe three-inches of it. It was apparent, because the door was wedged shut and required a bit of shoulder pressure to open. That didn't stop me from going over the airplane with a preflight as extensive as I'd do knowing that someone else had flown it. Thirty minutes later, with a rehydrated mouth and the puckers smoothed out of the other orifice, I took off again. As soon and the plane was off the ground, I dropped the nose and let it accelerate flying just a few feet off the surface, imminently ready to cut power and land if the noise came back. The flight home was great. I got to watch Torch-27 shoot an ILS approach into Palmdale. Torch-27 is an F-117. I learned enough about the GPS MAP 196 to be confident of using it cross-country. ...and I added one tiny detail to the Before Taxi checklist. |
On 12/14/04 8:16 PM, in article XfMvd.4651$Z%1.9@trnddc03, "Casey Wilson"
wrote: Here's the embarrassing part. The noise? When I'd shut the door, I'd left the tail end of the seat belt strap hanging outside-just about two-, maybe three-inches of it. It was apparent, because the door was wedged shut and required a bit of shoulder pressure to open. That didn't stop me from going over the airplane with a preflight as extensive as I'd do knowing that someone else had flown it. Thirty minutes later, with a rehydrated mouth and the puckers smoothed out of the other orifice, I took off again. As soon and the plane was off the ground, I dropped the nose and let it accelerate flying just a few feet off the surface, imminently ready to cut power and land if the noise came back. The flight home was great. I got to watch Torch-27 shoot an ILS approach into Palmdale. Torch-27 is an F-117. I learned enough about the GPS MAP 196 to be confident of using it cross-country. ...and I added one tiny detail to the Before Taxi checklist. I had the same thing happen to me on one of my x-c's during training. It sounded like it was overhead and I thought I had left the gas cap loose. Lesson learned. -- Jeff 'The Wizard of Draws' Bucchino Cartoons with a Touch of Magic http://www.wizardofdraws.com http://www.cartoonclipart.com The Wizard's 2004 Christmas newsletter http://www.wizardofdraws.com/main/xmas04.html |
![]() "Wizard of Draws" wrote in message news:BDE5017D.3C5DE%jeffbTAKEOUTALLCAPS@wizardofdr aws.com... On 12/14/04 8:16 PM, in article XfMvd.4651$Z%1.9@trnddc03, "Casey Wilson" wrote: Here's the embarrassing part. The noise? When I'd shut the door, I'd left the tail end of the seat belt strap hanging outside-just about two-, I had the same thing happen to me on one of my x-c's during training. It sounded like it was overhead and I thought I had left the gas cap loose. Lesson learned. -- I did leave the gas cap off my 172 once, after I dipped the tanks during preflight. I had a funny radio problem and I called my CFI on his mobile, turned out he was hanging around at another ramp so I taxied it over to show it to him. He couldn't figure anything out so I went to taxi back. I noticed a smell of fuel, much stronger than usual, and then I saw the trickle coming down the window. My penance was to spend 3 hours scrubbing fuel off every inch of the plane. In the roughly ten minutes the engines were running I think it sucked half the tank out. Hate to think what would happen in flight. -cwk. |
On Wed, 15 Dec 2004 03:03:23 GMT, "Colin W Kingsbury"
wrote: In the roughly ten minutes the engines were running I think it sucked half the tank out. Hate to think what would happen in flight. The one time I saw this, a guy left BOTH caps off his 185. On climb out you could see a significant spray (more like running water upwards) out of each gas tank. Unicom notified him of the problem and he flew the pattern and came back. He ended up with about 1/4 tanks on each side after one hop around the patch! Not a good thing. He refueled, triple checked the caps and went on his way. z |
"zatatime" wrote in message news:
On Wed, 15 Dec 2004 03:03:23 GMT, "Colin W Kingsbury" wrote: In the roughly ten minutes the engines were running I think it sucked half the tank out. Hate to think what would happen in flight. The one time I saw this, a guy left BOTH caps off his 185. On climb out you could see a significant spray (more like running water upwards) out of each gas tank. Unicom notified him of the problem and he flew the pattern and came back. He ended up with about 1/4 tanks on each side after one hop around the patch! Sure. moo |
On Wed, 15 Dec 2004 07:30:17 -0500, "Happy Dog"
wrote: The one time I saw this, a guy left BOTH caps off his 185. On climb out you could see a significant spray (more like running water upwards) out of each gas tank. Unicom notified him of the problem and he flew the pattern and came back. He ended up with about 1/4 tanks on each side after one hop around the patch! Sure. moo I'm assuming this means you believe there is no truth to what I've typed. Would it help if I told you it was an airline captain? If you'd like to give me your phone number I can have the operator who I am still friends with call you to validate the story, and probably offer more antics of this individual. On second thought you're probably not worth the price of the call. *squawk* z |
![]() "zatatime" wrote in message ... On Wed, 15 Dec 2004 03:03:23 GMT, "Colin W Kingsbury" wrote: In the roughly ten minutes the engines were running I think it sucked half the tank out. Hate to think what would happen in flight. The one time I saw this, a guy left BOTH caps off his 185. On climb out you could see a significant spray (more like running water upwards) out of each gas tank. Unicom notified him of the problem and he flew the pattern and came back. He ended up with about 1/4 tanks on each side after one hop around the patch! Not a good thing. He refueled, triple checked the caps and went on his way. Not to mention that at $4.50/gal at my home field, this is an expensive mistake. -cwk. |
Now, that was dumb. A 185 has bladders, and leaving the caps off can
pull the bladder retention snaps off inside the wing and collapse the tank. Filling a partially collapsed tank can mislead the pilot into thinking he has full tanks, and water can get trapped in the resulting wrinkles along the bottom. If the bottom is pulled up some, it will hold the fuel level sender up and give erroneous gauge indications. Those bladders need inspection after such an event. Most bladder-equipped Cessnas have an AD against the fuel caps forcing an annual inspection of the o-ring seal. A broken or crumbling seal can do the same thing as a missing cap: draw air out of the tank faster than the vent can balance the pressure, and fuel loss is the result. Dan |
"Casey Wilson" wrote in message
news:XfMvd.4651$Z%1.9@trnddc03... I flew over to Apple Valley (APV) to put in a little cross country time with a GPS MAP 196 in a Cessna 150 - and to indulge in a $150 diet-Pepsi. Casey, Thanks for sharing this and for doing so honestly...and congrats on keeping your cool. I just love how people are willing to help each other even if it through the occasional oops. Regards, Jay Beckman PP-ASEL Chandler, AZ (I'm taking my CFI with me tomorrow on a little XC jaunt as a recurring training exercise) |
I left the dipstick door open on a Cessna 182RG once. Flying from the left
seat I never noticed it. I was back taxing down the runway to the run up area when I passed another plane holding short on an adjoining taxiway. He called me on the radio to tell me (and the rest of the world) about the oil door. I shut down in the run up area and closed it while the other pilot did his runup and took off. We both exchanged a wave and a smile.... an embarrassed one on my part. Funny how it became a habit of checking that door when I was in the right seat and a student was in the left. Oh, and I've also done the seatbelt thing, but never actually took off in that condition.... because it is part of my after run up, pre takeoff check. The captain is ready for take off, so please fasten your seat belts and return your flight attendant to her upright position. Jim --- Outgoing mail is certified Virus Free. Checked by AVG anti-virus system (http://www.grisoft.com). Version: 6.0.806 / Virus Database: 548 - Release Date: 12/5/2004 |
Small plane noise is destroying my life | Robert Morien | General Aviation | 5 | December 1st 04 05:01 PM |
Cherokee Strobe Noise | Jonathan Goodish | Owning | 20 | November 2nd 04 02:42 AM |
Funny noise update | Peter Duniho | Piloting | 1 | July 1st 04 02:58 PM |
Ear plugs and noise filtering | Top Spin | Piloting | 12 | January 16th 04 04:52 AM |
Prop noise vs. engine noise | Morgans | Piloting | 8 | December 24th 03 03:24 AM |
