how to boost vhf scanner
Old January 6th 05, 08:02 AM
NW_PILOT
Default how to boost vhf scanner
What model of radio? you can alway buy a nice discone antenna will add some
dustance but if you have a cheap radio nothing will help much.
"northernsurferboy" wrote in message
I got a cheap radio shack airplane scanner. It works great when I sit in
airport parking lot but 5 km out it does nothing. I live about 15 km from
a
small airport and 40 from Pearson Internation Airport. Is there a external
antenna I can clip on to this thing to boost its receiving capabilites?
Old January 6th 05, 11:45 AM
Larry Dighera
On Thu, 6 Jan 2005 00:27:16 -0500, "northernsurferboy"
wrote in
Is there a external
It's important to have a visual path between the transmitter and
receiver, so antenna height is part of the issue. Here's something
you should find interesting:
http://groups-beta.google.com/group/... 6e6620c29b95
Now how about answering one for me. Why did you find it necessary to
cross post your inquiry to the binary newsgroups?
rec.aviation.piloting
alt.binaries.multimedia.aviation
alt.binaries.pictures.aviation
alt.aviation.student
Old January 6th 05, 01:33 PM
-=Plane Mad=-
Can u unplug or unscrew the aerial to get a bigger/better aerial on there?
the airport parking lot but 5 km out it does nothing. I live about 15 km
from a small airport and 40 from Pearson Internation Airport. Is there a
external antenna I can clip on to this thing to boost its receiving
capabilites?
Old January 6th 05, 03:35 PM
J Swaggart
capabilites?
which scanner do you have ?? I have a Pro-26 and it works fine. I do
have a mag mount antenna I use and I do monitor Pearson But only when
the plane is in the air. go here for some freq's
http://www.canairradio.com/
Old January 7th 05, 10:20 PM
the Legend of LAX
Just remember, VHF comm is line of site. If you can't see it, you can't
hear it (well sort of). I can't hear the tower on the airfield sometimes
with the large hangars in the way. Our TX antennae are less than 50 feet
above the ground, often less than 20. You should have no problem picking
up aircraft, though.
northernsurferboy wrote:
I got a cheap radio shack airplane scanner. It works great when I sit in the
airport parking lot but 5 km out it does nothing. I live about 15 km from a
Dale G Elhardt
Cypress Ca
"The universal aptitude for ineptitude makes any human accomplishment an
incredible miracle."
http://home.comcast.net/~laxet/
http://www.jetphotos.net/showphotos.php?userid=7702
Old January 9th 05, 10:27 AM
Cub Driver
On Fri, 07 Jan 2005 14:20:07 -0800, the Legend of LAX
I have the same problem with the Unicom at the local field, but not
because of the hangars. The lads in the shack turn it down so as not
to interrupt their cribbage game.
-- all the best, Dan Ford
email (put Cubdriver in subject line)
Warbird's Forum:
www.warbirdforum.com
Piper Cub Forum: www.pipercubforum.com
the blog: www.danford.net
Radio band scanner Fritz General Aviation 3 October 14th 04 07:36 PM
Aero scanner on websat websat General Aviation 0 July 31st 04 10:44 AM
Scanner Greg General Aviation 7 March 7th 04 06:06 PM
Aviation radio scanner tips? Jim Atkins Military Aviation 4 February 12th 04 06:58 PM
sounds of aviation navigation equipment as head on a scanner radio Dan Jacobson Instrument Flight Rules 5 December 4th 03 07:27 PM
