Literature mentions that the 3-blade V-22 rotor hub is attached to the rotor
shaft by a means of gimbal or universal joint. Gimbal and universal joints do not transmit a constant velocity when the hub and shaft axes are not aligned. Does anyone know if the V-22 uses a gimbal joint or if it actually uses a Constant Velocity Joint? Thanks. Dave J. |
It could be two universals close together?
But then it would need a supporting bearing/structure at the rotor end aswell. ? Hmmm... A CV makes more sence. Cam "Dave Jackson" wrote in message news:aW6xc.702485$Ig.509981@pd7tw2no... Literature mentions that the 3-blade V-22 rotor hub is attached to the rotor shaft by a means of gimbal or universal joint. Gimbal and universal joints do not transmit a constant velocity when the hub and shaft axes are not aligned. Does anyone know if the V-22 uses a gimbal joint or if it actually uses a Constant Velocity Joint? Thanks. Dave J. |
Cam
Two universals will only provide a constant velocity on the output shaft if the axes of the input and output shafts are parallel. For instance, when these two shafts are parallel but not aligned, the first universal will put a varying velocity into the connecting 'shaft' and the second universal will remove this varying velocity. I think that the hub and shaft axes on the V-22 are not always aligned and therefore a double universal joint will not provide constant velocity. Dave J "Cam" wrote in message ... It could be two universals close together? But then it would need a supporting bearing/structure at the rotor end aswell. ? Hmmm... A CV makes more sence. Cam "Dave Jackson" wrote in message news:aW6xc.702485$Ig.509981@pd7tw2no... Literature mentions that the 3-blade V-22 rotor hub is attached to the rotor shaft by a means of gimbal or universal joint. Gimbal and universal joints do not transmit a constant velocity when the hub and shaft axes are not aligned. Does anyone know if the V-22 uses a gimbal joint or if it actually uses a Constant Velocity Joint? Thanks. Dave J. |
True, I had forgoten about that (parallel in/out shafts)
But does that mean a tractor or four wheel drive suffer from alternating velocities on the front wheels when cornering? Cam "Dave Jackson" wrote in message news:Cynxc.674680$Pk3.470737@pd7tw1no... Cam Two universals will only provide a constant velocity on the output shaft if the axes of the input and output shafts are parallel. For instance, when these two shafts are parallel but not aligned, the first universal will put a varying velocity into the connecting 'shaft' and the second universal will remove this varying velocity. I think that the hub and shaft axes on the V-22 are not always aligned and therefore a double universal joint will not provide constant velocity. Dave J |
Cam opined
True, I had forgoten about that (parallel in/out shafts) But does that mean a tractor or four wheel drive suffer from alternating velocities on the front wheels when cornering? Yes, and for sharp turns, it is quite noticeable. "Dave Jackson" wrote in message news:Cynxc.674680$Pk3.470737@pd7tw1no... Cam Two universals will only provide a constant velocity on the output shaft if the axes of the input and output shafts are parallel. For instance, when these two shafts are parallel but not aligned, the first universal will put a varying velocity into the connecting 'shaft' and the second universal will remove this varying velocity. I think that the hub and shaft axes on the V-22 are not always aligned and therefore a double universal joint will not provide constant velocity. Dave J -ash Cthulhu for President! Why vote for a lesser evil? |
![]() Cam wrote But does that mean a tractor or four wheel drive suffer from alternating velocities on the front wheels when cornering? Steve's post covers the front wheel drive. To elaborate a little, The FWD has 2 CV joints; usually a Tripod joint at the 'differential' and a Rzeppa joint at the wheel. Dave J |
Are you folks sure the V22 is using a universal joint like what we find on
an automotive drive shaft? I would thing that that would be a very arcaic way to transfer power. Modern front wheel drive cars us a CV (constant velocity) joint in place of the old standard universal joint. I'm not saying that a CV joint fully eliminate the problems you're talking about with universal joints but they do work significantly smoother at higher angles. Some general links with pictures of what I'm talking about a http://volksweb.relitech.com/tech/cvjoints/cvparts.jpg http://volksweb.relitech.com/tech/cvjoints/cvfrnt.jpg Just a thought! Fly Safe, Steve R. "Cam" wrote in message ... It could be two universals close together? But then it would need a supporting bearing/structure at the rotor end aswell. ? Hmmm... A CV makes more sence. Cam "Dave Jackson" wrote in message news:aW6xc.702485$Ig.509981@pd7tw2no... Literature mentions that the 3-blade V-22 rotor hub is attached to the rotor shaft by a means of gimbal or universal joint. Gimbal and universal joints do not transmit a constant velocity when the hub and shaft axes are not aligned. Does anyone know if the V-22 uses a gimbal joint or if it actually uses a Constant Velocity Joint? Thanks. Dave J. |
"Steve R." wrote
Are you folks sure the V22 is using a universal joint like what we find on an automotive drive shaft? I would thing that that would be a very arcaic way to transfer power. Modern front wheel drive cars us a CV (constant velocity) joint in place of the old standard universal joint. I'm not saying that a CV joint fully eliminate the problems you're talking about with universal joints but they do work significantly smoother at higher angles. Some general links with pictures of what I'm talking about a http://volksweb.relitech.com/tech/cvjoints/cvparts.jpg http://volksweb.relitech.com/tech/cvjoints/cvfrnt.jpg "Cam" wrote It could be two universals close together? But then it would need a supporting bearing/structure at the rotor end aswell. ? Hmmm... A CV makes more sence. "Dave Jackson" wrote Literature mentions that the 3-blade V-22 rotor hub is attached to the rotor shaft by a means of gimbal or universal joint. Gimbal and universal joints do not transmit a constant velocity when the hub and shaft axes are not aligned. Does anyone know if the V-22 uses a gimbal joint or if it actually uses a Constant Velocity Joint? There are all FAR to mathematical for me but there are a few pictures that I liked too ![]() has a lot of diagrams. google [v-22 gimbal] returns: http://rotorcraft.arc.nasa.gov/publi...ree_AHSF02.pdf Which says: "The V-22 hub comprises three composite arms, or yokes, connected to the shaft by a constant-velocity joint." There is no detail of the CV joint in this document but tehre seem to be other documents on the same site. e.g. rotorcraft.arc.nasa.gov/publications/files/Acree_AHS01.pdf Note that the google results contain an incorrect space where in the URL displayed after the summary text. Google [v-22 "constant velocity joint"] http://rotorcraft.arc.nasa.gov/resea...amdetails.html "Gimbaled hub with constant velocity joint (spherical bearing and elastomeric torque links)" http://www.unicopter.com/1301.html Much *detail* and many ##-DIAGRAMS-## "(Somewhat similar to the V-22 tilt-rotor)" http://www.aero.polimi.it/~quaranta/...RF-2000-60.pdf "Significantly, it considers the gimbal joint, that links the hub to the mast in order to allow the fapping motion of the overall hub, and thus implementing a constant velocity joint, and the swashplate, with all the re- lated components that are required to transmit the pitch controls to the rotor blades." http://pcwww.liv.ac.uk/eweb/fst/publ...SSLA_feb11.pdf "In contrast, the homo-kinetic, constant velocity joint, featured on the V-22, requires that the drive component be connected after the gimbal springs eliminating cyclic variation of the rotor angular velocity." |
Thanks for the web sites.
The actual operation of the V-22 CV joint and whether it transmit a true constant velocity still remains a mystery. Both Bell and Sikorsky have patents on differing ideas for CV joints but I don't know if they have implemented them. The implication of a true CVJ in a rotor-head is interesting, because it should eliminate the Corollas effect and thereby eliminate a primary source of lead/lag. Dave J "AnyBody43" wrote in message m... "Steve R." wrote Are you folks sure the V22 is using a universal joint like what we find on an automotive drive shaft? I would thing that that would be a very arcaic way to transfer power. Modern front wheel drive cars us a CV (constant velocity) joint in place of the old standard universal joint. I'm not saying that a CV joint fully eliminate the problems you're talking about with universal joints but they do work significantly smoother at higher angles. Some general links with pictures of what I'm talking about a http://volksweb.relitech.com/tech/cvjoints/cvparts.jpg http://volksweb.relitech.com/tech/cvjoints/cvfrnt.jpg "Cam" wrote It could be two universals close together? But then it would need a supporting bearing/structure at the rotor end aswell. ? Hmmm... A CV makes more sence. "Dave Jackson" wrote Literature mentions that the 3-blade V-22 rotor hub is attached to the rotor shaft by a means of gimbal or universal joint. Gimbal and universal joints do not transmit a constant velocity when the hub and shaft axes are not aligned. Does anyone know if the V-22 uses a gimbal joint or if it actually uses a Constant Velocity Joint? There are all FAR to mathematical for me but there are a few pictures that I liked too ![]() has a lot of diagrams. google [v-22 gimbal] returns: http://rotorcraft.arc.nasa.gov/publi...ree_AHSF02.pdf Which says: "The V-22 hub comprises three composite arms, or yokes, connected to the shaft by a constant-velocity joint." There is no detail of the CV joint in this document but tehre seem to be other documents on the same site. e.g. rotorcraft.arc.nasa.gov/publications/files/Acree_AHS01.pdf Note that the google results contain an incorrect space where in the URL displayed after the summary text. Google [v-22 "constant velocity joint"] http://rotorcraft.arc.nasa.gov/resea...amdetails.html "Gimbaled hub with constant velocity joint (spherical bearing and elastomeric torque links)" http://www.unicopter.com/1301.html Much *detail* and many ##-DIAGRAMS-## "(Somewhat similar to the V-22 tilt-rotor)" http://www.aero.polimi.it/~quaranta/...RF-2000-60.pdf "Significantly, it considers the gimbal joint, that links the hub to the mast in order to allow the fapping motion of the overall hub, and thus implementing a constant velocity joint, and the swashplate, with all the re- lated components that are required to transmit the pitch controls to the rotor blades." http://pcwww.liv.ac.uk/eweb/fst/publ...SSLA_feb11.pdf "In contrast, the homo-kinetic, constant velocity joint, featured on the V-22, requires that the drive component be connected after the gimbal springs eliminating cyclic variation of the rotor angular velocity." |
Coriolis effect has to do with dissimetry of lift (advancing blade vs.
retreating blade) not blade velocity. On an articulated rotor head, lead/lag will remain, so CV joints are moot in that regard. Bob |
